Old 11-11-2020, 09:35 PM   #1
Jack
junkman
Jack's Avatar
Default 50mm readily available side drafts ?
Going to need a massive amount air going into a 16v head
Looking for any recommendations for 50mm side draft carbs that you can get ďcheapĒ
I know harleys have some big carbs but thatís as fas as my knowledge goes
Will make a custom intake etc
Thanks
I love you even more Jack.
Donít bother, I would literally rather throw them away than give you the pleasure. I will never sell to you.
Old 11-11-2020, 09:45 PM   #2
SU HS8 are 2" and used with some pretty big Healey and Jaguar engines. If I recall correctly Mike Jr or Mike Sr in their project 122 thread had aftermarket Weber clones. They may be available in 50mm.
Old 11-11-2020, 09:53 PM   #3
Broke4speed
Broke4speed's Avatar
The chinese Weber clones are available in 50mm.
1984 244/ AQ140A / M46
Old 11-11-2020, 10:02 PM   #4
Jack
junkman
Jack's Avatar
I thought of those but looking for more modern stuff
Keep the suggestions coming
Found some common mikumis but they’re are 46s I think which still isn’t big enough.
Old 11-11-2020, 10:02 PM   #5
Jack
junkman
Jack's Avatar
Yeah but Webers get choked up so itís not really a 50
Old 11-11-2020, 10:39 PM   #6
Broke4speed
What kind of 16v engine would need more air than a set of quad 50mm DCOEs could provide, even choked down to 46mm? Not trying to be a jerk, genuinely curious .
Old 11-11-2020, 10:45 PM   #7
Jack
junkman
Jack's Avatar
I’ll post specs when it’s all done
Doing port work (especially on intake- sloppy casting and room for better flow) and larger valves on intake and exhaust
There’s got to be something more modern Webers
Old 11-11-2020, 11:00 PM   #8
fatcatbestcat
Professional Hack
fatcatbestcat's Avatar
If you're going through all this trouble with a mega-ported head, why not just run EFI? I'm almost certain you could find some 50+mm ITB throttle bodies that won't be as much a restriction as all the internals of a carb.
If you happen to have a metric '67-'72 140/160 gauge cluster, please do PM me.
Will you do $14.99 shipped?
Old 11-11-2020, 11:21 PM   #9
Jack
junkman
Jack's Avatar
Because I really donít want to efi an amazon
50mm TBs are something Iím thinking of for another car
(I have a few 16v and even more Volvos)
Looking at 55 Webers ... ugh
Vergaser 46s are huge money and still a bit too small
Old 11-12-2020, 01:07 AM   #10
The Librarian
Go big or go home.
https://classicperformance-parts.com...n-carburetors/
If that's not in the budget you can get FAJS 55 DCOE's cheap.
https://www.alibaba.com/product-deta...346c65cainfm3X
Old 11-12-2020, 01:14 AM   #11
Jack
junkman
Jack's Avatar
Go big or go home.
if I start saving now I should be able to buy them in 200 years
whats the deal with solex sidedrafts
volvo used them on their race 16v but they seem to go for cheap?
Old 11-12-2020, 01:23 AM   #12
The Librarian
Yes they did. These have a tag that says "VOLVO 16 VALVES " on them but they're only 48's.
Where do find you them cheap? It could be because calibrated parts are hard to find.
Old 11-12-2020, 01:40 AM   #13
Jack
junkman
Jack's Avatar
there's few on ebay
call me and lets talk about those ;)
Old 11-13-2020, 11:03 AM   #14
Jussi Alanko
Here in Finland we use those Chinese Fajs carburators in "Folkraces"!
And there are good at least in WOT conditions!
Jussi Alanko is offline   Reply With Quote
Old 11-13-2020, 04:50 PM   #15
fatcatbestcat
Professional Hack
They're similar in function to the Weber DCO/Es, but use many completely different components that don't interchange. I tried to save a few bucks buying a set of DDH 40s, and found out the hard way that replacement parts for the Solexes are hard to come by.
Also I think Solex used zinc bodies, instead of aluminum?
Old 11-13-2020, 06:41 PM   #16
Avtovaz
If the reason you dont want to go efi is looks, convert a carb to efi? there is some good kits out there for like Su;s and the big ones are usually cheep.
Avtovaz is offline   Reply With Quote
Old 11-13-2020, 06:49 PM   #17
fatcatbestcat
Professional Hack
EFI is probably going to be cheaper and easier to find than 55-sized DCOE carbs.
You could try a high CFM 4-barrel, but I'm not sure airflow would be your friend with a setup like that.
Old 11-14-2020, 10:00 AM   #18
Jussi Alanko
Here is 55mm Fajs, they are good carbs for their price.
https://www.ebay.com/itm/FAJS-55DCOE...AAAOSwPaddEeno
Old 11-14-2020, 02:18 PM   #19
Jack
junkman
Jack's Avatar
Not for looks, just something I want to do with a 16v
The Chinese Webers seem nice but arenít that much cheaper than 50/55 Webers
Once the headwork is done Iíll flow the head and find out exactly what I need
Independent throttle efi 16v is going on a different car
Old 11-17-2020, 02:43 PM   #20
cosbySweater
cosbySweater's Avatar
http://www.forums.turbobricks.com/sh...d.php?t=357576
1984 Volvo 245
1995 Porsche 993
2013 VW Passat TDI
