John V outside agitator
- Mar 25, 2005
- Sleezattle, WA, USA
It's been obviously a long time that I've been to Boston...
It'll be a long time before I ever go within 400 miles of that place.
240 / aggressive : those words should never be used in the same sentence.
/thread.
-2.3 degrees of camber and 5 degrees of caster. 1/8" toe in combined.
Don't be surprised if the alignment guy has no idea how to get those settings. Unless its a race friendly shop half the techs don't know what to do if the computer doesn't tell them which screw to turn.
You need camber plates and coilovers to get those numbers. Stock spring diameter is too large. Caster isn't adjustable unless you have adjustable strut mounts, like these ...
http://www.kaplhenke.com/collections/240/products/240-adjustable-strut-mounts
or adjustable control arms
Do you have a product info/installation sheet for the mounts? That's one thing he asked for besides the specs I want.
What do you need besides alignment numbers? There are 4 bolts and 3 sliding paths. If he can't figure out which way to adjust it for negative camber run away as fast as you can.
I remember the first time Bne saw a triangle, and Towery had to show him how to handle it without poking an eye out.
If he has never seen the product before, it's fair to give him a photo or diagram.
My opinion, having worn out many sets of tires by using aggressive specs while waiting for that autocross to come along:
I would go -1.5 camber, +4 caster, and enough toe to keep the tire wear at bay. 0.1 -0.2 degrees positive.
Ended up going with this. Feels good so far, car is much more fun now. Thanks for the tips.
