MadDog_945
Våga Vägra 8V
- Apr 25, 2006
- Lower Saxony
AMON Bruder
Moving the top of the strut assy will mostly affect camber, side to side. If fore/aft, caster. Toe would be affected only slightly if at all, and as Det17 said would be checked/adjusted last.Quick question about this process:
You only have to move the front stud toward the inside (toward the engine bay), correct? Seems that this would affect the toe more than the camber, I would think you would want to move both the front and rear stud mounts in parallel?
Tim
Of course, toe must be readjusted. From my experience, that is step 3, after you set camber (1st) then caster (2nd). This modification does not permit much camber change, as the slots in the strut towers are fore & aft.....i.e. caster.
It seems to me that the difference between the two is that, in the two bolt method the maximum that the tophat can be moved Without grinding the hole in the top of the tower, is approx 10mm, and that moves the centerline of the strut assy also 10mm.
The one bolt method as above here moves the front bolt only, up to 23mm, and pivots off the stationary rear bolt. So how much the centerline moves (which would be the actual determinant of caster change) has not been measured AFAIK, but could be calculated if one was more up on geometry than I am currently. My guess though is that it's in the 8-11mm range. Still worthwhile. .
And I misspoke in my analysis; This
<i> So how much the centerline moves (which would be the actual determinant of caster change)</i>
should be This
So how much the centerline moves (which would be the actual determinant of <b>camber</b> change)
I'll edit that post so it's not confusing.
Yer thinkin' is severely impacting yer doin'.
Aw shucks...
'measure twice, cut once' 'twas said.
Or, 'Make careful decisions and then pull the trigger'
Occasionally I do it that way.
Actually it is better to move rear bolt since the lever effect is better on that one, the lever is about 0.6 vs 0.4 on the front bolt. Which means you gain more neg camber by moving the rear bolt.
True no doubt, especially for a DD/keep it running ok sort of thing, but for me it's also a hobby so it's fun, and one thing I can control fairly easily and cheaply. Some do race these, and maybe our little exercise in going through it will spark some tiny bit of performance gain.It's not THAT important that you do 100% same movement on both left and right bearing ...
I'm fully aware of that, but the caster you will lose by moving the inner bolt ~15-25mm is negligble, maybe 0.1degrees maximum.
What can be more benefitical is that you will probably gain more negative camber before the tophat hits the strut tower (if you cut out some material on the upper side).
Same for 7-series, or is there a difference?
