#26 |
Been here for too long
![]() Have you tried factory pads?
80 242- 2.5L 16V, NIW intake/exhaust, T5, Porsche brakes, short billies and Kaplenkhe suspension, Trutrack. Project Thread- http://www.turbobricks.com/forums/sh...d.php?t=324470 |
#27 |
TQ>HP
![]() I think the alignment may be important, if they are not parallel, seems that would impart vibration/noise till the clamping pressure is enough to make everything rigid. Either that or mount is not rigid enough as was discussed , You've eliminated pretty much everything else
1985 Chevy TPI V8 740. “Expertise in one field does not carry over into other fields. But experts often think so. The narrower their field of knowledge the more likely they are to think so.” – Robert A. Heinlein “We must reject the idea that every time a law is broken, society is guilty rather than the lawbreaker. It is time to restore the American precept that each individual is accountable for his actions.” – Ronald Reagan |
#28 |
All the gauges
![]() Not sure if you've solved this problem yet but I had a similar issue on the rear of my car. It turned out the shim that goes under the pins was dragging the rotor itself. I'm using OEM rotors. I ended up just grinding the OD of the rotor down a touch until it was no longer a problem.
I do have some squealing from the front now, but only when everything is super hot and only at really low speeds. Normally its fine. I'm on stoptech sport pads with no backing shims.
Kyle and the "Projects" -- '84 242 TI -- '66 220 S -- '89 Supra Turbo -- '84 Rabbit GTI ![]() |
#29 | |
Prius Owner
![]() Join Date: Jul 2008
![]() Quote:
Im having a hard time picturing what you did.
93 245 LS Engine Swap Project |
#30 |
All the gauges
![]() Sorry man didn't read your posts. My current squealing situation sounds similar to what you have, but only under 5 mph or so. I really don't care about it much at that point, its only when hot. I'm not even running shims in the front.
The first issue was on the rear. I could see witness marks on the outside of the rotor where the clip that holds the pads down was dragging. This was causing a squealing noise that went away when I got on the brakes. Again this was only on the rears though. |
#31 | |
Prius Owner
![]() Quote:
#32 |
80/20 speed parts club
![]() Resurrecting from the dead. This is the part you want to make the squeal (really more like the whole car resonating and sounding like a foghorn) go away: 30748514
https://www.fcpeuro.com/products/vol...0-v70-30748514 Ignore the product name on the URL. |
#33 | |
![]() Join Date: Jun 2003
![]() Quote:
#34 | |
![]() Quote:
#35 |
Prius Owner
#36 |
8v are still cool, right?
![]() That's right. You just have to grind a couple reliefs for the bolts.
1982 242 Turbo. |
#37 | |
Dejected by Volvo
![]() Quote:
Dave
![]() '84 242ti, owned since 2003. Always garaged since brand new. Old-school rounds because. B21FT, SDS EFI/IGN, TD04HL-15G, T5Z trans with 0.73 OD, 3.91 diff with unmodified G80. Volvo Seeks Divorce from Volvo Enthusiast Community: www.prancingmoose.com/#novolvo Dave's Volvo Page: www.davebarton.com Alternator Idler Pulley Project: https://forums.turbobricks.com/showthread.php?t=350085 |
#38 | |
![]() Quote:
Edit: tempted to order them myself but not sure the bolt pattern is the same for the caddy calipers. |
#39 |
![]() Found some pictures by searching the part number. So yeah, damper in between bolt and caliper/hub
https://www.drive2.ru/l/10128409/ |
#40 |
Turbo, what?
![]() I don't know anything about a shim that goes between the pad and the pistons on these R calipers. There is no Volvo bulletin for that, the bulletin is for the early cars that didn't have the mass dampers/weights/anti-vibration blocks you see mentioned above.
We had some intermittent issues with this sort of noise complaint even on a stock S60R that had the mass dampers installed. We installed Akebono Ceramic pads and Textar OE replacement rotors then the car developed brake noise(coming from worn Volvo pads and rotors). We switched to Volvo pads but it still made the noise. Then we swapped the Textar rotors out for Brembo OE replacements and the noise went away. Your experience may vary, and to those who have said that shims behind the pads are needed, are you making this up based on your thoughts with another application, or do you have a part number for something Volvo sold to help this situation?
Kyle - NLMGG: '91 244 NA DD/Track - General Leif: '71 142 Endurance Racecar - The General's FB page - Oregon Volvo Tuners - Died ![]() |
#41 | |
![]() Quote:
I just pulled up my VIDA and confirmed there is no shim listed in the brake system for the R calipers. Just those vibration dampers on the back of the caliper. Jordan |
#42 |
Turbo, what?
![]() Thanks for the confirmation, Jordan!
