Old 01-10-2013, 05:07 PM   #151
DennisvdB
DennisvdB's Avatar
Originally Posted by DennisvdB View Post
I'm doing the front now, is there anybody who upgraded from regular rubber bushings to PU bushings? Noticed any difference?
Anybody?
Volvo '76 244 wizz B19A
Comin' right up: B230FT '96 squirterblock - Nathan's 8V shorty header - Holset HY35W - TTV flywheel with 850R clutch - 480cc injectors - 3" JT exhaust - Iveco IC - M90 - Buchka Wasted Spark - BlaBla Chips - RSI Stage 1 Turbo Cam - 3" MAF - full Super Pro urethane - Koni Yellow
DennisvdB is offline   Reply With Quote
Old 01-10-2013, 08:25 PM   #152
smokeyfan1000
Guest
Anybody?
The harder the poly, the more difference you'll notice. But it's not like it's going to increase lap times by 30 seconds............
Old 02-04-2013, 03:41 AM   #153
Justin
Banned
Originally Posted by grnmachine02 View Post
I think it's awesome. I need to get another turbo rear bar, as I goofed an installed one turbo and one NA bar. Two turbo bars in the front. Handles well. Just don't drop the swaybar on your face like I did when you are installing them and you'll be a-ok.
LOL! Did this aswell.. ouch!!
Justin is offline   Reply With Quote
Old 12-17-2013, 10:43 AM   #154
appalachian
appalachian's Avatar
Okay, balls deep, anybody used a 28 and a 25 up front? And 25/25 in the rear? I imagine it would feel like its on rails but maybe im terribly mistaken.
1988 244 M47 B230F
"Wednesday"
appalachian is offline   Reply With Quote
Old 12-17-2013, 11:37 AM   #155
grnmachine02
Indicating?
grnmachine02's Avatar
It'll be very tail happy. I'm running two turbo bars in the back of my 745, and while it doesn't have snap oversteer, it feels like it is one step away from it.
Super stiff rear = dorifto action even when you don't want it.
1990 745t- b230ft, ebay manifold, hy35, Microsquirt, t5 2jz and w58 eventually no engine, and a decent mold collection on the interior.
Rage boner achieved.
grnmachine02 is offline   Reply With Quote
Old 12-17-2013, 08:58 PM   #156
Janspeed
and with an open diff: bad traction out of sharp corners. The inner rearwheel will spin easy.
Old 01-02-2014, 07:56 PM   #157
hdBattousai
great guide, think i might do this to my front in the summer when i start rebuilding my 244.
anyone tried 2 in the front and none in the rear, or tested this offroad? I drive offroad so i'm not even sure if 2 in the front is a good idea let alone the rear and clearance... lol
hdBattousai is offline   Reply With Quote
Old 01-02-2014, 08:56 PM   #158
appalachian
Why again would an individual want zero swaybar action in the rear?
Old 01-03-2014, 10:20 AM   #159
propav8r
F*ck Edgar
propav8r's Avatar
That.
Originally Posted by Quin
i improved my life by just getting rid of my 940
nipple farts
Originally Posted by VB242 View Post
Space time farts
My Project
K-Jet to Megasquirt Article
Old 01-03-2014, 11:22 AM   #160
appalachian
To be sloppy and loose? Oversteer under severe load only?
Old 01-03-2014, 11:42 AM   #161
grnmachine02
Indicating?
Oi. Some folks autox with no rear bar. It isn't sloppy or loose with no rear bar, it just doesn't suddenly and violently oversteer from being too stiff.
I haven't changed my setup yet from the dual turbo bars in the rear. It can be fun, sure. But this morning on the way to work before the plows had done much of anything, it was a complete bitch trying to keep it from sliding all over the place even on moderate turns.
Old 01-03-2014, 12:34 PM   #162
appalachian
But doesn't the rear end still have a ton of body roll that could, maybe, throw the backside spinning? Or would it just drag like a big weight? If the latter, I think I get it now for racing. Less tire spin less time wasted And *better* (more predictable) control/handling?
I dont know. New to this here double trouble sway stuff and whatnot.
Old 01-03-2014, 12:59 PM   #163
grnmachine02
Indicating?
The problem with a too stiff rear, is that it's not predictable. It's not " Ok, the rear is probably going to step out now" it's 'Holy ****, why did the rear just step out' Which can sometimes be fun.
I hear where you're coming from on this. Until i experienced it, I couldn't fathom why someone wouldn't want the rear to be as stiff as possible.
Old 01-03-2014, 07:28 PM   #164
hdBattousai
New to it to thats why I asked
Yeah I go on really loose dirt (like powder) so it steps out really easily even at low speeds with the stock sways so I didn't know if it would make a dif or not considering the looseness of the dirt, however there are also some pretty packed and heavily rutted areas I drive so I was also thinking too stiff in the rear could cause the opposite tire to lose something as well and cause issues.
I'm trying to find a happy balance based on others experiences as I don't have alot of money atm and I haven't found much info on this mod past asphalt use, plus I'm buying a 960 sedan I gotta drop some $$ into as well to get it where I want
Old 01-04-2014, 05:36 PM   #165
B-lennium
I have dual stock swaybars in the front of my 164, and 1 stock 240 bar in the rear. I believe this is a perfect combination. a little stepout in the rear when its really wet outside. when its dry I need a better seat to hold on ;)
Volvo 164e B30e, Megasquirt MSII extra
B-lennium is offline   Reply With Quote
Old 01-06-2014, 03:31 PM   #166
hdBattousai
Sounds like that's what i'll try then, test it out off-road and see how it performs since I can always remove it later and try that thanks for the info
Edit: Has anyone tried dual sways on a 92-94 960 sedan? I was gonna get a beefy one from IPD but it says it only fits on the wagon and not the sedan so even if it does this will be the cheaper alternative and i'd rather do it this way
Old 01-06-2014, 03:49 PM   #167
Råda
Volvoretard/Partshoarder
Råda's Avatar
Your multilink already have a rear bar and is not able to fit dual due to lack of space. And AFAIK there are no upgrades on that. And an early 960 probably have a 24mm front bar. Which is 1mm thinner than the ipd one.
Jonas
Råda is offline   Reply With Quote
Old 01-15-2014, 03:57 PM   #168
hdBattousai
yeah wouldn't want dual rear anyway just front but if it's already 24mm not much of a point, and good to know just got the car last weekend for my birthday from UTAHGTBRIK so haven't had much chance to learn more on it
Old 07-13-2020, 01:28 AM   #169
shobin
Does anybody on this thread have the original pictures that came with this post? I'm looking to do this and don't want to make any mistakes.
shobin is offline   Reply With Quote
Old 07-14-2020, 04:29 AM   #170
Jack
junkman
Jack's Avatar
no because it's stupid
I love you even more Jack.
Old 07-14-2020, 06:01 PM   #171
Fa182
Stage 1
Fa182's Avatar
+1
Old 07-14-2020, 10:06 PM   #172
122power
dude
122power's Avatar
Idk my lemons car has dual front bars and works pretty well. Been like that since it was built afaik.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 07-14-2020, 11:17 PM   #173
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
I did it on 2 cars but I think ipd bar is better on my current car
Old 07-15-2020, 12:14 AM   #174
2turbotoys
Astro Zombie
2turbotoys's Avatar
Lol
It kinda is a bit. Just get IPD bars or something.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 07-22-2020, 11:09 PM   #175
adamdrives
In b4 triple bars
Feedback thread
78 242 DL 189k (For Sale)
83 245T+IC 136k
99 V70R 163k lazer blue
05 S60R 161k sapphire/nordkap
08 S80 V8 109k
adamdrives is offline   Reply With Quote
