StreetForged
- May 24, 2018
I've had BC coilovers for a while now, and it was a nightmare to get the rear end to ride properly. The car has a pretty big rake, because the car literally bounces like a trampoline if the rear struts are bottomed out or the dampening setting is below 25/30 clicks. Intuitively, it seems like the lower you adjust the strut, the more preload would be placed on the rear spring, as it sits at a further pivot point behind the strut itself. I had to adjust it 4 times to get it to the best compromise of ride height and being able to hit bumps without bouncing or hearing knocking sounds on rebound (likely the strut topping out due to the ridiculous rate and preload)
BC only sells the kit with 6k 6k front and rear, which is a really bad design choice, due to wanting a lower rate on the end of the car that has less weight. The rears are a V-barrel design, so its very hard to find replacement springs for the car. I want a spring that's about an inch shorter, and somewhere around 5k rate. Is there any place anyone is aware of that would sell something like that at an affordable price?
This has had me thinking about heating the top coils on the springs to drop the car about half an inch to an inch, also dropping the rate and stopping the preload issue in the meantime while I try to find a better way of solving this problem. I was also considering cutting a coil off, but I don't like the idea of having a sharp, angled spring end that won't seat properly on the frame. The 240 coilover kit was definitely an afterthought that went through very little to no testing when it was made, and it's really disappointing to even be considering these hacky solutions so my car both looks and rides right.
