I.M. Weasel
- Sep 21, 2011
- Driving the No Malarkey Bus
Looks great, nice you made them fit, looks like a fun car.
They have similar offset to hydra wheels 30. No spacers used on the rear so I plan on getting the hubs/rotors redrilled, using long studs, and then getting spacers. Right now the car has two spare tires since the front and rear are different bolt patterns.Veeeerrrry interesting. So those wheels are straight onto the 8.8 axle? Then it's just a matter of getting the fit right on the front with some adapters. Those are more or less FWD offset, so spacers should work well up there.
What would the specs needed be (offset, bolt pattern) for 15" wheels on a 240 with a ford 8.8 that has been shortened to run 2 passenger axles? Looking to still be able to roll the project around still once I get the rear mounted. Figure I can order a couple of cheap wheels from Summit, or if anyone knows if there is a specific wheel from a junkyard that would fit?
Explorer or mustang wheels, maybe crown Vic?
Crown Vic wheels fit Ranger.
Why does no one put 5x108 axles in the 8.8? Seems like the easiest thing to do to match the front without using adapters.
How much are new 31 spline 8.8 axles with the right length and 5x108 bolt pattern?
Pretty sure crown Vic is 5x 4.5
