Old 11-25-2020, 10:43 PM   #1
mschultz373
Default fuel pressure spec
what's the spec for a 94 940 Turbo? running LH2.4. I hooked my gauge up at the rail and it read ~45psi. seemed to hold for a few minutes after turning off, too. It was a quick read before leaving the shop for the night.
I read on some 'volvo answers' site that that's high, but I figured I'd come to the experts and ask.
I have yet to test pressure at the fuel supply line to the main pump. should that spec be the same?
what does it mean if my PSI is above/below the spec? I've been getting terrible gas mileage (14-16mpg) so I wonder if she's running rich, but I don't know for sure if that'd be verified with a pressure reading or not.
thanks as always yall
mschultz373 is offline   Reply With Quote
Old 11-25-2020, 10:52 PM   #2
90volvo
I believe thats right on? But Im sure some experts will tune in .
B230ft rebuilt -8.8 comp. -Stage 3 rsi cam
3 inch ex.-GTX3076r turbo ballbearing.
ebay intercooler-3 inch IC piping- Oil cooler with 10an hose.
port stock intake (weak, having a custom intake by viking fab.)
Megasquirt 2-1300cc injectors (running E85)
530 head with big valves ported and assemble by culberro
Old 11-26-2020, 01:11 AM   #3
It should read 45 PSI with the vacuum line disconnected. With the vacuum line connected at idle the gage should read ~ 39 PSI.
Old 11-26-2020, 02:53 AM   #4
mschultz373
vac line at the FPR? I had that connected. so... does that mean my FPR is broken?
Old 11-26-2020, 03:12 AM   #5
Was the engine running when you took the reading?
Old 11-26-2020, 03:52 AM   #6
mschultz373
Yea, engine @ idle in P.
I'll take more thorough, careful readings at both the rail and supply line in the morning to confirm this finding.
Old 11-26-2020, 04:48 AM   #7
That isn’t that far off. I’ve seen that much variation before without problems. Measure the pressure again with the engine idling and the vacuum line off and plugged.
Old 11-26-2020, 10:12 AM   #8
OttoB
My engine was running quite normal with 70 psi fuel pressure. Idle was too fat but surprisingly lambda correct the afr quite well.
OttoB is online now   Reply With Quote
Old 11-26-2020, 02:36 PM   #9
mschultz373
i think everythings fine. reading this morning was ~41psi @ idle in P with vac line attached, went up to ~50psi without vacuum. held the 41psi for 20+min after turning car off. I couldn't get a read at the valve before the main fuel pump - connected the gauge but it read 0 - but I suspect that valve may be clogged or something. the car has been running mostly fine, in D at idle it can feel rough and vibrate a lot but i think my motor mounts are completely toast.
Old 11-26-2020, 03:22 PM   #10
It's fine. I usually see 41-42 PSI at idle with the vacuum line connected. 45 with it disconnected.
