Old 03-24-2019, 08:20 AM   #51
240wagonguy
The GM DRAC also converts from an analog signal to digital. The Volvo speedo gets the analog input from the sensor directly.
Old 10-28-2019, 09:07 AM   #52
jjona5
Did anyone ever figure this out? I'd also like to keep my ABS in my 93 classic.
jjona5 is offline   Reply With Quote
Old 10-28-2019, 09:25 AM   #53
JohnMc
JohnMc's Avatar
My 8.8 is still sitting in the garage. The Volvo axle hasn't blown up... yet.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 10-28-2019, 09:30 AM   #54
240wagonguy
Seems to me the solution is already in here on page 2. Cut a new reluctor ring or modify the one in the axle, and use the ford abs sensor. Several members reported success.
Old 10-28-2019, 11:01 AM   #55
mikep
The MP
mikep's Avatar
Originally Posted by bobxyz View Post
I looked briefly at the DRAC and I don't think it has enough range to convert from a 8.8 VSS to 240 ABS/Speedo.
The 240 ABS and Speedo expects a 48-tooth ring off the axle. A 205/60R15 tire gets 817 rev/mile. Multiply this by 48 and you get 39216 pulses per mile. The number on the face of the 240 speedo is the calibrated PPM, e.g. 39200.
If I understand correctly, the 8.8 is normally a 40-tooth sensor off of the driveshaft. With a 3.73 diff, and the same tire as above, this results in 817 * 3.73 * 40 = 121896 PPM, or roughly a 3x higher rate than what the 240 ABS/speedo needs.
The DRAC is a PLL based frequency converter. From the "input ratio" charts, it can rescale with a frequency multiplier of 0.5 to 2.0, based on the jumper settings. This isn't enough range -- the 240 speedo would need an "input ratio" of 3.0. This is off the charts of the available jumper settings.
I usually see a sensor above and behind the pinion flange, but reading the tone ring next to the ring gear. Usually 108 teeth.
(on explorers)
Old 10-28-2019, 11:19 AM   #56
jjona5
I read that it was bouncy. I would imagine that would cause the ABS unit some issues.
Old 10-28-2019, 12:46 PM   #57
240wagonguy
Likely because of unevenly spaced teeth, 130/48 means you cut off every 2.7 tooth on the wheel. Obviously not gonna work well. Best to fab a new wheel with 48 evenly spaced teeth.
Could also cut a wheel that bolts onto the driveshaft flange. You'd have to divide 48/ the gear ratio to get the correct teeth, and make a bracket to hold the volvo speed sensor.
I'm just throwing out ideas I've had recently to get the speedometer working in my welded diff car thats missing the tone wheel. I was gonna try to run it off a front ABS sensor but obviously your ABS would have to be decommissioned, mine already has been.
Old 10-28-2019, 03:10 PM   #58
mikep
The MP
mikep's Avatar
I just counted 3 tone rings on 8.8 explorer/mountaineer diffs. two had 4-link, one had leaf springs.
108 teeth, 8.3"-ish" dia.
The ones with low tooth count are usually mounted at the hub or outer axle, 3.6-4.5".
https://www.yukongear.com/partslist....gs+%26+Sensors
Old 10-28-2019, 11:06 PM   #59
jjona5
I emailed a couple places about custom tone rings.
Old 10-29-2019, 07:07 AM   #60
JohnMc
JohnMc's Avatar
If it helps the price, I will get one.
Old 10-29-2019, 09:16 AM   #61
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
I'll try and keep tabs on this, I'm in for 2 I reckon
Megasquirt Tuning!
Old 10-29-2019, 10:14 AM   #62
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Same here. If its a reasonable price I'd be interested in getting a good speed reading from the rear diff so I can possibly use it for a traction control system and front ABS strut.
Current setup - Aluminum L33/Summit Turbo Stage 2, single Walbro 450 and Dual AEM 400's, Bosch 210's
3060lb no driver
3240lb with driver
Old 11-10-2019, 07:37 PM   #63
jjona5
emailed a few places. need to get an 8.8 tone ring to send them.
Old 11-10-2019, 09:29 PM   #64
Forg
Forg's Avatar
Is there a reason you can't use an electronic pulse-counting converter, is the signal more complicated than simple pulses?
Officially more comely than Paul Buck.
When I'm cruisin' in overdrive ...
Don't have to listen to no run-of-the-mill talk jive.
Shatner: The Colonel is breakdancing ... gimme a break!!
Rollins: Credit terms raised!
Shatner: I can't get behind any of that!
Shatner: I can't get behind so-called singers that can't carry a tune, get paid for talking, how easy is that? Well, maybe I could get behind that ...
Rollins: Well, I can't!!
Forg is offline   Reply With Quote
Old 11-13-2019, 03:41 AM   #65
DrZiplok
DrZiplok's Avatar
Let us know if anyone seems sane; been buying from reluctorrings.com in the UK. Quality product, but not cheap, and even less so with shipping to California.
DrZiplok is offline   Reply With Quote
Old 11-13-2019, 03:43 AM   #66
DrZiplok
DrZiplok's Avatar
It becomes quite ... exciting keeping the output duty cycle right, especially if you're trying to make an ABS system happy.
Old 11-14-2019, 08:56 AM   #67
jjona5
I wonder if we could just do the math and get a rear tire that is 2.08 percent larger than the front and call it a day 49 vs 48 tooth.
Old 11-20-2019, 10:35 PM   #68
mikep
The MP
mikep's Avatar
Where am i mailing this tone ring?
