Inertia is your friend.I have an impact gun and 24mm impact socket, but i thought the whole point of this socket is to be able to keep the strut from spinning while tightening the 24mm nut?
No longer turning when you hit it with the impact IS proper torque
Not bl-l-l-l-l-l-l-l-l-l-l-l-l-l-l-l-l-spinny-spin.
Blip. Blip. Blip.
Let the nut tighten a bit more with each blip, before the heavier main shaft has a chance to start spinning.
Gee, what's wrong with the deep off-set box end wrench for $15?
Most strut manufacturers use a different tool to hold the shaft. You may need more than 1 tool if you're changing brands.
