Finally ready for some belated updates.
I spent some time on Monday wiring up another relay for the e-fan. First, the e-fan is fused. Second, Now I can control the fan from inside with the A/C switch.
And since the switch is powered by ignition w/ a 5 sec delay, I can just leave the switch on and the fan turns on automatically.
When the key shuts off, the fan shuts off. I also wired the high speed through the temp sensor on the radiator, but it's stuck closed currently, so the high speed stays on. Have that disconnected till I get a new temp sensor.
I also pounded and reshaped the stock AMM bracket to re-mount the AMM.
Then I borrowed the washer system from the 940 so I could wash my windows. The 940 wont be going anywhere for a while.
I also took time to install the cruise control kit I pieced together from 3 junkyard cars.
One was an automatic, one was a manual but older car, and only the third car had the turn signal stalk.
Buchka's triple blink doesn't work with the one of these, but I can't remember which.
Another shot
And the cruise box.
I have a valve from grainger sitting in the vice witha vac nipple being set by epoxy waiting to replace the cheapo ebay MBC.
Overall, the car's been a blast to drive.
The exhaust guys ran the downpipe too shallow, so the old exhaust now bangs/rubs on the tranny crossmember. That's annoying as hell.
But not as annoying as new hole blown into the old muffler by a turbo exhaust.
2nd gear in the m47 is rough. Once in second, the boost is fun.
