![]() Join Date: Jan 2005
![]() ![]() ![]() a bit leaner than i want, so ill be a bit easy on it until i get standalone. :::::Engine::::::: -2.5L -CP piston: 8:1 CR, 335grams +/- .1grams -160mm rods (i think 600 grams, if that sounds right) -Volvo 16v head -Double Valve Springs -ARP Head Studs (same as Cossworth, hehehe) -Cometic MLS Head Gasket (MLS = multi layer steel) -Volvo Penta (boat) PZ cams: ~10mm lift and not sure of duration -10% over stock Oil Pump (SPM) -BMW Getrag Manual 5-speed transmission -6 Puck Sprung clutch -100% over PP -custom driveline (BMW + Volvo) -Adjustable Cam Gears (by SPM in Sweden) -034 Motorsports Oil Catch can ::::TURBZZZ:::: -T3/T4 60 Trim, .63a/r Turbine, .60a/r compressor 60 trim -Custom 4-2-1 exhaust manifold -Audi 10v/20v turbo WasteGate (external) -Full 3" SS exhaust, side exit, Borla Muffler, no Cat -Ebay (yeahh bitches, ebay) Intercooler -custom oil system :::::Suspension/Brakes::::: -Koni Adjustables -EuroSportTuning Springs (lame rate, and progressive - not proud of them...) -iPd 25mm sway bars, front and rear -SS brake lines As of now on NON-CHIPPED LH2.4 (turbo), browntops, 3" AMM Last edited by rallyvovo; 11-06-2007 at 01:18 AM.. |
![]() congrats
82 244glt= stock SOLD 1981 242 Tic= K-Jet, 3 inch SAM exhaust, MBC@15psi, k cam(FAIL), B cam( FTW), TTR cam gear(FAIL), 90+ ported, clutch net 4 puck, bilstien hd, 7in round e-code headlights, 8000k HIDs. 162hp/214tq @ 10psi 15.69@89.5ish ![]() ![]() |
fige=500Dollar Mistake
![]() Join Date: Jan 2006
![]() wow peak@redline, how many RPMS do you give it usually? cause the graph says it wants more
1978 244dl - Down for paint/16vt 93 245 - Kaplhenke Shortened coilovers with adjustable Koni Reds, adjustable rear spring perches with revalved bilstein S-10 shocks. Turbo 2.5 motor in the works. 10 v50 - Unobtainium T5 R-Design AWD M66 |
#4 |
cutting, welding, bashing
![]() Props on the numbers...
Motor specs would be nice! Laters Nick
Volvord Project Thread :http://forums.turbobricks.com/showthread.php?t=184497 1972 Mk1 Escort, B230, 16v, T5/4L60E, 8" Axle, KMS MD35, AIM EVO Datalogger "Volvord MK1 Escort Project" : http://www.jwbr29544.pwp.blueyonder.co.uk/escort |
#6 |
![]() damn man, that LH limiter's killing ya.
#7 |
#8 |
BRANDSCHUTZVORSCHRIFTEN!
![]() Join Date: Dec 2002
![]() Nice numbers, it wants more revs.
And thats pretty lean, sure the dyno wideband is accurate?
"They bum rushed them in their own crib, they drank all their beer, they partied with their ladies and they left with the trophy" Now with in-house Dyno tuning! Megasquirt Tuning! Plug and play LH 2.4 Megasquirt, now with stealth mode! |
#9 |
#10 |
Drunk as ****
![]() Hasn't even hit peak torque yet by redline either from the looks of it- too big of a turbo? Is that second graph screwy or is your boost still climbing at redline too? That can't be right...
And 13+:1 AFR's is getting close to "needs-a-new-motor" territory.
Currently Volvo-less ![]() |
#11 |
#12 |
![]() Join Date: Jan 2003
![]() down with lh, not bad numebers at all but I think there is a whole lot more left in her, your numbers shouldn't even been comparable to mine. How much boost is that? *edit saw you posted 15 as I was typing that*
08 535xi wagon 6sp 99 Miata Exocet |
#13 |
Guest
![]() So... it was on 8v turbo computers then?
#14 | |
![]() Quote:
get that ish on standalone and go join the 400 club. |
#15 |
![]() you need a boost controller then, that solved part of the issue on ken's car. upon closer inspection, its wanting stable boost, then we can see what kind of rev-ing it wants (but it'll still like to turn up ;) )
#16 |
Traitor
![]() buy my megasquirt you 300+ bastardo.
and thanks for showning that LH turbo comps can run a 16v car just fine. also, i agree that browntops and 3" dont mix for AFRs. would prob make more power with browntops and regular AMM: watch AMM reach cut by like 200 WHP, watch AFRs climb after that, leave content that the BTs are maxed out.
'92 944 Turbo:13.400@99.68. Sold. '90 744 16 Valve. 16.317@85.55. Sold. '92 244. Sold. http://pbase.com/740weapon |
#17 |
![]() my 38 has been working very well, I would consider something with a vband though, the tial 38 mounting screws can eat me.
#18 |
ZoomZoom
![]() Join Date: May 2003
![]() Thats not bad at all for LH!
75 242GL - LS turbo, 4L80E, narrowed four linked 9" 89 244DL- Mazda 2.3 MZR, S366, 5R55E on Electromotive TecGT with PCS paddle shifters 94 945- Beater 93 965- For sale 91 940SE- Roller, for sale ![]() |
#19 |
tequila_gundam_hug_the_toilet
![]() bastard of a web filter at work means no pics from this thread. how much power is it making (in text)?
1999 S70t5m. Volvospeed Car 2005 s60. Bucket of bolts 1996 850t Daily Beater 1992 742j ugly speed 2000 Audi A6 5spd conversion (grown man swagg) |
#20 |
![]() Join Date: May 2004
![]() 313.6.
Boost and HP increase right up to about 6100 rpm, where the test ends.
#21 |
Backwards Turbo
![]() Join Date: Feb 2005
![]() Nice work man!!
#22 |
#23 |
![]() yikes. LH ftl. buy weapon's msns, and get a better wastegate
-Billy Volvoless for the first time since 1990... ![]() 2002 Toyota Avalon XLS (comfy gradma car) 1996 Chevrolet Tahoe LS 2WD (hauls ass) 1990 Mazda Miata (track toy) |
#24 | |
Section 9
![]() Damn fine numbers ripper! And there is obviously a good deal more potential there.
#25 |
Guest
![]() I know you are not interested, but I do have chips for B230FT+16v and B234F+T... (for future 16v turbo users)
