John V outside agitator
- Mar 25, 2005
- Sleezattle, WA, USA
Who?
It's real easy to measure deck height. Straight edge and some feeler gauges that you will need to shim your cam anyways. From there it's just a little math away from knowing what thickness you can get away with depending on your maximum rpm.This is a pretty old thread but it has peaked my interest in raising compression. I'm planning on install a 114938 - Billet HD VX Street Performance Camshaft from IPD and since I'll be learning how to do that for the first time I may as well learn how to install a head gasket. Because I'm just planning to wing it in my garage I won't try to figure out the piston protrusion, stretch, valve clearance or have a machine shop smooth out any surfaces.
Can anybody suggest a Cometic gasket thickness that will work with the new camshaft, that is very unlikely to cause any damage to the motor considering nothing being measured, and I will feel an increase in performance? I drive the car pretty easy and it has an automatic trans. I'm just looking for some more grunt while getting onto highways and while towing my trailer. Something less than .040?
Has anyone else been having a hard time finding head gaskets for a b230 on the cometic website?
Oh and I have an '87 245 with the stock head.
Thanks for your help.
squish quench or whatever you want to call it is not a thermal thing it is about creating a high turbulence combustion chamber and not having any dead areas of fuel mixture that get exposed to the fire AFTER cylinder pressures have increased beyond the auto detonate level.
Squeezing the fuel mix into the center of the mix vigorously stirs everything up and creates a more homogenous mixt and shares all the fuel mix with the fire.
Any high temps seen in those edges is cause by detonation as they would otherwise be cold spots.
I think squish better describes what happens though. As the piston *almost* touches the head on those quench pad sides, it violently *snaps* the air out of the rapidly closing gap. That creates a lot of turbulence in the central chamber in the already burning mixture. All that added turbulence helps 'quench' the hot spots in the area because the air is moving more. The less close the piston gets to the quench pads, the less 'snap' there is, the less turbulence is created, and the more hot spots are allowed to linger.
And the thickness of the gasket doesn't matter that much, it's the distance between the piston at TDC and the head - the pistons may be above the block, below it, or flush with it at TDC. Measure that, and add/subtract from the head gasket to arrive at the measurement that really matters.
I'm running .036 on the PV (block decked to zero the pistons), .040 on the 16VT, because that head design doesn't really have quench pads so it doesn't really matter much.
