Old 12-29-2013, 04:16 PM   #26
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
No boost spiking cause of the single wastegate?
Old 12-29-2013, 04:29 PM   #27
Se88e_K
Originally Posted by rj740t View Post
Man you're doing an amazing job! So inspiring! which exhaust housing you got on that hx52? When do you expect to see full boost?
16. full boost about 4500rpm, but i really don´t know. With my old hx40 have i full boost at 3700rpm.
Se88e_K is offline   Reply With Quote
Old 12-29-2013, 04:32 PM   #28
Se88e_K
I´m really dont know what u mean. It´s eayier to build. And i don´t see any problem with a single 60mm wastgate, i have one 50mm before.
Old 12-29-2013, 04:50 PM   #29
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Some say when you have a twinscroll you need one wg for each scroll to avoid funny things happening to your boostlvl...?
Old 12-29-2013, 04:59 PM   #30
Se88e_K
I have a partition up to the wastegate valve. So I make use of twin-scroll fully anyway.
And we most over here builds like this, because it works well.
It's a little hard to see from the picture, but it can be seen that the wall goes right up. It is about 3mm clearance between
Old 12-30-2013, 11:47 PM   #31
+Kardboard+
Chinese guy/Swedish rides
+Kardboard+'s Avatar
'08 XC90 V8 Big Björn|'88 245DL Uncle Sven, sold|'95 945T Darth Haul, sold|'82 242GLT B23E Lumpy the Angry Viking, sold|'77 244DL, sold|'90 744T, sold
mtd240: I suspect "the wives" have a super-secret forum to discuss whether or not they will let us buy Volvo parts.
DavidSamuels: Not a website, a panel discussion/reality show. Real Housewives of Gothenburg.
-Feedback-
+Kardboard+ is offline   Reply With Quote
Old 01-11-2014, 11:50 AM   #32
Se88e_K
Would mount the gearbox for a while but ran into some problems. 765 pressure plate off the clutch cover. So had to grind some on the inside but it was not enough. Was then put on 765 pressure plate in the lathe and turn it down a bit and now it's free.
TODAY
So now I have working clutch
Thought the link would be very heavy tread with a 765 pressure plate. But it was like a normal clutch.
But a hell of rooting to get the air but eventually it went. But then decoupled the not so got forgives steam pin on the slave cylinder 15mm then it got better.
Then I've probably welded on the clutch pedal 5 times today before it got good. But it takes quite far down but it should work now, remains to be seen on a test drive.
Has continued to mount back some stuff today. Finished building the pressure tube.
Old 01-11-2014, 02:16 PM   #33
Råda
Volvoretard/Partshoarder
Råda's Avatar
That's some serious turbo
Jonas
Old 03-22-2014, 02:58 PM   #34
Se88e_K
Now it was a while since I updated the thread. Has happened quite a lot since then.
Has built roll bar, etc.. The car is now ready for summer '14. Just a little remap the engine a bit first. I will have about 600whp, think that's enough to burn some tires on the street.
It will not be so very text, but here are some Pictures.
Old 03-22-2014, 03:16 PM   #35
Se88e_K
How can I rename my thread? Can not not find where to do it.
Old 03-22-2014, 03:36 PM   #36
FattMatt805
juggalo
FattMatt805's Avatar
hit the little red triangle below your name, (report button) and nicely ask a mod to change it
1998 V70 T5M, 245k 218WHP, 238TQ. 15.19@95mph
1996 855T *CRASHED*
1987 suzuki samurai, stock, rolled twice, removed antiroll bars, 30"AT
1977 F250. 460ci
1957 H.D. Sportster. Mothballed
FattMatt805 is offline   Reply With Quote
Old 03-22-2014, 05:34 PM   #37
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Holy hell that looks AMAZING!
(PM me with what you want the thread retitled)
Old 03-22-2014, 11:45 PM   #38
shaved240
shaved240's Avatar
what flywheel are you using?
1988 244: b230f+t, M46:PARTED
1995 960: SOLD
1994 945: SOLD
Old 03-23-2014, 02:57 AM   #39
Se88e_K
Custom made billet flywheel from bakaxel.se
Old 03-23-2014, 03:23 AM   #40
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
that turbogenror
Old 03-26-2014, 03:59 PM   #41
shaved240
shaved240's Avatar
this flywheel?
http://bakaxel.se/koppling/svanghjul...tartkrans.html
and you're using a standard 765 e34 M5 pressure plate and 6 puck clutch? So besides turning down the outside of the clutch the pressure plate just bolts up to that right?
I'm not too keen on my 9" dog dish flywheel w/ standard 740 turbo pressure plate and 6 puck. Doesn't hold all that much torque and this seems like a good solution.
Sorry for the many questions, but can a 765 pressure plate be fitted to a redblock flat flywheel aka 8.5" flywheel?
Old 03-30-2014, 12:00 PM   #42
Se88e_K
this flywheel?
Yes it is the flywheel I have. You can not use 8.5 "flywheel, it is too small in diameter., You can use the dog dish flywheel and turn it flat and drill it for 765 pressure plate.
Old 03-30-2014, 12:05 PM   #43
Se88e_K
Homemade flex plate in aluminum between the gearbox and propshaft. Dual bolt pattern, 110 mm to gearbox and96mm to propshaft
Old 03-30-2014, 12:07 PM   #44
Se88e_K
Then I was out premiere ran a bit today
Drove not so long but had not washed the car from everything garage pond during the winter.
Tried to throttle a little was welling up at 0.4 bar only but there is potential.
Will probably replace the gearbox pads late, sits nylon pads now. Becomes a little too stiff.
Is a little vibration from the ´propshaft so I may adjust the support bearing little.
Now it's just a little mapping left then all is finished.
Brings some images.
Old 03-30-2014, 01:07 PM   #45
BoostRadley
BoostRadley's Avatar
OMFG! My new favorite car. Nice work.
BoostRadley is offline   Reply With Quote
Old 03-30-2014, 01:22 PM   #46
Hank Scorpio
Really just a gorgeous car! Maybe the coolest 142 I have ever seen!
Old 04-19-2014, 11:40 AM   #47
Se88e_K
Now it is finally a bit mapped on the street
Has not been anything special fuss at all except that there is vibration in the driveline around 60km / h, but then drop it completely.
Tried then to schimsa up support layer 1.5 mm and then it got better but it's not quite a hundred yet. But as soon as it loads so it's no vibration at all.
boost that is at least 1 bar now. Then we raised it to 1.2 bar but it became just a little higher revs after 6000rpm so it's little lab spirit mad load valve left .
Full pressure is now at 4700rpm is enough to get it a little earlier with some more lab spirit but on the whole it works well I think.
The grip is completely absent in 3rd gear now so the question is how much boost I can use before it starts to spin completely on the street.
The idea is to charge at least 1.5 bar late , otherwise you will get increase boost late in the bench if it spins to much on the street .. Now dc load valve on only 23% all the way and now rises a little boost all the way to the turbo 's not the bottom than
With my past turbo so the valve was set to 79% and then fell boost still at higher rpm so it was probably pretty stressed .
Was going to take to boost up someone else day now during the Easter Holidays.
Google transle is my friend ;)
Old 04-19-2014, 02:31 PM   #48
Daviticus
This is amazing.
Blue 1979 245, Khaki 1988 244.
Go read performance subforum for like a month.
Daviticus is offline   Reply With Quote
Old 10-23-2014, 01:25 PM   #49
Se88e_K
Much has happened since the last update.
In May drove first on the Strip. Went pretty well. 11.25 / 207kmh @ 402m.
Low in revlimitid 50m before the finish.
Then I drove to the race track and crashed quite dramatically into a steel railing.
The car was crooked frame both front and rear. The car is under construction now again with much fiber, whole front, doors, trunk lid and plastic windows.
Is the front axle from the 240 now with its own tubular frame. Becomes very pictures now.
Before the crash
Own toppmounts
Old 10-23-2014, 01:29 PM   #50
fortbrick
fortbrick's Avatar
No going back now I guess. This should be interesting... haha.
