Old 11-01-2019, 02:33 PM   #26
Minglor
If the combo you're building isn't too crazy I'd encourage you to stick with the stock (GM) pcm. It does a great job and is very easy to tune.
With a stockish swap it'll as simple as sending it out to get flashed, if you don't have access to HPTuners.
The stock harness can be pulled with the motor and the 60e harness can be made to work with the 80e.
If you are going with the cheapest engine you can find it'll probably be a 4.8/5.3.
Those paired with an 80e I'd also be concerned about the length of the first gear and the stock stall.
For cheap as possible - 60es will hold up if kept cool and cam only power.
Minglor is offline   Reply With Quote
Old 11-01-2019, 02:42 PM   #27
propav8r
F*ck Edgar
propav8r's Avatar
So what I'm hearing is you want to buy the 5.3 I have. BTW, it's got a factory ECU and all you need to make the 80E work with it is a harness for the trans and a bit of tuning time.
Originally Posted by Hockey930
Jb welding tiny pieces of a fuse to the injectors seems to have worked perfectly
Originally Posted by Quin
i improved my life by just getting rid of my 940
nipple farts
My Project
K-Jet to Megasquirt Article
Old 11-04-2019, 06:41 PM   #28
vwbusman66
Stößelstange über alles!
vwbusman66's Avatar
You could trade me the wagon for the 142
1971 142 beater/fake racecar
1972 145 sh*t hauler
The incest is implied.
vwbusman66 is online now   Reply With Quote
Old 11-05-2019, 09:46 AM   #29
cosbySweater
cosbySweater's Avatar
If your that cheap, do a 700r4 like Doug said, manual valve body, and a column shifter. BOOMER POI SHIFT
1995 Porsche 993
2013 VW Passat TDI
Old 11-05-2019, 01:09 PM   #30
Lord_Athlon
Chuckie Blows
Lord_Athlon's Avatar
If you want to build it, ****ing build it. Having a thread where you want people to do the leg work for you because you can't afford a microsquirt is insulting.
Yet Asher here went with...
Old 11-06-2019, 11:02 AM   #31
vwbusman66
vwbusman66's Avatar
I’m not asking for leg work, lol.
More so corroboration.
My bad.
Old 12-08-2019, 02:12 PM   #32
dmann
https://www.youtube.com/watch?v=ozbWf_QsPrw
If you want really cheap.
Cracked windshield, Home Depot hardware for switchgear, just all around next level redneck here. Strong work.
dmann is offline   Reply With Quote
Old 12-09-2019, 11:09 AM   #33
vwbusman66
vwbusman66's Avatar
oh damn
Old 12-30-2019, 10:05 PM   #34
superdve
If you are doing any LS swap why not run the factory ECM for the engine and 4L80E? I've been doing this standalone stuff for years like almost 30 years! I know both A340E and 4L80E controls. I run my 2JZ/A340 71' Mopar on Megasquirt with a GPIO. Ask away if you have Q's.
superdve is offline   Reply With Quote
Old 12-30-2019, 10:10 PM   #35
Broke4speed
Broke4speed's Avatar
Scrapyard Scamp? My buddy Danny built the Mutt (69 Valiant w/2JZ/TH400) :D
