stayathomedad
- Apr 21, 2020
- Visalia California
531 Head to B230 Block NA application
Hey all, since there are soooo many opinions and information out there regarding head bolt choices, head bolt lubes, head bolt sealants, head gaskets, etc. I figured I'd go ahead and ask what you guys think in regards to this.
*So, what do you guys use in regards to cylinder head installs, (lubes and sealants)?
*Do you guys use any type of "sealer" with the head gasket?
*In general do you use a thread sealer along with lube on head bolts? If so, what do you use?
*Best head bolts?
*Best head gaskets?
*What do you use to clean the mating surfaces of the block and head?
*For this application I've read that the torque settings should be two stages, the first being to 44.2 foot lbs the second being 66 foot lbs? Is this accurate?
*I've read the torque sequence should start in the middle moving out? Is this generally accurate?
Lots of questions
Thanks!
*Best head bolts?
*Best head gaskets?
Lots of questions
Thanks!
