Old 10-17-2019, 03:09 PM   #1
S70T5fivespeed
S70T5fivespeed's Avatar
Default Faulty gauges 91 740
I’ve seen bits and pieces of info on some recent threads here, as well as thru googles. Looking for current knowledge on the subject. Appreciate the help.
Have a 91 740 factory turbo with what seems like a failing cluster. First the gas gauge went limpy (like showing 10% on 90%) then just gave up, so I was using the trip odo for gas, but now Speedo has gone dead so no odo/trip odo or speed.
I know people say the 91/92 clusters are just bad, and I think others have said you can swap up to a better cluster (94/95 940?) so wondering what the best course is in this instance.
Also would the newer clusters match visually and feature a turbo gauge (I know these gauges are mostly useless but trying to keep this as oe as possible)
Otherwise is it possible to fix this one and perhaps make it stronger than original? Would be sending out to fix so not sure if costs on that would make it a poor choice.
Thanks
99 S70T5M black on graphite suede
91 740SE white on black
90 740TI oe aero kit black
In the barn: 67 123GT
S70T5fivespeed is offline   Reply With Quote
Old 10-17-2019, 03:51 PM   #2
nordmaschine
forced instruction
nordmaschine's Avatar
First thing, take it out and reflow all the solder joints on the back. See where that gets you.
As far as 940 clusters go, they don't phisically fit, unless you swap the entire dashboard. Which is a straight fit, though it's going to take you a better part of a day, IF you know what you're doing.
Then it's onto pulling pins out of 740 plugs and into 940 plugs, since 740 and 940 clusters are wired differently. Plugs are great though, you don't neex any special tools to de/re-pin them, just both diagrams and go one wire at a time, because there are a couple of the same color...
As for making it stronger, what's the point? They lasted 25+ years before starting to fail, reflow gets them probably another 10, then some capacitors die, then you redo them and reflow it again, that's another 20-ish years. Are you going to drive it that long?
Jetronic is romantic.
Whiteblocks
Old 10-17-2019, 04:22 PM   #3
S70T5fivespeed
Thanks Nord. That’s interesting you mention the 940 dash re: cluster. I thought the 940 dash was the same as the later 740 one, and have a replacement from a 940 I was planning to eventually put in.
As for driving this car ideally as long as possible.
Old 10-17-2019, 08:50 PM   #4
2turbotoys
Have you seen me?
2turbotoys's Avatar
I had my 91 740T cluster repaired by DNA Speedometers, it worked perfectly after that. That's actually the second time I typed that tonight haha
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 10-17-2019, 09:02 PM   #5
S70T5fivespeed
Thanks 2TT. Can I ask what something like that would cost?
Old 10-17-2019, 09:24 PM   #6
2turbotoys
Have you seen me?
2turbotoys's Avatar
I believe it was about $300, I would have to find the receipt. This cluster used to be on their site with a price, it looks like the site has been redone and I couldn't find it easily. Their communication was very good however, and asking is always free haha.
https://dnaspeedometers.com/
Old 10-17-2019, 09:31 PM   #7
S70T5fivespeed
Yes thanks for the lead will def request a quote, no worries on hunting a receipt.
Thank you!
Old 10-17-2019, 09:37 PM   #8
2turbotoys
Have you seen me?
2turbotoys's Avatar
No problem, I searched for a long time for a good used one, with no luck. I did read (while waiting for it to return to me) that since it is a 1 or 2 year only gauge the main difference was the gas gauge or something, most everything else is the same as a regular 740T gauge, but that was a very deep internet rabbit hole that I can't retrace.
It took a couple weeks to get it back, I drove around with my phone in the cluster hole with a GPS speedometer app during that time lol. Unfortunately I sold that cluster about 6 months ago, to a guy who was really bitter about paying me $200 or so for it.
Old 10-17-2019, 10:08 PM   #9
S70T5fivespeed
From what I’ve read about the 91/92 clusters figure better to fix than to swap anyway since most seem to fail.
But now I’m curious about this whole 7/9 dash fit issue, as I have a nice 9 dash I was hoping to put in my 91 740 with the oe 7 series trap cluster.
Old 10-17-2019, 10:15 PM   #10
2turbotoys
Have you seen me?
2turbotoys's Avatar
Very true. I didn't regret fixing it. Good luck whichever path you take!
Old 10-18-2019, 02:44 AM   #11
nordmaschine
forced instruction
I don't know, maybe US late model 740's god 940 dash from the factory?
Anyway, 740 cluster:
940 cluster:
There's the difference in size and shape, thus requiring corresponding dashboard.
Old 10-18-2019, 02:59 AM   #12
MasterBlaster
Yup...
And 91 740 owner's manual:
https://volvornt.harte-hanks.com/man...740_01.htm#ch1
496,000 km so far...
Old 10-18-2019, 02:59 PM   #13
S70T5fivespeed
Thanks MB that pic shows the one I’m working with (the 91-92)
Old 10-18-2019, 05:56 PM   #14
redblockpowered
redblockpowered's Avatar
I have a 1990 760 Turbo cluster that... might work? And definitely could be yours. It's the trapezoidal style, with 120 mph speedo.
1991 245 B230FNA/M47 no thread: secret LeMons car technology abounds
1991 245 B230F/M47 no thread: very boring (330k!)
Old 10-18-2019, 08:27 PM   #15
S70T5fivespeed
Thanks RBP I think the clusters are pretty specific tho, 90 760 no workie with 91 740
Old 10-18-2019, 09:00 PM   #16
redblockpowered
That's what I thought too. Oh well. I can take a picture of the circuit board if you want to play spot the difference but I think you're right.
