I sent fige a PM about buying his alternator bracket, but haven't got a response. I'd like to spend as little money as possible before I get it running and driving so I can get a better idea of where my money should go first. I have a brand new generator sitting in the trunk so I'd like to try that out first. I need to go to a parts store today and buy a bigger socket for the nut on the pulley.
Before you bloody those other three knuckles make sure the "new" generator mounts up exactly the same as the near-destroyed one including pulley alignment and angle.
You can struggle or you can re-mount the old generator in the car and follow these instructions...
I was able to get the stuck fan nut off without the holding tool using a rather unconventional means. Soak the nut overnight with penetrate then heat with a torch if available. I used a plastic coated dog tie out cable to do it. First, since I was replacing the fan belt anyway, I cut the old one off to get it out of the way. Next I looped the dog leash around the AC bracket compressor was removed at the time, then looped it around the fan pulley and turned the pulley until the cable wrapped over itself and began to pull tight. Next I used a very long and large ratcheting breaker bar to take up the cable slack until the pulley would not turn any more. Then kept applying gradual force to the wrench, watching the cable and alternator mount to make sure nothing was bending. After a bit, the nut broke loose, and there you have it.
If the dog won't share his vinyl-coated steel cable any very strong section of rope will work.
If re-mounting the old generator seems like too much work just rope-tie two 2X4 studs together (faces facing) about 3 feet from one end then use the other ends as giant pliers.
Any local auto alternator shop will remove the nut for free...
You: "The last four alternator shops couldn't get this nut off and they all said I'd be wasting my time coming here..."
Shop: "Gimme that thing...".
Steering wheel removal...
http://forums.swedespeed.com/showthread.php?115471-Steering-wheel-and-dash
http://www.brickboard.com/RWD/index.htm?id=750608&show_all=1
As you see, your model Volvo is fully supported on the www.
BTW, if not already consider taking the time to create a folder on your non-phone computer setup then fill it (over time) with saved pics, pdfs, etc. from the www.
This allows you to search quickly for immediate details such as generator (dynamo) electrical test values on pdf Page 4 of this...
http://volvo1800pictures.com/docume...stem_p1800/part_3_electrical_system_p1800.pdf
Also let us know any parts you need so we can offer sources.
I always enjoyed wrenching on old Volvos rather than clicking around on the www but that may be due to the fact that my wrenching daze were before the discovery of top soil.
George Dill
