Sketchysedan
- Feb 20, 2019
Just had the engine from my ?95 t-5r out for a manual swap. Prior to the swap it had no coolant issues at all. When I put the engine back in, at first I had a minor coolant leak which I have since fixed. The coolant reservoir boils over if I let the car idle too long. Always happens when coolant temp is 205-210 degrees, can?t tell if the fan will come on or not because it won?t get hot enough before it boils over. I have used block tester and there are no combustion gasses in the coolant. I noticed the old green cap was very cracked so I replaced, the new cap is gray and 125 kpa vs the green being 150 kpa. Any suggestions? If I?m moving, car fluctuates between 145 and around 190, only when I stop does the temp go up and it boils over. Any suggestions?
