Old 09-28-2020, 11:51 AM   #1
v8volvo
Default Disabling 200 series steering column / ignition lock without key?
This is related to the car discussed in another thread here: http://forums.turbobricks.com/showthread.php?t=356756
I decided to drag it home and try to save the drivetrain for another project. The rest of the car is really too far gone to be worth anyone's time, even with the diesel VIN, now that I have had time to look at it more closely. Needs paint on every panel, interior is beat, etc. I'm going to discourage everyone who expressed interest in hauling it somewhere else, but it'll be OK as a parts donor.
I got new keys cut to VIN by Volvo, but they don't work. Presumably another example of Volvo's support for the old rigs getting worse or less consistent, or the car was re-keyed at some point. Anyway, without any keys, I can't get the car out of there and onto the trailer since the column is locked. Hotwiring the engine is no problem but I need to be able to turn the wheels.
Anyone have a good trick to releasing the column lock on a 200 series? Big screwdriver and big hammer do the job to smash the ignition cylinder apart? Other approaches that are known to work? Don't really want to go over there and spend an hour mangling the thing without getting it freed up.
86 745 D24T/ZF 340k lifted 2.5"
83 764 D24T/M46 145k
93 Toyota 4x4 pickup 1.9 TDI swapped
04 Audi Allroad 6MT 2.0 TDI swap in progress
01 Audi Allroad 6MT 2.7TT
02 F250 SD 5.4/4R100
v8volvo is offline   Reply With Quote
Old 09-28-2020, 12:18 PM   #2
Pull the steering shaft.
Old 09-28-2020, 02:34 PM   #3
Spend $25-$35 and have a key cut from the door lock cylinder. I doubt your car was re-keyed. In my experience, Volvo gets the keys right about 70% of the time from the VIN.
Old 09-28-2020, 05:52 PM   #4
v8volvo
Then what? Put vise grips on the splined stub and steer it that way? Gotta be an easier way.
I thought about that and tried a few locksmiths, feels like a little more effort than I want to go through, pulling the door apart, etc. Might be the only way though. That's funny about the 70% guess, I used to have keys made by the dealer regularly 10-20 years ago and they were always right on, but this is the second case of a misfit I have heard of in the last year. Maybe they used to do a better job keeping track of the info than they do now.
Nobody knows if you can just punch out the lock with a mallet and chisel? No one here has ever tried to steal a 240? (I'll finish the joke myself -- no, 240s are not worth stealing )
Old 09-28-2020, 06:38 PM   #5
You can punch the lock. I have been forced to do that more than once. Count on having to use a die grinder as well as good quality drills. The combo of die cast pot metal and hardened rollers makes it quite a process to drill out the lock. Count on breaking a few twist drills in the process. There is no putting a screw driver in the lock and turning it like you can on an 80's Ford. Those cars can be stolen in less that 5 seconds. Plan on an hour or two destroying the lock on that 240. BTW, you don't have to take the door apart to get the lock out. Use the passenger door lock. All you have to do is remove the two screws that secure the lock retention plate to the door, use a thin punch to push the plate off into the door, pull the lock cylinder out. It will take you less than 3 minutes. Now, if you want to reinstall the door cylinder, then, you have to remove the door panel.
Old 09-28-2020, 07:49 PM   #6
You can pull the ignition/lock assembly off the column in about 20-30min if you know what you're doing. That allows you to turn the wheels without having a key.
Edit: Apparently there are 3ish versions of steering column and lock depending on years. I had the easy-peasy bolt on one, super easy to take off the switch with the clamshell mount.
Later ones are pressed on.
http://cleanflametrap.com/ign_sw.html
Old 09-28-2020, 07:54 PM   #7
How? Without the key the dead bolt/steering lock pin won't retract. Therefore, you can't remove the casting.
Old 09-28-2020, 07:57 PM   #8
Edited my post. Check out the different types in the link. I got lucky with the clam-shell type.
Old 09-28-2020, 08:48 PM   #9
Yes. Those you certainly can. I didn’t think about that. His diesel is probably old enough it may have that type in it.
Edit: The 1982 244 steering column I have here has the clamshell type you mentioned. His 1980 should have the same type in it. Easy. Good catch.
Old 09-28-2020, 11:15 PM   #10
v8volvo
Interesting, good info, thanks, now we are getting somewhere.
So with the early "clamshell" style looks like you can unbolt half of the strap that holds the lock assembly to the column. But what if the locking pawl is extended and engaged? Will it still come off of the column once you get the screws out? It looks like it might be able to.
Old 09-29-2020, 01:16 AM   #11
It should be able to tilt enough to slide off sideways.
