fix your busted ass motor and trans mounts
When i assessed the shifter bushings going into the transmission they didnt look too bad and they definitely wouldnt cause clunking. I do remember last month when putting on the better driveshaft that the tailshaft assembly had play. Not horrible but definitely noticeable.
I never though of it but it is probably alot of my issue. Since I have replaced mostly everything
https://streamable.com/wjgt6v
Shifter will come out of 1st gear sometimes.
If i hold the shifter while its in first i can feel alot of movement going down into the gear compartment.
I hear a clunk sometimes bad when shifting and it hates decelerating.
Its really rumbles down there in low gear and deceleration.
If I didn't know better, I'd think something inside the trans is gone.
Worn synchros can let parts "walk" down the shafts until they disengage.
Bad shaft bearings will definitely cause a lot of noise.
What's the oil look like (assuming there's any in there)?
Clear and oily, or mostly shiny metal dust with a bit of oil mixed in?
