Old 12-21-2016, 10:44 AM   #1
noz-e8tr
noz-e8tr's Avatar
Default s60R R brake upgrade=massive brake squeal. Thoughts?
My 242 was upgraded to s60r brakes using STSmachining's adapters and since I have had massive brake squeal. Mostly at light to moderate braking. Under hard braking it stops. I'm not talking a little squeal here. Ear drum bleeding in stereo from both front brakes. I find myself waiting till the last minute to brake so I can brake hard to keep it quieter.
Before everyone starts throwing ideas, let my tell you what I've done.
3 completely different sets of pads. Different compounds and different brands. Made no noticeable difference.
I have chamfered the edge of all the brake pads with a grinder ...No difference.
Rotors, I originally had cross drilled and slotted. Changed them to OEM plain rotors, no noticeable difference.
I'm open to suggestion here guys. Has anyone had similar results?
Berserker 242 Build Thread
This subculture is not conducive to meeting women let alone inspiring them to drive 30 year old, rectilinear, underpowered shit boxes.
Originally Posted by Walt Disney
"All our dreams can come true, if we have the courage to pursue them."
noz-e8tr is offline   Reply With Quote
Old 12-21-2016, 10:56 AM   #2
grnmachine02
Indicating?
grnmachine02's Avatar
Stupid question, but have you greased up everything? Brake Squeal is usually caused by a lack of lubrication. Also, the s60r actually had a campaign about brake squeal. I can't remember if they changed pads and rotors, or just pads.
1990 745t- b230ft, ebay manifold, hy35, Microsquirt, t5 2jz and w58 eventually no engine, and a decent mold collection on the interior.
Rage boner achieved.
grnmachine02 is offline   Reply With Quote
Old 12-21-2016, 11:00 AM   #3
Brake noise can be very tough to cure. The best first step is to use lots of lube. Even on the pad anywhere the caliper touches. Try new hardware also and make sure it's properly Iinstalled. Wire brush the brake hardware surfaces and maybe even lube under there too.
Old 12-21-2016, 12:43 PM   #4
mopar318
mopar318's Avatar
What pads? Squeel is normal with aggressive compounds.
Also, stock Brembos groan normally when driving as well.
Pimps out interiors.
1980 242 16 valve turbo
2007 V70R
mopar318 is offline   Reply With Quote
Old 12-21-2016, 04:36 PM   #5
GTJordan
Been here for too long
GTJordan's Avatar
There is a shim available for behind the pad. I believe this is the campaign mentioned above. Can try those out.
Old 12-21-2016, 04:49 PM   #6
ErikS
FWD!
ErikS's Avatar
+1
The flat shim eliminates it 90% of the time.
'95 854 T5M
'15 MB ML350
'15 F150 3.5 Ecoboost
ErikS is offline   Reply With Quote
Old 12-21-2016, 04:55 PM   #7
77volvo245
77volvo245's Avatar
We installed these on a customer car, works great, zero squealing. The rotors are really expensive I would recommend buying the AKEBONO pads from IPD. Get your rotors turned down give a nice clean surface.
https://www.ipdusa.com/products/5242...tors-s60r-v70r
https://www.ipdusa.com/products/9715...rumbs=P0,P9134
STSmachining
Old 12-21-2016, 06:55 PM   #8
flyfishing3
flyfishing3's Avatar
Ding ding ding
2018 4Runner
2016 Outback
2005 Sequoia
98 v70r saffron/tan.
Huge insurance bill.
follow me to V70R & S60Rhttp://v70r.com/forums/
flyfishing3 is offline   Reply With Quote
Old 12-21-2016, 07:42 PM   #9
mopar318
mopar318's Avatar
Odd though. I am running hawk HP+ on my v70r with no shims and don't have that bad of squeel. The usual aggressive compounds whining when stopping with mild braking force.
Got a video?
Old 12-21-2016, 07:56 PM   #10
fortbrick
fortbrick's Avatar
Pad shims. Should come with the oem pads. Not sure if available separately. I usually just re-use the old shims.
Old 12-21-2016, 08:06 PM   #11
Marvelous3
Who engineered this?
Marvelous3's Avatar
I have those stoptech rotos on my wagon. Purely anecdotal but I've experienced no squealing with them.
Old 12-21-2016, 09:00 PM   #12
M.H. Yount
M.H. Yount's Avatar
Shims and lube all metal-to-metal contact with a SMALL amount of appropriate lube.
Old 12-21-2016, 09:02 PM   #13
aristg
El Greco Capitano
aristg's Avatar
My rear pads (brembo pads + brembo 330 no drilled rotors) stopped squealing after the dyno session where wheels got 15 times up to 240 km/h ... So i assume it was the brake dust or something.
Plus LOCTITEpaste does miracles
aristg is offline   Reply With Quote
Old 12-21-2016, 09:03 PM   #14
Texas240
Prius Owner
Texas240's Avatar
Just installed s60r fronts on my 245. Im using stock oem rotors, akebono ceramic pads that came with shims on them and that red lube stuff that semi dries. Zero squeal or chatter. I went heavy on the lube
93 245 LS Engine Swap Project
Old 01-08-2017, 10:46 PM   #15
Texas240
Prius Owner
Texas240's Avatar
Any update on this? Mine started to squeal now thats it cold here and the brakes aren't getting up to temperature with mostly highway driving right now.
Old 01-10-2017, 10:46 PM   #16
matt b
Grease alone won't work. Make sure you use the shims too. Really hot temps or really cold temps, I get minor squeal (even with shims) but most passengers don't even notice it.
Shims, man shims....
Old 01-11-2017, 12:09 AM   #17
Texas240
Prius Owner
Texas240's Avatar
I have shims that came with the pads. The squeal is pretty bad. When my fiancé starts questing noises....
Old 01-11-2017, 12:14 AM   #18
volvo?
That One Guy
Mine are terrible, almost un driveable. Are the Cadillac ones this bad?
volvo? is offline   Reply With Quote
Old 01-11-2017, 12:49 AM   #19
Texas240
Prius Owner
Texas240's Avatar
Same Pad is used. Makes me wonder. I'll try a true caliper piston grease instead over pistons with the semi lastic squeak product thats on there now.
Old 01-11-2017, 12:55 AM   #20
volvo?
That One Guy
Keep us updated. I'm getting g tired of the squeal.
Old 01-11-2017, 02:03 AM   #21
Maybe it's your custom relocation brackets.
Old 01-11-2017, 02:09 AM   #22
volvo?
That One Guy
I was actually thinking that. Maybe the caliper is not centered over the rotor?
Old 01-11-2017, 05:31 AM   #23
Tuff240
240 Ninja
Tuff240's Avatar
Didn't they offer a stiffening/dampening bracket for the R brakes?
-Patrick
Old 01-11-2017, 10:53 PM   #24
Texas240
Prius Owner
Texas240's Avatar
Hmmm. Didn't think about that. Guess I could buy a different brand of brackets and see.
Old 01-12-2017, 03:46 PM   #25
noz-e8tr
noz-e8tr's Avatar
I have no update as of now. Mine are still ear bleeding squealing at anything less than full on hard braking. I'll be pulling it apart this weekend to re-check alignment and centering. I have the metal shims that came on the r calipers. Like I've mentioned, I have tried 3 different pad sets of different manufacture and grip. I have also tried plain OEM rotors and my dimpled and slotted rotor all with the same results. I'll recheck everything and assemble with lots of grease. However I won't have results for a couple weeks as I'm also swapping out heads and cam.
