M.H. Yount
- Nov 1, 2008
- Charlotte, NC
Why not try measuring the temps first? The result just may keep you from coming up with a solution that doesn't really work to solve a problem that doesn't really exist...
It's just an idea I came up with. Wanted opinions as to whether it'd do any cooling or not.
considering manufactures/etc do it, i'd put money it would cool(that and logically it would)
No company that I can find makes a finned cover for the 240 diff with electic speedo wires going into it. If they did, I'd damn sure buy one one if it wasn't 200 bux.
.....really? you expect a high performance diff cover for a volvo for under $200? if you want cheap and and upgrade, pull the diff cover and weld some fins on it already
And the diff gets pretty hot on a 100F* day after 100 miles of 65+ MPH driving. Was just looking for a cheapass way to cool diff a little.
pretty hot? that's all relative, shove a sensor in it and see what the gauge reads if you really cared
What if you switched to synthetic and ran some ducting like they do for brakes and blow it on the diff housing itself?
LOL, A plain Finned aluminum cover isn't worth 200+ bucks. I remember when they were $35-45.00really? you expect a high performance diff cover for a volvo for under $200? if you want cheap and and upgrade, pull the diff cover and weld some fins on it already
Muchachito, seriously, this is one of those ''less than 0.272% change'' things.
You have no idea if whatever temp it is now is a problem but you do know that whatever it is that many Volvo axles with normal 'merikun service ie "aaaaaw sheeeeeut, I hain't lookt at the axle or trannie fluid since that time that th' hogs done ate yer sister" have gone 200-300k miles..
Rather than fawkin wif this pull the head and mill off 060! get some pop going.
I know the PO i this car. I have every receipt for work ever done since new. All Volvo dealership work in CaryNC. I' was just wondering IF my idea would work. nope, not pulling he head for more pop.. Gonna drive it for 600,000+ more miles is my plan.You have no idea if whatever temp it is now is a problem but you do know that whatever it is that many Volvo axles with normal 'merikun service ie "aaaaaw sheeeeeut, I hain't lookt at the axle or trannie fluid since that time that th' hogs done ate yer sister" have gone 200-300k miles..
I've got one with well over 500,000 miles on diff . My 79 245. But that does not mean it will not benefit from cooler oil now does it?Guess what? it gets hot, it cools down and is ready to do that routine again and again....
when was the last time you heard of a diff failure from heat? all the diff failures I see here seem to be shock related, and not a breakdown of the fluid.
My 242 has 400,000 miles on it, many of those miles are from Hwy 5, 70+ mph from SF Bay Area to Los Angeles , diff has not blown up.
For an endurance racer, it would be cheap insurance...or if you had real data, not just a hunch...
See my point? I might give my idea a try after I get the rest done to the car.
I wish I knew someone who'd let me borrow an infra red theromometer gun thingy, to get a before & after reading on diff temp when I do. Just to see if it cools any.
After all, those little rinky dink oil coolers for engines, mounted under the hood in engine heat, still cool the oil.
