Old 09-21-2020, 07:40 PM   #1
will740turbo
Question Putting a b230ft into a GLE wagon - radiators are different?
Hey, turdbo folks.
I'm assembling my L-block after getting it back from the machine shop, and looking ahead.
The car it's going into is an 89 GLE, and the radiator is only about 18", along with the fan shroud. I know I'm going to need some parts, and I saved a lot from my totaled car, but not the radiator. I don't think I have the shroud anywhere.
Anyone done a swap like this? I wouldn't mind going to an electric fan, but wasn't planning on it right now. I know I'm going to need a new PS pump pressure and return line, but I'm sure there will be some aggravating surprises.
What's with the little radiator in this car? Is it from the 16V POS engine, or the year?
will740turbo is offline   Reply With Quote
Old 09-21-2020, 07:51 PM   #2
740atl
educator monkey
740atl's Avatar
Do you have a donor car you can source parts from? IIRC the earlier 740 radiator isn't as long as the late 740/940... but should still be fine for turbo use. I had an 88 740 GLE that I did a +T swap with and it never had cooling issues.
Old 09-24-2020, 03:45 AM   #3
will740turbo
I don't have one anymore. I crashed my 90 740t (with 314k miles after 12ish years), and stripped everything I thought I would need from it. I never considered that the radiators would be different though.
Old 09-24-2020, 05:47 AM   #4
740atl
educator monkey
740atl's Avatar
Use the one you have.
Old 09-27-2020, 05:07 AM   #5
will740turbo
Why? I'm doing a mild build on this car. I don't want a smaller radiator that was made for a non-turbo engine.
Old 09-27-2020, 05:42 PM   #6
740atl
educator monkey
740atl's Avatar
Well good luck with that. I ran a turbo setup for years on that same tiny radiator you’re complaining about. What are you worried your 190rwhp turbo wont be able cope with that radiator? Get past it and move onto the next issue.
Old 09-29-2020, 03:00 AM   #7
will740turbo
For future reference - 24" radiators are for the stock e-fan cars.
