Old 12-24-2012, 04:55 AM   #1
Se88e_K
Default Se88e_K's crazy Volvo 142 16v Turbo
2010
Just bought it. On the way home.
Painted in the garage
VEMS 3.6
First time on the road
Firt version turbo engine
VEMS 3.6 display
Se88e_K is offline   Reply With Quote
Old 12-24-2012, 05:01 AM   #2
Se88e_K
new rims
Old 12-24-2012, 05:07 AM   #3
Se88e_K
Holset hx40
Old 12-24-2012, 05:11 AM   #4
Josh
Crazy. Love that color
Josh is offline   Reply With Quote
Old 12-24-2012, 05:16 AM   #5
Se88e_K
Winter 2012/13
I Build a new engine now.
Engine spec:
B230fk block -98
Original crankshaft
H profile rods
Wiseco 8,5:1 forged piston
16v head
machanical camshafts 11,7mm lift, 280deg
HX40 turbo
Old 12-24-2012, 05:29 AM   #6
Se88e_K
VS bmw m3 e46
I test launch control
1,2bar boost
1bar boost
Old 12-24-2012, 06:54 AM   #7
Arjen
Great car man, nice fabrication skills and attention to detail. Got some more specs on the fuel system with in tank pump and all? I got some problems with my 144 tank and want to go with an in tank fuel pump and surgetank, or did you ditch the in tank pump when you went with the surgetank?, I can't really tell by the picture.
404hp with stock rods back then? and now your going 16v maybe wanna sell me an 144 b230 intake and/or exhaust manifold?
Arjen is offline   Reply With Quote
Old 12-24-2012, 07:19 AM   #8
Se88e_K
Yes stock rods and piston with 404hp at wheels.
i find one more picture on my tank.
I have a walbro fuel pump inte the tank to a 2,5liter surge tanke then a bosch 044 pump.
Al parts from my old engine is sold.
Old 12-24-2012, 09:13 AM   #9
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
Hey there, whats the size of the exhaust housing on your big big holset? i'm looking at the dyno plot on the old engine and that thing spools fast. you must be using electronic boost control.
Old 12-24-2012, 09:26 AM   #10
Se88e_K
Size is 14 the smallest holset have to hx40. i´m using electronic boost control.
I have 1,8bar boost at 3700rpm on street.
I use this valve to control boost
Old 12-24-2012, 10:30 AM   #11
DNAsEqUeNcE
†John3:16
nice. I need to re-think and re-do my approach. i've got 11cm2 on hx52 billet, but a more cobbled 16v approach.
Old 12-26-2012, 08:37 AM   #12
ovlover
ovlover's Avatar
Love it!!! Fantastic build!!!!!
ovlover is offline   Reply With Quote
Old 12-26-2012, 05:37 PM   #13
frodosm3
frodosm3's Avatar
wow this is a nice car!!! could you elaborate more on what you did to the block and what else was done to the 16 Valve head. Im in the process of building an engine myself and want to know what are the options out there for a high horsepower higher revving engine
1976 Volvo 242DL Holset HE351 16 Valve
1983 Volvo 242DL New Daily
1993 Volvo 244 For Sale
1966 Volvo 122S Amazon
frodosm3 is offline   Reply With Quote
Old 12-26-2012, 07:07 PM   #14
Se88e_K
thanks.
B230fk-98 block, bored to 96,50mm
H profile rods
Forged wiseco 8,5:1 piston
Balanced original crankshaft
Cooperring headgasket
( http://server.pure-pf.com/webshop/pp...oopervolvo.jpg )
Double valve spring
Stainless valve 36mm on, 32out
Ported 16v head
rebuilt to MECHANICAL camshafts
280deg, 11,7mm lift, 256deg at 1mm open
HX40 54mm in/65mm out, exhuast size 14
Fuel: e85
With this part will i rev 8000rpm.
At 2bar boost i will have about 550hp/700nm
Old 12-27-2012, 12:00 AM   #15
frodosm3
frodosm3's Avatar
Originally Posted by Se88e_K View Post
thanks.
H profile rods
Double valve spring
Ported 16v head
Fuel: e85
thanks for the info my friend!!! im in the process of building my own motor and 550HP is around how much HP i want, i will be following this build closely, i hope you dont mind me asking questions so many questions.
heres my build
http://forums.turbobricks.com/showthread.php?t=219476
Also, aside from the work you listed, is everything else stock on the motor?
Old 12-28-2012, 01:05 PM   #16
Se88e_K
I have build a own fuelrail with an8 connecting on both side.
Also weld a flange to trottlebody on the intake.
Old 12-28-2012, 03:55 PM   #17
Sebastiaan245
Fy fan vad snygg, skulle gärna se den på riktigt.
Sebastiaan245 is offline   Reply With Quote
Old 12-28-2012, 06:03 PM   #18
DNAsEqUeNcE
†John3:16
all steel
Old 12-27-2013, 02:31 PM   #19
Se88e_K
Last time then i write here.
Dyno graf. hp is on wheels
i tryed 201m, but i drove only one times then a drive shaft broke.
And a week later i broke my getrag 262 on a track day
I Think i have to little Power this summer so i change to a holset hx52 now.
I will have about 600whp now.
Bmw 530d e60 transmission and Sachs 765 with 6 puck sinter
Old 12-27-2013, 03:22 PM   #20
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
So awesome!
I like the intake.
Old 12-29-2013, 02:25 AM   #21
diponyou
diponyou's Avatar
dude this f'n epic, you swedes are crazy.
Brandon B.
1993 240+T ms2v3, 96#s, e85, T5
1984 242ti Hi-Comp b23 N/A, m46. Work in progress
93's Build Threadhttp://forums.turbobricks.com/showthread.php?t=264885
84 242 Hi-Comp N/A Build Thread
http://forums.turbobricks.com/showthread.php?t=290023
diponyou is offline   Reply With Quote
Old 12-29-2013, 12:44 PM   #22
Råda
Volvoretard/Partshoarder
Råda's Avatar
One crazy car! Love it
Jonas
Old 12-29-2013, 12:56 PM   #23
Se88e_K
Thanks for the comments
Today I finished building everything on the car. So now I'll just buy oil for the gearbox so I can begin to reassemble everything. Then do I just wait for better weather so I can map it on the street.
Old 12-29-2013, 03:16 PM   #24
Hagar17
Hagar17's Avatar
So excellent! Utterly impressed!
Keeping late 80's Swedish metal alive!
Hagar17 is offline   Reply With Quote
Old 12-29-2013, 04:00 PM   #25
rj740t
rj740t's Avatar
Man you're doing an amazing job! So inspiring! which exhaust housing you got on that hx52? When do you expect to see full boost?
rj740t is offline   Reply With Quote
