bmdubya1198
- Aug 24, 2016
- Charlotte, NC
bmdubya, check out the last few posts in VolvOrr's thread. See if any of it applies to your situation. I saw in an earlier post that you're using an iPD cam. You might need at least an adjustable gear, or in a worst case a different cam.
Thanks for posting this! It sounds like his issue is very similar. I actually ordered an adjustable cam gear from STS machining last Friday, just waiting on it to ship. Hopefully it will be sent out soon so I can advance the cam timing a little bit. I really think that's the issue.
Some good points were brought up on that thread as well. I have no idea how much the head was machined on mine, I should ask the previous owner what the machine shop told him. My valve clearance is fine though, so I don't think there's anything to worry about on that end.
