Idle speed in gear should be 750 rpm. With AC switch completely turned off. If AC switch is even slightly turned to the right of the "0", the idle will be elevated to around 900 rpm in gear and 1000ish in park. There is a microswitch that tells the computer to adjust the idle, depending on if the AC is on or off. Sometimes, the little metal flapper that operates the switch gets bent and will not make contact, causing the engine to run at the faster idle speed, even when the AC is turned off all the way. If the AC is dead, and that is occuring, you can disconnect the wires to the switch, or pull the AC relay (located behind the fan switch area of the control panel, clipped to one of the supports), which will cause the idle to go back down.
