#1 |
Do you have a cobalt?
![]() Join Date: Nov 2005
![]() for my vertical mounted 16v b230, right now its just a b21 for mock up.
droping the pan without droping the x member will be a nice feature. ![]() drivers side going thew a mess of PS and lines, its clears everything perfect though! ![]() passenger side. ![]() the washer and nut are being used as spacers right now, the fatory bolts are to long with the new mounts. they are bolted down tight on a few bolts. it looks like its gona be a fun setup, im ecited!
1983 242dl *6.0 lq4 swaped* Build thread http://forums.turbobricks.com/showthread.php?t=282323 |
#2 |
Sick ****** T-Brick Prick
![]() Wait, are you selling these?
1982 GLT 244 redwood metallic, turbo, lowered...RIP Colonel Mustard: 1979 242DL, B21A, SU carb, M45, GT sways, Limited-slip, rad hubcaps, Manual rack, no ac e-fan Blueberry: 1989 244, dark blue. Ipd everywhere. H-cam. Advance and full retard switches on dash. Galaxy wheels, LSD, other stuff from a bunch of cars on here. |
#3 | |
doing something stupid
![]() i think straight up 16vt will help a lot in the narrow 240 bay, it's how i'd (try) and do it
#4 |
![]() would love to. maybe a set or so dont hound me with pm's people this was a side project i did at school, as is i have very little time if i get time ill try and cut a few extra sets on the water jet. these could also be used in the slanted configuration. just weld the arm at a diffrent angle.
#5 |
Abnormally Aspirated
![]() Lookin' good.
#6 |
![]() I have mocked up and sourced all the parts to do a similar passenger mount.
There is a hole in the pseudo frame rail just above where the k-member. All I can gather is there is indent from a bracket that bolts through the k-member from below and maybe this "hole-window" is for alignment purposes? Does it serve any other function? Can it be covered when making a weld-on bracket without issue? Thanks.
Member: TBCCS "Emancipate yourselves from mental slavery; only ourselves can free our minds" - you know who! "It is no measure of health to be well adjusted to a profoundly sick society" - Jidu Krishnamurti |
#7 | |
![]() Quote:
Thread Tools | |
Display Modes | |
