Old 12-09-2008, 05:18 PM   #51
500dollar744ti
still rides with MrDoug
500dollar744ti's Avatar
Originally Posted by Hagar17 View Post
yeah I'm confused -if you do this to an ezk116 and chip it - will it work on LH2.4?
the idea is just to make the "non-chippable" ezk chippable with a daughter card... when i soldered the components to make my lh2.2 ecu chippable i believe i was doing the same thing one way or another.
-Matt
1989 Volvo 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes.
1998 Volvo S70 T5m- Stock, 229k
1998 Jeep Cherokee XJ- Stock, 154k
1983 Ford F150- '89 5.0 H.O, C6/4x4, F+R LSD 4.10, 7" lift, 35s.
1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, HR-Titan 19p.
500dollar744ti is offline   Reply With Quote
Old 12-10-2008, 12:37 AM   #52
sbabbs
sbabbs's Avatar
I take it the smaller chip on your daughter card is the same kind of chip just a smaller format then the stock chip size?
Simon
Old 12-10-2008, 01:14 AM   #53
JR-66
Simon
Its a router, 3 state latch, not memory chip.
Turbopower
JR-66 is offline   Reply With Quote
Old 12-10-2008, 06:59 AM   #54
sbabbs
sbabbs's Avatar
I see, you switch back to the chip that was already on the ezk or the one on the daughter card with the switch. Correct? So if we wanted two custom chips, could you swap the stock chip that's on the ezk board also? Which chip is it on the stock non daughtercard board?
Simon
Old 12-10-2008, 08:31 AM   #55
JR-66
In my opinion, software is inside the processor in "non chippable" ICU, most likely it can be read and rewrite. This is small downside in this daughter card,
not so good to put n/a ICU to turbo car, only one usable bin.
I would still include that map switching gadget in this d-card, one way or an other.
Old 12-10-2008, 09:25 AM   #56
blabla
blabla's Avatar
I feel this deserves a little explanation.
The unchippable boxes don’t have any eprom at all. All of its software is stored in the CPU itself. Nonetheless, an external eprom can still be linked to the CPU. A few signaling pins will “tell” the CPU to discard it’s build in maps, and complete boot from the external ROM.
The EZK will use it’s RAM to store values it may learn when running. When you turn off the ignition the EZK still gets power.
And yes, the small chip on my daughterboard performs the same tasks as the small smd chip on the factory daughterboard. This chip will take care of the address latching.
blabla is offline   Reply With Quote
Old 12-10-2008, 11:57 AM   #57
Hagar17
Hagar17's Avatar
Ok I want one!
Keeping late 80's Swedish metal alive!
Hagar17 is offline   Reply With Quote
Old 12-12-2008, 12:28 AM   #58
shawty950
Default Create list of people interested?
Would it be a good idea to PM or create a list of people that are keen/interested/going to buy this "kit" when its available?
I have Freds chips coming in the new year and dont have a chippable ezk at this time.
If the kit is going to be avail approx the same time I will just get it instead of searching for a chippable box.
Am very keen to be able to buy this.
Shawty
shawty950 is offline   Reply With Quote
Old 12-15-2008, 01:50 PM   #59
BDKR
Section 9
BDKR's Avatar
Shawty
I am very interested in this idea!!!!!
For all you Dijkstra fanboys:
Old 12-15-2008, 02:02 PM   #60
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
i wouldn't mind getting one or two to futz around with. I should have the stuff to set an engine up on a stand before long, so I'll have the toys available for mucking.
Megasquirt Tuning!
linuxman51 is online now   Reply With Quote
Old 12-15-2008, 02:04 PM   #61
BDKR
Section 9
BDKR's Avatar
@55h0l3!!!
Old 12-15-2008, 02:06 PM   #62
linuxman51
linuxman51's Avatar
no, when i have an engine dyno hung off the end, then you can call me an *******
Old 12-15-2008, 06:50 PM   #63
BDKR
Section 9
BDKR's Avatar
Will do.
Old 12-15-2008, 10:27 PM   #64
sbabbs
sbabbs's Avatar
How about a redblockhoe? Comes off the tongue easier..
Old 12-17-2008, 07:34 AM   #65
blabla
blabla's Avatar
'Ho Ho Ho'
EZ116K DB GB
Old 09-13-2009, 12:12 AM   #66
Homer
OEMplus++
Homer's Avatar
Ahoy,
Finally flipped the header at work this week and installed the daughterboard today.
Its only been 8 months since assembling it.
Anyway, works like it should. Nothing exciting to report except that the EGR CEL went away.
-Jacob:
2006 A4 - Comfy DD
Old 09-13-2009, 01:09 PM   #67
Karlos_UK
Karlos_UK's Avatar
are the daughterboards still available? just found i have an unchipable box
Karlos_UK is offline   Reply With Quote
Old 09-13-2009, 11:00 PM   #68
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
I have Pm'ed you Martjin - I need my DB!
Old 03-11-2011, 08:05 AM   #69
sootie
are these still for sale
sootie is offline   Reply With Quote
