My lack of updates does not mean a lack of work done. I've been working on the 242 as much as I can.
Patched up the front of the right hand sill
Painted up the parts of the floor that are completely done. The welds around the patched floor areas still need to be ground down on the underside and possibly touched up.
I made the decision to take off all the filler on the panel behind the right hand door and straighten it out as best as i could. It was bent up far more than i expected and was very difficult to get straight. As a result i ended up putting a fair amount of filler back on but at least now i know whats there and that its done properly. I welded up the holes that had been put through the panel to prevent moisture getting behind the filler on the panel.
I also welded up all the trim holes along both rear quarters. I did this by moving from one hole to the next and only partially welding the hole each time before repeating the process. I also used the same gradual process for grinding the welds down. As a result i was able to keep the warping to a minimum. The following picture shows an in progress shot of filling the bent panel and a little around the welded up trim holes.
A bit of digging at the front corner of the right rear quarter window revealed some holes and i ended up cutting out and patching the area
Trying to hide behind filler under the right bottom corner of the rear window was another dodgy rust repair. When it was patched the person doing it didn't even paint the back side
I straightened out and welded up the patch and painted in behind it as best as i could using the drain hole bellow that section. A little bit of filler and everything was straightened out.
I also deleted the trim at the top of the C pillar. I welded up the hole, ground back the weld on the seam slightly and straightened it all out with some filler.
The preparation for painting of the rear quarter took ages because there was just so many layers of paint. I decided the take it back at a minimum to the original volvo primer layer. That meant removing 6ish layers of paint
Yet another rust hole, ended up just cleaning it up and filling it with weld
Finally after many hours i primed the entire rear quarter as shown in the following pic. Following taking that pic i sprayed the panel with a mist of black paint and am in the process of sanding it back to find any low spots. So far so good, only identified one spot so far where its a little low around one the of trim holes i welded up.
With the right rear quarter more or less done i moved on the repairing rust around the rear windscreen. Yet another example of a dodgy patch in the past, bit hard to tell from the pic but there is just a bit if metal that was slipped behind a rust hole and welded in. The area now features a proper patch and painted as best as i could behind it. the rust in the rest of the lip was mostly built up again using weld.
I've also made some progress on repairs to the rear of the left hand rear wheel arch. A large part of the patch came from a donor section. The rest of the patch had to be made from hand as i dont have access to a car without butt cheeks to cut up. With the inner skin patched im ready to patch the outer skin which is likely to prove challenging to get right.
As per my previous post the 4 springs arrived (purple in the pic bellow). I also picked up another pair of springs to play with on the rear for $11.25 shipped, won on ebay, 200mm long and approx 270lb/in (red in pic bellow). The yellow springs and coilover sleeves are as per purchase awhile ago. Going to buy the coilover sleeves for the front soon.
Also picked up another turbo this time a t4 with a dodgily modified hotside housing. I combined it with the hotside of a t3 i have and a rebuild kit to make a complete turbo. Need to work out how much power it would be good for before deciding if i will keep it and use it on the 242 or sell it on
