Old 10-17-2011, 09:20 AM   #1
Josepilove
Default 2 years old gas bad?
I forgot that i had 10 gallons of gas in my 245 when i put her up on jackstands 2 years ago to do a b230t swap. so now everything is together and it cranks, gets spark and i have double checked the timing, but no go.
Could it be bad gas?
Josepilove is offline   Reply With Quote
Old 10-17-2011, 09:37 AM   #2
billkaz
Bomber Dream
billkaz's Avatar
I parked my 96 Saturn with 1/2 a tank of gas for just about 2 years. A bit hard starting, but once it caught, ran just fine.
1992 240 Wagon
2006 Mazda6 Wagon
billkaz is offline   Reply With Quote
Old 10-17-2011, 09:44 AM   #3
15A
World's Oldest Brewery
15A's Avatar
I had a tank of 4 yr old gas that was hard starting. I got a couple of large bottles of 90% + isopropyl alcohol and dumped it in - along with a 2-5gal can of fresh premium. It did start - stunk and the exhaust was white for about 3-5min, then she ran like a gem.
(IF YOU WANT ME TO LEAVE YOU FB AFTER THE FACT, JUST SAY)
Alcohol does not solve any problem, but then again, neither does milk
15A is offline   Reply With Quote
Old 10-17-2011, 11:34 AM   #4
The Spirit Of Rolling
Volvos, VWs, & NO Vagina
The Spirit Of Rolling's Avatar
The gas available for the last few years tends to separate, esp. if it has ethanol in it. Therefore, no telling what sort of fuel you would be getting at the outlet of the tank; rest assured, it won't be the right octane. I haven't had trouble getting a few cars started that have sat for a year or a bit over, but I am not anxious to try for much older than that.
I'd always recommend adding as much premium as you can to get rid of the old fuel at the same time.
An appreciative user of the Kinder, GentlerTurbobricks (TM)
'86 245 GL A/T- DeCarbons, BF Goodrich's, and Uro suspension bushings, woohoo!
'83 VW GTI, '83 300TD
The Spirit Of Rolling is offline   Reply With Quote
Old 10-17-2011, 11:44 AM   #5
Derp
Old 10-17-2011, 12:00 PM   #6
John V, outside agitator
Depending on where you are the gas can turn to turpentine and piss in as little as 7-8 months. There is a drain on the tank pretty sure. Get some fresh gas in there.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 10-17-2011, 12:54 PM   #7
2manyturbos
^^ This. I made the mistake of running the gas out of a car that had sat in the auction for just over a year. It ran crappy and made my eyes sting if I went anywhere near it while it was running. The next day, I went to start it after putting fresh gas in it. It wouldn't start and cranked way to fast. Broke the timing belt. The reason it broke the timing belt is two intake valves had stuck to their quides. I ended up having to replace the head. Even with a hammer and punch, I couldn't budge the valves. They were pulling the quide out of the head as they came out. The cylinders were like super sticky fly paper. It took quite awhile to get all the "Super glue" off the cylinder walls and tops of the pistons. I will never make the same mistake againg. Do not run old gas through the engine, drain it.
Old 10-17-2011, 02:35 PM   #8
winglet
YES.
I just wasted an hour trying to start a lawnmower that had sat for a couple of years. Drained the tank and the carb, refilled with fresh gas and it started on the first pull....
My 745ti has been sitting for 5+ years. I'm just hoping when I drain the tank that it will still burn....
winglet is offline   Reply With Quote
