Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Hello Guest, welcome to the initial stages of our new platform! You can find some additional information about where we are in the process of migrating the board and setting up our new software here
I have a 240, recently purchased, has no panhard rod or the mounting bolts, any help with the size and thread pitch would be great. I have one from IPD but need the bolts
The bolt is M12-1.75 x 80mm. The nuts are the same for the bolt and the diff. The washer for the diff side mount is cup shaped and shows as NLA on the Volvo parts websites but appears to be available albeit expensive. A large thick flat washer will work though.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
