Old 03-10-2020, 05:33 PM   #1
spock345
spock345's Avatar
Default Smog Ref and a +t
Has anyone successfully gotten a +T car through the California smog ref? I have seen a few references to people suggesting that but haven't found a recent example of someone's results.
My biggest worry is them checking the block serial number and I have read mixed reports on that. I have all the parts for a +T and a cylinder head. So if they check part numbers I would just need a good B230FT block.
1967 122s, B20F, M40
Old 03-10-2020, 05:40 PM   #2
No.
Originally Posted by churd9 View Post
Has Biden taken office yet?
Old 03-10-2020, 05:58 PM   #3
spock345
spock345's Avatar
Thanks, time to go find a B230FT block.
Old 03-10-2020, 06:08 PM   #4
Might as well buy a parts car they want to see all 12# of 7-940 sheet in the 240's 5# bag engine bay.
Old 03-10-2020, 07:29 PM   #5
Oh and if it's a 940T and the ref knows his stuff he'll be looking for an autotragic behind it.
Old 03-10-2020, 07:32 PM   #6
spock345
spock345's Avatar
That is precisely why I am trying to find a 90 or 91 740 block. The only possible sticking point could be the head mounted distributor.
Old 03-10-2020, 08:03 PM   #7
122power
dude
122power's Avatar
Buy a 740t or 940t save time and effort
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 03-10-2020, 08:21 PM   #8
James M
Bored member
James M's Avatar
Head mounted distributor on a FT is the biggest issue, even though it makes no difference they will fail you for a block one. My guess is [I]if[I] you bar one with the head mounted dizzy then move to a block mounted one a smog tech won't fail you.
I was thinking about this fitment issue today, besides shimming the transmission mount id be interested in trying to hog out the holes on the motor mount to move it forward a tiny bit.
Or get a sharpy, draw a T next to the F and tell the smog guy its OEM
Old 03-10-2020, 08:34 PM   #9
James M
Bored member
James M's Avatar
Based on what I've read you can use the old transmission if you want, no need for an auto
"The transmission and evaporative systems will be allowed to remain in the recipient vehicle configuration,but must function appropriately."
https://www.bar.ca.gov/pdf/Engine_Ch...G_04.19.18.pdf
Old 03-10-2020, 10:03 PM   #10
spock345
spock345's Avatar
I have measured the clearance behind the head with the trans jacked up and there isn't much space. So either caving in the firewall or try it with a block mounted distributor.
On the transmission it should be easy to just say the engine is from a 90 or 91 740 turbo. The biggest difference visually being the smaller radiator and intercooler. You could also argue that the motor came with that transmission in the same configuration from the factory.
From that slideshow it would appear that since my 240 and the donor car are OBD 1 then keeping the M47 is just fine. Although that will be replaced in favor of something better soon after I get it past the ref.
Old 03-10-2020, 10:44 PM   #11
James M
Bored member
James M's Avatar
They will also check the ECU and EZK part numbers against the year of the motor. I don't think intercooler or radiator matters as far as the ref is concerned
Old 03-10-2020, 10:53 PM   #12
http://forums.turbobricks.com/showthread.php?t=264901
Old 03-10-2020, 11:01 PM   #13
James M
Bored member
James M's Avatar
If only it wasn't uselessly blurry Photobucket pictures
http://forums.turbobricks.com/showthread.php?t=338345
Most of what I've read consists of Volvo Kids struggle with BAR, I guess others have had better luck (or better refs)
Old 03-10-2020, 11:05 PM   #14
Agreed that's what it says on the site but a member was trying to ref a 240 to smog as a 940 which never got a stick shift here and the referee gave him grief.
Can't find the thread but it might be better to get a 740 in that case.
Old 03-10-2020, 11:10 PM   #15
122power
dude
122power's Avatar
Yeah he was in sac. Ref said he needed head mounted dizzy for 2.4. Even tho the block one is just a transfer basically.
Buy a diesel car and be done with it. Or a 75.
Old 03-10-2020, 11:14 PM   #16
James M
Bored member
James M's Avatar
Make a diesel car and be done with it. Or a 75.
Or pull your **** off every two years. Not hyped for this summer, mines coming up
If only someone nearby had a diesel car or 75 they wanted to sell
Old 03-10-2020, 11:24 PM   #17
Or buy a 240 Turbo and get happy with it for what it is.
Old 03-10-2020, 11:38 PM   #18
spock345
spock345's Avatar
I think I have everything to the point where it will take an hour or two of work to remove or install the turbo on my existing engine. So removing it for smog is doable, but annoying.
A factory 240 turbo is definitely the ideal situation.
Old 03-10-2020, 11:50 PM   #19
Well you'd better have your isht right before you go to the ref and 'call the cops' to your own party.
In any case as they say; "Good luck with your mission should you decide to accept it."
Old 03-11-2020, 12:00 AM   #20
jfry
jfry's Avatar
Find a cool smog shop that's not going to bust balls about visuals. I had one in Oakland when I lived there. Moved up north and it is as just as easy to find one. First shop up here said "you don't have a vacuum advance on your distributor". Enough said. I'm outta here. Second shop didn't give an F as long as you pass the sniffer. They've passed me about five times now.
jfry is offline   Reply With Quote
Old 03-11-2020, 12:25 AM   #21
122power
dude
122power's Avatar
pull it off every two years?! Thats sounds like a blast....
if only they would pay what its worth.
Could also look at vehicle smog cut points. Then you can pick a year that has high limits. A 76 I have has a limit of 1100 for nox which is pretty high.
Old 03-11-2020, 01:01 AM   #22
James M
Bored member
James M's Avatar
Originally Posted by 122power View Post
pull it off every two years?! Thats sounds like a blast.....
Shouldn't be too bad I'm planning my conversation now "no those holes arnt for an inter cooler, ignore those oil lines they are for an oil cooler"
The issue is passing a visual, If it was just tailpipe (like it should be) then even a +t done well would pass.
Why can't they go back to rolling 30 year cutoff
Old 03-11-2020, 01:11 AM   #23
122power
dude
122power's Avatar
idk they should. How many carb cars are on the road still but need smog tests? Heard they were trying to get them up to the year 1982 but well see.
Old 03-11-2020, 01:22 AM   #24
You sell them for ~#$2.5K are you not happy with that?
Old 03-11-2020, 01:28 AM   #25
122power
dude
122power's Avatar
I am. Most just see the price as the hurdle not the end goal.
