Old 07-21-2008, 11:02 PM   #1
Jerd
Jerd's Avatar
Default 3rd mount engine brace awesomeness [pics*video]
Dont make fun of my welds. They have a **** load of penetration and will never brake so suck my titties if you care so much about the look of them to dis the coolness.
Yes i went around back to show you my K-cam open exhaust awesomeness numero dos
Old 07-21-2008, 11:26 PM   #2
pooprah
Guest
nice!
Old 07-21-2008, 11:52 PM   #3
Thor
Thor's Avatar
Nicely done. Rubber or polly bushings?
1991 240 M-47 daily driver
Build thread: 91 240
Feed back: Here
Thor is offline   Reply With Quote
Old 07-22-2008, 12:12 AM   #4
Jerd
Jerd's Avatar
Rubber but the little steel tubes that go through them have perforated edges and when you tighten it down they dig into the steel.
So it doesn't really move at all side to side but some up and down.
Old 07-22-2008, 12:13 AM   #5
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
Nice work, I suppose that will be somewhat in the way if you ever go turbo though eh?
-Kenny
Old 07-22-2008, 12:16 AM   #6
Jerd
Jerd's Avatar
actually it shouldn't be.
boost line should go above it and intake should go under it.
If it is in the way then i will defiantly be cutting out the bottom bracket and will move it. .
Old 07-22-2008, 06:20 AM   #7
Crazychopstick
(/// _ - )
Crazychopstick's Avatar
Location: Receiving Transmission from David Bowie nipple antenna
Pretty cool. I want to make one out of my old panhard rod.
I wonder if there is any benefit to having an adjustable third mount as opposed to a solid one?
Crazychopstick is offline   Reply With Quote
Old 07-22-2008, 02:42 PM   #8
GhengisKhan
That exhaust is so F-ing hot, so all you have is a K cam? (almost the same as the iPd right?) What have you done with the exhaust? Chopped the Cat off?
GhengisKhan is offline   Reply With Quote
Old 07-22-2008, 02:51 PM   #9
DaButcher
Do a Burnout!
DaButcher's Avatar
Poly melts (been there - done that).
The OEM rubber will deteriorate, but it will last almost one year.
DaButcher is offline   Reply With Quote
Old 07-22-2008, 04:51 PM   #10
Jerd
Jerd's Avatar
k cam and ipd cam are similar but not the same.
K-cam Ipd adjustable gear custom intake exhaust is cut after the cat and has a homemade tip. for now, i will be putting a real exhaust on later.
Other than that its stock.
Old 07-22-2008, 10:12 PM   #11
2fast242gt
Do you have a cobalt?
doesnt look like lots-o-penitration. look to gobular to have great penitration. cool design though.
1983 242dl
*6.0 lq4 swaped* Build thread
Old 07-22-2008, 10:20 PM   #12
Josepilove
sounds like you were tap dancing...nice work.
Josepilove is offline   Reply With Quote
Old 07-22-2008, 10:32 PM   #13
RedFridge
RedFridge's Avatar
HA! Been there done dat video?
What the F..k was THAT man?
You crazy mo fo.
Oh..nice brace. Wanna lick your welds you welder you.
RedFridge is offline   Reply With Quote
Old 07-22-2008, 11:45 PM   #14
Mueller
Mueller's Avatar
You crazy mo fo.
ditto....glad my wife didn't walk in the office with that playing, she would have thought I "switched sides" and was playing for the other team
as for those bubble gum looking welds, they make grinders for a reason
looks good other wise.....I would have gone with tubing instead of solid bar stock, save some weight and you'd never know the differance in strength.....
Old 07-23-2008, 12:18 AM   #15
Jerd
Jerd's Avatar
Lol i know. oh well.
its 1/4" thick tubing lololol
