Hello all. I am trying to resurrect a 1985 Toyota Corolla RWD (aka AE86) and am looking at swapping the rear end with something more robust and came across the 1979-1991 (?) Volvo 240 rear end as possible candidates. I believe I've done enough searching to be somewhat informed but there is so much confusion in all the threads I've read that I was hoping for some clarification.
Chassis: 1985 Toyota Corolla RWD (aka AE86).
Engine: Toyota 3SGE "Beams" 2.0L engine from a 1998-2005 Toyota Altezza and will left stock, possibly with ITBs (because ITBs). 207hp@ 7600rpm and 160 ft lbs @ 4800rpms.
Transmission: Toyota J160/Aisin AZ6 mated to the 3SGE from the Altezza.
Things I would like to clarify:
1) The AE86 axle width, from hub surface to the other is 1410mm. The 1030/1031 axle width is 1400mm (correct?).
2) The 1030 is available from ~MY1979 through ~MY1985
3) The 1030 is essentially a Dana30 and all parts for a Dana30 will transfer over (correct? I understand there are "reverse" rotation Dana30s and offset pumpkins but I am not talking about those obviously)
4) The 1031 is available from ~MY1985 onwards
5) The 1031 is Volvo specific and there are proprietary parts like bearings (correct?)
6) In either case, there appears to be a split amongst the available ring and pinion gears depending on which ring and pinion you start out with. This split appears to be at 3.73. Anything below, you can only go lower. At 3.73 and above, you can use anything higher.
7) The 1031 is stronger than the 1030 due to larger RP
Given the modest power, low torque goals and the higher revving nature of this engine I am looking at the 1030.
I will be looking to install a limited slip differential of sort. Ideally, a clutch based one but a Torsen/Helical type one will suffice if I can't find one. The 1030 appears to be the better bet with this in mind since Dana30 parts can transfer over.
I would like to change the bolt pattern to 4x114.3. I know you can get a spacer conversion but would like to avoid that. In the offroading world, a new hub with different bolt pattern is possible for the Dana30. If the 1030 is essentially the Dana30, I should be able to do this as well.
The AE86 stock FD is 4.3. The Altezza stock FD is 4.1/4.3 depending on year. Wheels/tires are VERY different between the two thus I was going to possibly start with 3.9 gearing. I haven't done the math yet. If going with the 1030, an aftermarket 4.1/4.3 would need to be sourced. If going with the 1031, a drop in 4.1 can be sourced from a Volvo 740.
So right now, everything seems to be pointing me at the 1030 rear end. Is my above reasoning sound? Is there any reason why I should consider the 1031 other than it being slightly stronger? Anything else I may be neglecting?
Thank you in advance for your expertise.
