Old 11-05-2019, 12:19 PM   #1
Chuck W
Chuck W's Avatar
Default Whiteblock into a 240 - Engine Management?
As I've committed to swapping a whiteblock 5-cyl into my 240, I'm left with trying to decide what ECU to use for the project.
The shortlist of possibles are:
-MS3
-MaxxECU
-Flashable M4.4 Motronic
I'm intending to do COP and utilize the ExVVT set-up on the engine I have.
I've messed with older MS stuff on a couple of projects and have begin to dabble in the M4.4 tuning on our 850's. I'm no expert though.
Are either of the non-OE ECUs a better choice for the 5-cyl? Been starting to dig through documentation on them, but haven't been swayed one way or the other.
Trying to keep costs reasonable, but I understand that this will most likely be one of the more pricey components of the project.
Thoughts?
'78 264GLE
'97 854 T5 (Eventually to be 5spd)
'80 264GLE (B21FT/M46/MS) - SOLD '77 242DL (B21F/M45) - SOLD '75 245DL SOLD '85 244GLT DEAD
'83 Tbird Turbo (2.3T/T5/MegaSquirt)
My feedback thread
Chuck W is offline   Reply With Quote
Old 11-05-2019, 08:28 PM   #2
Dirty Rick
Dirty Rick's Avatar
MS3 would be my choice.
Old 11-05-2019, 08:29 PM   #3
doucheNozzle
doucheNozzle's Avatar
Everybody swears by the MaxxECU stuff for the white blocks.
However, people are making damn good power with the help of Aaron at VAST. The nice thing about a tuned 4.4 ECU is that you don't have to do any of the warm up ****.
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 11-05-2019, 10:13 PM   #4
Chuck W
Chuck W's Avatar
Yeah, I recently got stuff set-up to be able to flash/tune the M4.4 stuff, and have messed around with things a little bit, and not having to deal with the fiddly bits would be nice. The learning curve on tuning that set-up is a bit steeper, though.
Old 11-05-2019, 10:40 PM   #5
doucheNozzle
Just have Aaron tune it for you?
Old 11-06-2019, 12:23 AM   #6
Chuck W
Chuck W's Avatar
That's always an option, but digging in and learning is all part of the fun.
Old 11-07-2019, 01:21 PM   #7
Chuck W
Chuck W's Avatar
Maybe I'm missing it somewhere, but does MS3 support e-throttle?
Just an option I'm toying with.
Old 11-07-2019, 01:28 PM   #8
oldschoolvolvo
oldschoolvolvo's Avatar
Here's another thread worth reading
https://forums.tbforums.com/showthread.php?t=301865
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 11-07-2019, 01:46 PM   #9
Chuck W
Chuck W's Avatar
The only thing that is turning me away from using the M4.4 ECUs I have is the fact that they are 20-year-old electronics.
I did more digging, and MS doesn't support e-throttle. At least not "officially".
Old 11-08-2019, 12:05 AM   #10
Alex Buchka
8 cylinders
Alex Buchka's Avatar
I've had a few different ecu's on my whiteblock swapped 240. Started with a megasquirt and moved on to a few different flavors of Link G4+. Right now I'm running a G4+ Extreme and I'm fairly happy with it. My turbo+ITB setup is kinda quirky and there are a few things I wish it would do better but my only option for improvement at this stage is a Motec or a Life Racing ($$$$) so it'll stay on the car for now.
At the end of the day I think it's basically a toss-up between Link, MS3, and MaxxECU. They are pretty competitive on price, features, and flexibility. You'll be happy with any of them to be honest. I'm personally not a big fan of MS3, mostly due to the lack of E-throttle support.
Old 11-11-2019, 04:15 PM   #11
stick70
All the gauges
stick70's Avatar
I'm on a MS3Pro here, don't have anything bad to say about it.
Old 11-12-2019, 11:16 AM   #12
Chuck W
Chuck W's Avatar
Thanks for the input, guys.
I think I'm leaning towards the MaxxECU set-up, as I'm kind of liking the option to do the e-throttle.
Old 11-12-2019, 02:31 PM   #13
GTJordan
Been here for too long
GTJordan's Avatar
I'm also 90% decided this is the route I'm going on my 16V Turbo.
Jordan
Old 11-13-2019, 08:55 AM   #14
Chuck W
Chuck W's Avatar
I guess staying on the e-throttle discussion.
I've seen a couple builds using MaxxECU that are using the throttle body from a P2 S60/V70 (0-5V signal with a PWM back-up). I didn't see much on the pedals, but I'm imagining some hybrid of the 240 and P2 set-up.
Old 11-13-2019, 05:14 PM   #15
Alex Buchka
8 cylinders
Here's a picture of the setup I'm running mocked up on the bench.
It's an E-class benz pedal position sensor made to interface with a cable. The sensor has two 0-5v outputs that are compatible with pretty much any ECU. Just mounted it underneath the brake master and joined it to the stock throttle cable. Way easier than digging around under the dash.
https://www.fcpeuro.com/products/mer...sor-0125423317
I bought it used on ebay with a bracket, stump of throttle cable, and a cut harness for something like $65.
Old 11-13-2019, 05:26 PM   #16
RvolvoR
cough
https://www.maxxecu.com/products/ter...rness/volvo_t5
Old 11-14-2019, 02:06 AM   #17
Chuck W
Chuck W's Avatar
That might be an option, if it works with the SPORT version of the ECU.
http://www.maxxecu.com/webhelp/wirin...-volvo_t5.html
Old 11-14-2019, 02:22 AM   #18
RvolvoR
It should, as the main plug on their ECUs are all the same, iirc. It is the second or third plug which adds a bunch more stuff on the race and pro versions.
Old 11-14-2019, 09:04 AM   #19
Chuck W
Chuck W's Avatar
Interesting.
I'll be swapping the pedal assy anyway, seeing as the car is originally a manual, so I'll be mucking about under the dash with mods for the hydro clutch set-up, so it might not be too terrible to make any changes to accommodate a pedal sensor. This would save one bit of mods, I suppose.
