Old 08-08-2020, 02:59 AM   #1
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
Default Just got my ipd springs...
And I want to cut them. I just want to be a little lower than they provide. Not sure how much to take off the front? I plan on doing a full turn off the rear. Sorry for another spring post but it's my first set of ipd and I know they dont sit low enough for me.
Old 08-08-2020, 03:16 AM   #2
TurboDutch
I guess two...
TurboDutch is offline   Reply With Quote
Old 08-08-2020, 03:45 AM   #3
Wilford Brimley
Old 08-08-2020, 04:25 AM   #4
James M
Bored member
James M's Avatar
Don't cut them just heat with a torch and let them sit until you like it
2003 Ford mustang V6 automatic hours out here
James M is online now   Reply With Quote
Old 08-08-2020, 09:31 AM   #5
Cut them right in half, sell the other halves to the other TB lowlifes and profit again.
Old 08-08-2020, 01:33 PM   #6
Wilford Brimley
I half expected these responses....guess I'm just not sure how much to take off the tight coil part to get little lower
Old 08-08-2020, 01:34 PM   #7
Wilford Brimley
I like the way you think...ipd spring blow out! 50% off!
Old 08-08-2020, 02:10 PM   #8
LC4CARL
Aero challenged
LC4CARL's Avatar
It's a PITA, but maybe trial and error would be the safest bet. Can't "cut them longer" as my dad used to say.
@PDXvolvo on IG
Old 08-08-2020, 02:11 PM   #9
2manyturbos
A little at a time. You can't put it back. You have actual work ahead of you. Get off here and get busy.
Old 08-08-2020, 02:30 PM   #10
mikep
The MP
mikep's Avatar
Did you install them and drive it first? Or are you guestimating?
Originally Posted by leecatd8209 View Post
Being dead has a funny way of messing up your small business, too.
Old 08-08-2020, 03:23 PM   #11
IPD springs typically have the front a bit lower than how much they lower the rear. I would try them first before you cut.
Old 08-08-2020, 04:20 PM   #12
Wilford Brimley
Thanks guys I'm going to put them on right now
Old 08-08-2020, 04:31 PM   #13
How is this thread still in performance?
Old 08-08-2020, 04:52 PM   #14
TurboDutch
Good one! Try before you cry!
Old 08-08-2020, 06:48 PM   #15
Wilford Brimley
I hate the way the front looks. Took 1 full off the rear 1 1/2 front. Mucho better
Old 08-08-2020, 06:48 PM   #16
Wilford Brimley
Old 08-08-2020, 10:02 PM   #17
Kjets On a Plane
Kjets On a Plane's Avatar
https://photos.smugmug.com/Cars/Volv...1c5-9d7e-M.jpg
Even qualified surgery is often a subtractive process.
Good luck.
How PSI a stock can support?
Always Be Crushing!
Old 08-10-2020, 03:41 PM   #18
122power
dude
122power's Avatar
Isnt the 7/9 low enough ready?
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
122power is online now   Reply With Quote
Old 08-10-2020, 04:12 PM   #19
2manyturbos
The IPD springs sit about as low as you can go and still drive a 7-9 without tearing up the bottom of the car. To each his own.
Old 08-10-2020, 05:51 PM   #20
Josh
I just installed a set on 91 940 turbo and found they sit at a great height for a daily. Don’t really have to worry about driveways or steep transitions. Paired with some Bilsteins they rode nice and compliant, actually made the car feel much more responsive without killing the ride.
Paired with hydras and stock tire sizes, I could see wanting that lower the front just a touch more to eliminate the wheel gap though. Cutting one more coil all the way or so would probably bring it down to a more aesthetically pleasing ride height. I’ve cut a couple coils off Ipd/TME springs for a 240 and the ride wasn’t too bad, it’s probably about the same case for the grandpa series cars. Of course with a lower ride height you risk bottoming out the struts more often, leading to prematurely worn out suspension components, and also throwing the geometry off a just a little too far, causing the steering to feel off and run into bumpsteer.
Whatever you do, make sure you get a good alignment so the car isn’t all over the road.
Josh is offline   Reply With Quote
Old 08-11-2020, 02:57 PM   #21
283SD
I put IPD's lowered springs on my V8 wagon 30 years ago, and 300K miles later they have settled to where I like them. Got time?
Old 08-12-2020, 11:47 PM   #22
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
howdy :D
Old 08-13-2020, 03:07 PM   #23
mikep
The MP
mikep's Avatar
Dude. Brett. DudeBrett.
Old 08-13-2020, 03:09 PM   #24
He's back for some DNA splicing.
Old 08-13-2020, 10:27 PM   #25
bionicbanana
bionicbanana's Avatar
Heady topper is good stuff
Start small, like 4 coils first
bionicbanana is offline   Reply With Quote
