Old 11-15-2019, 07:19 AM   #1
Mattis
Mattis's Avatar
Default Redblock AW transmission to whiteblock AW bellhousing?
Hi.
As the title says. Has it been done, or can it be done?
Helping out a friend thats gonna put a b6304 into a volvo 164, and he wants to stay automatic..
The donor had a questionable transmission.
So we're looking for alternatives, preferably something that just bolts on to the bellhousing, and old redblock transmissions came to mind
I don't remember anything about the old redblock AWs, but I remember some of them had a detachable bellhousing.. wich ones? And do they share the bolt pattern with the AW 30-43?
Or are there other alternatives that don't need a bunch of wiring?
Thanks
Mattis is offline   Reply With Quote
Old 11-15-2019, 08:19 AM   #2
Lankku
Lankku's Avatar
Maybe someone has done it, but I don't see why would you. You'd have to make a bellhousing by joining new and old, drill new holes into the flexplate for the torque converter and machine a sleeve to center the torque converter to the crank.
I would buy another whiteblock AW if the current one isn't good. Not much more wiring to do than with just the engine.
245 -90 "B6284T"
Old 11-15-2019, 08:38 AM   #3
Broke4speed
Broke4speed's Avatar
The old AW7x boxes don't have the same bellhousing pattern at all. It's been attempted in the past, but they're 100% incompatible.
The AW30-40 probably just needs new clutches, and that's pretty easy to do.
1984 244/ AQ140A / M46
Broke4speed is online now   Reply With Quote
Old 11-15-2019, 08:39 AM   #4
Chumley360
Isn't the AW7x series bellhousing significantly deeper than the AW30-40?
Got boost? Yes! Got manual? Yes! Got gear? Yes! Got V-8 power? No
1995 940t
Chumley360 is offline   Reply With Quote
Old 11-15-2019, 09:34 AM   #5
Mattis
Mattis's Avatar
We're still in the brainstorming/bench racing phase, so mostly just throwing options around here
I agree that maybe finding a better/fixing the old box is probably the way to go
So in short.. You can not swap the bellhousing on an AW7* with the bellhousing from the whitblock box?
Old 11-15-2019, 10:39 AM   #6
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
get a toyota 1uz or 2jz auto. same bolt pattern
Megasquirt Tuning!
Old 11-15-2019, 10:40 AM   #7
linuxman51
linuxman51's Avatar
no. its the same 'shape' but the pattern is shrunk down and the aw71 bellhousing is extended.
Old 11-16-2019, 01:26 PM   #8
lummert
lummert's Avatar
An AW4 from a RWD Jeep Cherokee or RWD Jeep Commanche pick up is compatible with the bellhousing from a 960 trans. The transmission controls from the AW4 may also be easier to adapt.
Old 11-23-2019, 08:38 PM   #9
Mattis
Mattis's Avatar
Looks like it will be swapped with another stock box..
But was wondering if any one has continued the development on the flappy paddle controller the poi made once upon a time?
Old 11-24-2019, 01:12 PM   #10
Broke4speed
I converted the schematic to a PCB to make it easier to build.
http://forums.turbobricks.com/showthread.php?t=349801
I have a couple PCBs left, but you'll need a Parallax board to finish it off.
Old 11-28-2019, 02:14 AM   #11
OttoB
Toni had AW72 with B6304 in his 245. He used KL-Racing adapter plate.
