Old 11-19-2020, 09:40 PM   #1
seanile
seanile's Avatar
Default Give electric fan a manual on/off switch? (no a/c)
soooo i'm going to be doing the a/c delete on my '92 240 (see sig for specs), while i also have in my possession a new electric cooling fan that will obviously be rendered useless following the delete.
my [dumb] question is if it would be viable to finagle a manual power switch, perhaps via the a/c button, to turn on the electric cooling fan at will on the stupid hot days. would this overwhelm the alternator? i am not super knowledgeable with circuitry but have some friends who are and would help me if i enlisted them, but i wanted to run it by you all as a feasibility study first.
or should i just sell the fan and move on with life.
thoughts? questions? eye rolls?
1992 240 GL (4dr, B230F, M47, LH 3.1)
seanile is offline   Reply With Quote
Old 11-19-2020, 09:56 PM   #2
carver
Redblock for life.
carver's Avatar
Those fans are not really meant to be run all the time. Kind of like an E-Fan setup. I wouldn't bother. The question that remains... isn't it wicked hawt in Boston in the summer? AC Delete... you sure?
carver is offline   Reply With Quote
Old 11-19-2020, 10:00 PM   #3
seanile
seanile's Avatar
totally fair. i wasn't considering it as an all the time thing but just a useful extra tool to keep it cool in stop-and-go on the interstates. could always just pour my iced dunkies over the engine if i'm desperate.
i've never been one to use my a/c anyway, i'm more of a drop the windows and turn up the stereo kinda guy.
Old 11-19-2020, 11:33 PM   #4
In that case it's a waste of time as the car has lots of headroom in terms of cooling capacity.
Old 11-20-2020, 06:35 PM   #5
142 guy
If you go to Speedway Motors, or JEGS or ..... you can find electric fan controllers. If your radiator tank does not have a fitting for an RTD some of these controllers come with a little rubber seal that fits in under the top rad hose and allows you to slip an RTD in to measure the coolant entrance temperature to the rad. The controllers have an adjustable temperature setting for turning the fan on.
Generally simple installation even for the electrically challenged.
Old 11-20-2020, 08:14 PM   #6
apachechef
Burnt Sierra Madre
moreso once you remove condenser
Dammit, Lummert.
Old 11-21-2020, 07:05 PM   #7
mikep
The MP
mikep's Avatar
What is wrong with you guys? It can't run all the time? Says who? If you aren't interested in his idea, stay out. One person added anything constructive.
I have done this, as an over-ride for a temp switch. Lots of people have done a manual switch. And if that fan is there, I guarantee it was built to withstand a switch sticking on and it running constantly.
OP, some systems have a switch in the lower hose area to tell a fan when the radiator is not removing enough heat. So there's another way to do it. I have even used a headlight switch (or maybe an old pull-switch for wipers) to turn on low and high, using a resistor for low. You can do anything you want.
Originally Posted by leecatd8209 View Post
Being dead has a funny way of messing up your small business, too.
Old 11-21-2020, 09:12 PM   #8
seanile
seanile's Avatar
that does sound reasonably doable option to have, thanks. i've got nissens 3 row i'm planning on installing this coming spring. haven't looked closely at it and it's packed away at the moment so i'm not sure what fittings it has available.
excellent, that's exactly what i was looking for. i appreciate your input.
Old 11-22-2020, 01:34 AM   #9
carver
Redblock for life.
carver's Avatar
Ok to be a little more constructive. Here's a way to use an 850 E-Fan relay to turn on a fan. No switch necessary if you just use a relay, turns on and off with the car. Temp switch only turns fan on at whatever temp your switch is rated. Get one of these:
Wire it in like so...
I don't really know the particulars on the AC fan but here's a thread that addresses it.
Questions? PM me anytime.
Old 11-22-2020, 06:35 AM   #10
OttoB
When i was innovative (lazy) i used brake light switch to turn on the efan.
Old 11-22-2020, 09:27 AM   #11
shoestring
shoestring's Avatar
C'mon, kid, don't waste your Dunks like that. I'll meet you in the pahkin lot at Kelly's Roast Beef over in f*hkin' Saugus there and we'll take care of it.
In all seriousness yeah, you could use that switch. I would wire it to a relay, not so that it carried all the current through the switch. I'm sure it's not rated for that.
Old 11-22-2020, 01:50 PM   #12
seanile
seanile's Avatar
thanks everyone, very helpful. this gives me a lot to work with.
carver, i'll likely shoot you a note in the spring when i get into installing the new radiator, appreciate the offer.
dammit i haven't been to kelly's in too long, thanks for the reminder to get my ass back over there shoestring
Old 11-22-2020, 02:16 PM   #13
Default KISS
Or stick to your original plan with amp rated wiring & a switch installed in a blank plate on the center stack console.
Old 11-22-2020, 03:32 PM   #14
mikep
The MP
mikep's Avatar
I think he's all set, then. Are we all set? I'm all set.
Watch out for that one guy, though. He's storrowed again.
Old 11-22-2020, 05:52 PM   #15
All set except for the fuse.
Old 11-22-2020, 06:22 PM   #16
shoestring
shoestring's Avatar
Storrowed? I thought he was Makin' it in Massachusetts...
Old 11-22-2020, 06:38 PM   #17
Dann sind wir Helden
I had it hooked up to switch the ground on position 85 on the above diagram. 86 had power from another relay that turns on with the key. I used an all blue a/c switch and grounded one side of the switch to the steel frame.
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 11-22-2020, 07:40 PM   #18
mikep
The MP
mikep's Avatar
For those of you following along at home:
https://en.m.wikipedia.org/wiki/Storrow_Drive
Old 11-23-2020, 09:39 AM   #19
esmth
Storrow/Soldier's Field is a fun drive at 1am.
1991 244 LH2.4 M46 341k miles
Old 11-23-2020, 02:12 PM   #20
shoestring
shoestring's Avatar
I like the picture of "Storrow drive mid-afternoon". Looks like they photoshopped all the cars out.
Last post from me on this. Sorry to jack this thread.
Old 11-23-2020, 02:26 PM   #21
seanile
seanile's Avatar
all good, i've watched a semi being backed up from the BU bridge by staties before. ****in hilarious.
my favorite part is the wiggle under the longfellow overpass. makes the tires chirp every time.
Old 11-23-2020, 02:54 PM   #22
brickcupra
Default Fan switch
Hey , It might be a little hard to do wiring, but all the ideas above sound good. Just a tip, make sure you have heavy duty gauge like # 8 or so to power the relay and the fan. Also use a fuse between the power supply ( Battery or any place with heavy gauge power) and a good clean ground. It might be a good idea too to use a diode to prevent power back feed into the relay . I used a temperature controlled switch but I swap my engine to a supra 7mgte and I had an extra port in the coolant thermostat housing.
Good luck. the a/c fan is a push fan. It will be a good a idea to use a pull fan ( behind the radiator) and eliminate the fan clutch system , Youll safe some horse power.
Take care
DZ
brickcupra is offline   Reply With Quote
Old 11-23-2020, 06:41 PM   #23
Mike, it will literally cool better with the little auxiliary fan and the evaporator out of the way. Hell, a car making 3-4x the power will handle the extra heat output just fine with the same hardware OP has. If an auxiliary fan is needed, then there is something broken with the system that needs to be addressed. Plain and simple.
Furthermore it will actually be a nice little chunk of change for OP if they put those things up for sale as the late model dual pass stuff is pretty desirable
Old 11-23-2020, 09:37 PM   #24
Marvelous3
Who engineered this?
Marvelous3's Avatar
Yes, it can be done. My old grey car had a manual rocket switch that controlled the pusher fan for the ac. It’s a simple single pole relay, some wiring, and a rocker switch. Probably take you an hour or two to wire up and make it look nice.
Old 11-28-2020, 09:17 AM   #25
dalek
Benchracer Tribe
dalek's Avatar
I thought the turbobricks way was to have an exposed wire you grounded to an exposed frame part to turn the fan on.
Feedback!
