Old 06-30-2020, 12:18 AM   #76
rms
rms's Avatar
Rear brakes lines done and started on the fronts. Pressed in the long BNE studs on the front hubs and mounted up the Brembos. Making progress...slowly.
File Type: jpeg 96A894E4-92A7-47C8-BF53-6AA90B07BDAF.jpeg (78.8 KB, 536 views)
File Type: jpeg 7B548F40-F600-4EDF-BA8E-135B7077FCA1.jpeg (83.2 KB, 533 views)
File Type: jpeg 9B3FF4DB-883C-4DBE-9A3B-8AD9517B220B.jpeg (99.7 KB, 535 views)
-Ryan
rms is offline   Reply With Quote
Old 06-30-2020, 12:26 AM   #77
itlksez
itlksez's Avatar
That’s beautiful.
itlksez is offline   Reply With Quote
Old 06-30-2020, 10:07 AM   #78
Vol242vo
Keep it clean...
Vol242vo's Avatar
Yes!!!
Derek
1 Owner - 85k mile 1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 07-01-2020, 06:44 AM   #79
MikeSr.
What, me worry?
MikeSr.'s Avatar
Where are you in Acworth? I am over by the lake.
I coulda had a V8!
Old 07-01-2020, 09:26 AM   #80
rms
rms's Avatar
Iím in Brookstone.
Old 07-01-2020, 10:31 AM   #81
3wagons
3wagons's Avatar
Been a while since I've checked in on your progress. Car is coming along great. Sounds like we may have enough local folks for a cruise in at some point.
82 242
83 242
86 745 M46
92 745
94 945
3wagons is offline   Reply With Quote
Old 07-01-2020, 10:41 AM   #82
MikeSr.
What, me worry?
MikeSr.'s Avatar
We could start an Acworth 242 club- I have 2- ‘81 with LS swap and a stock ‘83 flathood turbo.
Old 07-01-2020, 10:59 AM   #83
rms
rms's Avatar
Looking forward to it!
Old 07-01-2020, 11:17 AM   #84
white855T
Originally Posted by rms View Post
Thanks! Beige is definitely last on my favorites list too, but something about the original paint and patina that make this car an exception.
Yo man, Beige is the like the best Volvo color ever! You don't even know how lucky you are...
I just picked a swag table for my bandsaw, can't wait to use it for exhaust stuff. I got mine with the foot switch.
Old 07-01-2020, 11:26 AM   #85
rms
rms's Avatar
Youíre gonna love the Swag table, and the foot switch is a must! 👍🏻
Old 07-30-2020, 09:15 PM   #86
rms
rms's Avatar
Worked on the interior a little. Dyed the rear carpet black with Rit dye in a tub, and used good front carpet from a 90 in the junkyard. Looks great after a shampoo. Also used the rear seat covers from the 90. My original brown interior had turned purple. This two tone brown/black should look pretty sweet.
File Type: jpeg 7A14B730-DCEB-4A75-93E7-362967C54C82.jpeg (118.6 KB, 426 views)
File Type: jpeg 33F72D13-619D-4204-9965-643B6EEDB662.jpeg (128.1 KB, 428 views)
Old 09-09-2020, 06:18 PM   #87
rms
rms's Avatar
So Iím changing things up a bit. Iíll be V8 swapping my 242 with a Ford 302, and still using the T-5 transmission. I already have a roller 302 and a set of TFS heads. This will be carbureted as well. I made the motor stands from plans I found on here, and the block bolts in great. Steering shaft is tight and I know the headers will be too.
Also scored some nice wheels from MikeJr on a trade. I think they look pretty sweet. 17x8 et40 with 215/45/17 and a 25mm spacer.
Old 09-11-2020, 12:18 PM   #88
rms
rms's Avatar
My dash pad is in bad shape with multiple cracks, having spent 4 decades under the Florida sun. Fortunately, a great member here had a perfect one and I was lucky enough to score it. Now that the old dash pad is off, I may see about changing out the heater core. I canít image thatís a fun job.
File Type: jpeg 3D556267-DA90-44E3-96E2-08DA3A73BEB2.jpeg (100.3 KB, 301 views)
File Type: jpeg 3DB4796F-4710-4401-AECB-1E83E280D2E3.jpeg (111.5 KB, 306 views)
Old 09-15-2020, 05:54 AM   #89
740atl
educator monkey
740atl's Avatar
Awesome project. The 302 is a nice little drop in and the tfs heads will wake it up.
Old 09-15-2020, 07:57 AM   #90
rms
rms's Avatar
Thank you! I am definitely more excited about it, now that Iíve changed directions.
Old 09-15-2020, 08:26 AM   #91
740atl
educator monkey
740atl's Avatar
I like the little 302. I know it’s not the most advanced or highest flowing or has the most power but it gets the job done. You won’t be disappointed. I just installed an explorer gt40 intake and gt40p heads on my buds 242 302 and it runs great. I chose to use the exploder coils and trigger wheel setup to run edis8. The edis8 starts flawlessly every time.
Not to mention you can almost drop an entire 5.0 drivetrain in the car. Except for the yoshifab ds to diff adapter it’s all stock... and pullapart must have a ton of them in stock.
Old 09-15-2020, 09:47 AM   #92
rms
rms's Avatar
I like the little 302. I know itís not the most advanced or highest flowing or has the most power but it gets the job done. You wonít be disappointed. I just installed an explorer gt40 intake and gt40p heads on my buds 242 302 and it runs great. I chose to use the exploder coils and trigger wheel setup to run edis8. The edis8 starts flawlessly every time.
Not to mention you can almost drop an entire 5.0 drivetrain in the car. Except for the yoshifab ds to diff adapter itís all stock... and pullapart must have a ton of them in stock.
I've been a Ford guy my whole life, mostly Mustangs and F100s. I needed a cool project a little out of my comfort zone. When I found this 242, and this forum, I knew that was it. I was really hell-bent originally on using the 6 cylinder white block from the 960 I bought, but now I'm glad I decided to go back to my roots, drivetrain wise. I have a ton of spare Ford parts, like this 302, so it really works for me.
Pull-a-parts here in ATL, 3 of them, are pretty sparse in Mustang stuff. I may be able to score a driveshaft there though.
Old 09-15-2020, 10:41 AM   #93
matt b
WHat are you using for a panhard bar ?
Looks good, the dyed carpet looks like it was always black. Loving the progress.
Old 09-15-2020, 10:50 AM   #94
rms
rms's Avatar
Thanks! I was pleasantly surprised how well the Rit dye worked too.
I have the Kaplhenke V3 panhard bar.
Old 09-17-2020, 10:28 PM   #95
rms
rms's Avatar
Mocked up the bellhousing, trans, and Foxbody driveshaft. Have a Yoshifab adapter coming for the pinion yoke. Iím very pleased, and a little surprised, how well it all fits in then 240. Driveshaft to floor clearance is a little tight at the rear, so I may clearance the tunnel a bit. The shifter even pops through the factory hole perfectly. Iím pretty happy at this point, but I havenít got to the exhaust yet...😕
File Type: jpeg C7E6476A-7AE8-4ECF-A2E0-9A8F4FEF0E74.jpeg (133.3 KB, 210 views)
File Type: jpeg BE0C7CFC-A539-4FC6-8C1E-9A0E386966B9.jpeg (151.7 KB, 210 views)
Old 09-17-2020, 11:10 PM   #96
2turbotoys
Salaminizer
2turbotoys's Avatar
Very cool, the 5.0 has one of my favorite exhaust sounds when done right. That is worth a lot in the drivers seat. T5? I missed that part
Edit, it is in the thread title lol, my bad
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 09-17-2020, 11:16 PM   #97
rms
rms's Avatar
Thanks! Agreed, the 5.0 with a mild cam and 40 series flowmasters is an amazing sound. Exactly what this will be. Takes me back to high school days.
Old 09-18-2020, 04:16 PM   #98
rms
rms's Avatar
Mocked up the heads and shorty headers. Just like everyone who has done this said, one driver side tube hits the steering shaft, and the header flange hits the body on the passenger side. Nothing a BFH and some redneck engineering canít fix.
File Type: jpeg 990D6191-D35F-4A89-A412-4277C98AF09E.jpeg (127.6 KB, 184 views)
File Type: jpeg 1AD1D3DA-AFCD-4420-B4E4-031E996F627A.jpeg (132.8 KB, 184 views)
File Type: jpeg 84D70642-1241-4133-A2D5-F742611038C6.jpeg (127.7 KB, 180 views)
Old 10-07-2020, 06:25 PM   #99
rms
rms's Avatar
More mock-up and header solutions. The passenger side header flange hit the frame rail, so I cut it off and tacked in a 45 degree elbow. This seems to be a good option, and itís still removable from the top. Also modified the transmission crossmember for the T-5.
Old 10-11-2020, 10:49 PM   #100
rms
rms's Avatar
Pulled the heater box out to replace the heater core. Decided to strip it all down and clean it. It was pretty filthy. Core was actually fine, but Iíll replace it anyway since Iím here. I just hope I can figure out how to put it back together.
File Type: jpeg AD6A612E-2CAB-4CFC-9460-6967FAB03267.jpeg (116.4 KB, 67 views)
File Type: jpeg B6B043D3-184C-48F6-BD43-DB61232A0156.jpeg (106.7 KB, 68 views)
