#1 |
![]() what's the spec for a 94 940 Turbo? running LH2.4. I hooked my gauge up at the rail and it read ~45psi. seemed to hold for a few minutes after turning off, too. It was a quick read before leaving the shop for the night.
I read on some 'volvo answers' site that that's high, but I figured I'd come to the experts and ask. I have yet to test pressure at the fuel supply line to the main pump. should that spec be the same? what does it mean if my PSI is above/below the spec? I've been getting terrible gas mileage (14-16mpg) so I wonder if she's running rich, but I don't know for sure if that'd be verified with a pressure reading or not. thanks as always yall |
#2 |
![]() I believe thats right on? But Im sure some experts will tune in .
90 Volvo 240-my current setup. B230ft rebuilt -8.8 comp. -Stage 3 rsi cam 3 inch ex.-GTX3076r turbo ballbearing. ebay intercooler-3 inch IC piping- Oil cooler with 10an hose. port stock intake (weak, having a custom intake by viking fab.) Megasquirt 2-1300cc injectors (running E85) 530 head with big valves ported and assemble by culberro sons car- 93 240-15g turbo-chipped-95,000 miles. Slick car Leave feedback- http://forums.turbobricks.com/showthread.php?t=355413 |
#3 |
![]() It should read 45 PSI with the vacuum line disconnected. With the vacuum line connected at idle the gage should read ~ 39 PSI.
#4 |
![]() vac line at the FPR? I had that connected. so... does that mean my FPR is broken?
#5 |
![]() Was the engine running when you took the reading?
#6 |
![]() Yea, engine @ idle in P.
I'll take more thorough, careful readings at both the rail and supply line in the morning to confirm this finding. |
#7 |
![]() That isn’t that far off. I’ve seen that much variation before without problems. Measure the pressure again with the engine idling and the vacuum line off and plugged.
#8 |
![]() My engine was running quite normal with 70 psi fuel pressure. Idle was too fat but surprisingly lambda correct the afr quite well.
#9 |
![]() i think everythings fine. reading this morning was ~41psi @ idle in P with vac line attached, went up to ~50psi without vacuum. held the 41psi for 20+min after turning car off. I couldn't get a read at the valve before the main fuel pump - connected the gauge but it read 0 - but I suspect that valve may be clogged or something. the car has been running mostly fine, in D at idle it can feel rough and vibrate a lot but i think my motor mounts are completely toast.
#10 |
![]() It's fine. I usually see 41-42 PSI at idle with the vacuum line connected. 45 with it disconnected.
Thread Tools | |
Display Modes | |
