1stRavens 1989 740TI - The 700R
Old and new together
kept the old dp so fitted an enlarger into the 3" pipe
Straight pipe to over axel bend
Over axel
Custom Hanger :lol:
last, a video of it. The noise level is too high for the mic but you will get an idea.
http://www.ryanniblett.co.uk/video/new exhaust.avi
A few problems with it.
First, the crossmember below the rear seats is a tad close to the exhaust and it bangs over every bump. I need to find a way of sorting this so if anyone has any ideas.
Second is the back pipe is about 3" too short so is hidden from the back when you look down. Also makes it very noisy in the car
Third is the noise. OMG this is loud. I was going to try it without boxes but I will be ordering one next week to go on the back.
Update
Some genuine polaris came up on ebay but under a strange title. I watched them and in the end, bid and won them!
some pics :
Before :
During:
After :
And the best part, I paid less than ?150 for 5 wheels, 4 of which have almost new tires. :lol: :lol: :lol:
The new parts from Thailand (VBS) arrived this week. I got them sprayed up myself and put them on the car.
New parts
Snow cap
Clear Lenses
Sprayed up the cap and bottom of the lenses. The paint bubbled a bit on the bottom of the lenses but after a few coats, came up fine.
Painted the bulbs to make them amber for legal reasons. These came out way too dark so redid a spare set of bulbs a lot lighter. Didn’t look as good but provide the right colour of light.
The parts installed.
They do look a little strange but I think this is due to how clean they are compared to the rest of the car. They should look fine in a month or so.
and from last weekend
We took a look at the task ahead. Firstly, evidence that the 90+ manifold
has a very small hole in the flange.
We then compared the wastegate housings / turbo outlets. The ATP has such a
massively better flow path for the WG hole [imghttp://www.ryanniblett.co.uk/images/744/blackpool/blackpool_housings.jpg[/img]
The ATP also has a honking huge outlet!
...and the flapper can open a lot further, too.
Since the exhaust side of the head was wide open, it would be rude not to
try out the SSAutocrap header. We noted how it actually leaves the turbo in
quite a sensible location. And how it's held together with lady's welds.
After a combined effort from myself and Mr BB-Q, the 90+ had a T3-flange
sized hole in it.
Shiney! :)
The WG hole on the 'Chinese special' T3/T4 hybrid was TINY given the size of
even the standard flapper, so we set about porting this out too.
Wait...what do you think this is BB-Q, a Turbobricks meet or something?
Ah yes, zipties for teh win!
A slightly more respectably sized WG hole.
The oil drain had to be modified to fit the different spacing created by the
move to the 90+ manifold. We also switched to the Mitsubishi actuator, as
the Garrett one is huge, and makes turbo removal most tricky. However, this
made clearance seriously tight.
After that was all bolted up, it was time to get busy with the MIG
...and some more...
...and some more...
....until we had a very smart looking open downpipe.
The arrangement at the turbo end was super-neat
Close-up:
Old vs new:
New, close-up
The system was re-hung, and after a few tweaks which dictated a second
overnight stop, declared completed. The end result as seen primarily by STI
and Evo owners :rofl:...a very highly polished just-under-3" tailpipe...
Boost control is now solid, and there has been a notable improvement in
performance (quite literally) pound for pound. The DP is virtually a work of
art and thanks again to Mark and family (especially the highly patient
Tina!) for their help and hospitality. Top folk :)
Written by foggyjames
Fitted a set of hova tail lights to the car.
Nb The amber bulbs have been replaced with clear led bulbs just to complete the look.
A bit of an update on the car.
After being off the road for six weeks due to new pas rack being fitted (long story), the car made it to a meet in oxford last weekend. On the way down, it was noticed that while under boost, lots of blue smoke was coming out the exhaust. It made it back (using 4 litres of oil to cover 240 miles) and is now (again!) off the road as we move house.
Plan is to get a 940 lpt block (with 13mm rods and squirters) in, get a t3 and rebuild it, fit my t4 compressor and wheel onto the t3 and put the whole lot in place of the current engine. Should hopefully fix the oil burning issue and the multiple oil leaks that I currently have.
and following on from the last post,
We got the block on monday, and got it onto the stand last nght. I'm planning to start working on it tomorrow but this made change looking at the forecast.
B230FK shortblock. Bores look fine with a very slight lip.
Inlet manifold came with the engine so I managed to get a cruise control throttle spool and 940 tps (if anyone wants one, the tps is for sale)
and summit racing have just delivered the parts for my turbo oil drain (2 sets as BB-Q wants one too)
Just waiting for fcp to delivery their parts now.
and another update, mostly taken from the thread in showroom
531 is off my old car
New block has been cleaned and repainted
Grind out the oil drain hole to ~23mm with a carbide burr, then cut a thread in it with a 3/4" NPT tap.
Fit 3/4" NPT to -10AN male/male coupler.
Add -10AN to -10AN terminated braided hose. (I had to cut this another 3" shorter)
Parts from FCP
Cleaned up 531
Repainted sump and valve cover
B230ET removed
Bonnet Dented :roll:
new seals going in
Waterpump and 531 fitted
the old block - oil leak possible?
New block with manifolds and turbo attached
New engine in place
Just need to put the car together again
yeah, nice one ryan.
Looks like its going to be very quick.
What I/C do you have?
I've just seen how out of date this thread is so time for a big update.
After fitting the engine - it turned out the head bolts were torqued wrong (long story) so one snapped.
Stump came out fine though
After refitting the head, another problem came up - low oil pressure. So, we had to remove the engine again :roll:
had a bit of fun with the engine 2 foot up in the air
In the end, got it all back in. Oil pressure issue was down to the oil filter boss so this was replaced.
The car as it stands now
and it has crossed over into the 200k group
Andy (stuntman on v3m) popped round this weekend to put a tint on my car.
Also, Fordy-88 helped me recover my headliner, fix my sunroof and fit my new pillar pods to the car. (its quite hard to get decent pics of a headliner in a saloon)
