shane5.2vodoo
- Jul 13, 2016
What mods need to be done to a 531 head previously used in a boat, for automotive use? I am aware that it most likely will not have the sodium filled exhaust valves needed for Turbo use. But besides that and the combustion chamber volume difference compared to the 1000530 head, what other mods are necessary (I believe the head has to have a hole drilled and tapped to accept a fuel injection system, coolant temperature sensor below intake port #3 ...manifold mating surface flange).
Is there enough material around the exhaust valve seats, to accept slightly larger exhaust valves? Would larger valves hit the tops of the cylinder bore?
