junkman
![]() Going to need a massive amount air going into a 16v head
Looking for any recommendations for 50mm side draft carbs that you can get “cheap” I know harleys have some big carbs but that’s as fas as my knowledge goes Will make a custom intake etc Thanks |
![]() SU HS8 are 2" and used with some pretty big Healey and Jaguar engines. If I recall correctly Mike Jr or Mike Sr in their project 122 thread had aftermarket Weber clones. They may be available in 50mm.
Dave, 1982 242 turbo. 338k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration. 1993 245 Classic, 430k miles, enem V15. IPD bars and chassis braces. Simons sport exhaust from Scandix. sbabbs ezk chip. Been a good road warrior. Genuine Volvo rebuilt leaky M47. ![]() |
![]() The chinese Weber clones are available in 50mm.
1984 244/ AQ140A / M46 |
#4 | |
junkman
![]() Quote:
Keep the suggestions coming Found some common mikumis but they’re are 46s I think which still isn’t big enough. |
#5 |
junkman
#6 |
![]() What kind of 16v engine would need more air than a set of quad 50mm DCOEs could provide, even choked down to 46mm? Not trying to be a jerk, genuinely curious
#7 | |
junkman
![]() Quote:
Doing port work (especially on intake- sloppy casting and room for better flow) and larger valves on intake and exhaust There’s got to be something more modern Webers Last edited by Jack; 11-11-2020 at 10:58 PM.. |
#8 |
Professional Hack
![]() If you're going through all this trouble with a mega-ported head, why not just run EFI? I'm almost certain you could find some 50+mm ITB throttle bodies that won't be as much a restriction as all the internals of a carb.
Doing the wrong thing the right way. If you happen to have a metric '67-'72 140/160 gauge cluster, please do PM me. |
#9 | |
junkman
![]() Quote:
50mm TBs are something I’m thinking of for another car (I have a few 16v and even more Volvos) Looking at 55 Webers ... ugh Vergaser 46s are huge money and still a bit too small |
#10 |
The Librarian
![]() Go big or go home.
https://classicperformance-parts.com...n-carburetors/ If that's not in the budget you can get FAJS 55 DCOE's cheap. https://www.alibaba.com/product-deta...346c65cainfm3X |
#11 | |
junkman
![]() Quote:
whats the deal with solex sidedrafts volvo used them on their race 16v but they seem to go for cheap? |
#12 |
The Librarian
![]() Yes they did. These have a tag that says "VOLVO 16 VALVES " on them but they're only 48's.
![]() Where do find you them cheap? It could be because calibrated parts are hard to find. Last edited by hiperfauto; 11-12-2020 at 01:38 AM.. |
#13 |
junkman
![]() there's few on ebay
call me and lets talk about those ;) |
#14 |
![]() Here in Finland we use those Chinese Fajs carburators in "Folkraces"!
And there are good at least in WOT conditions! |
#15 |
Professional Hack
![]() They're similar in function to the Weber DCO/Es, but use many completely different components that don't interchange. I tried to save a few bucks buying a set of DDH 40s, and found out the hard way that replacement parts for the Solexes are hard to come by.
Also I think Solex used zinc bodies, instead of aluminum? |
#16 |
![]() If the reason you dont want to go efi is looks, convert a carb to efi? there is some good kits out there for like Su;s and the big ones are usually cheep.
#17 | |
Professional Hack
![]() Quote:
You could try a high CFM 4-barrel, but I'm not sure airflow would be your friend with a setup like that. |
#18 |
![]() Here is 55mm Fajs, they are good carbs for their price.
https://www.ebay.com/itm/FAJS-55DCOE...AAAOSwPaddEeno |
#19 | |
junkman
![]() Quote:
The Chinese Webers seem nice but aren’t that much cheaper than 50/55 Webers Once the headwork is done I’ll flow the head and find out exactly what I need Independent throttle efi 16v is going on a different car |
#20 |
![]() Join Date: Jul 2009
1974 AMC Gremlin, lq4, 7875 billet, ss2 cam, 80e, 3600 stall converter, Holley Terminator x 1984 Volvo 245 1995 Porsche 993 2013 VW Passat TDI |
