Old 05-27-2019, 03:32 AM   #1
seanile
seanile's Avatar
Default 240 Rear Jack Points
Hello! I have read and I have read, but everyone really only ever says to jack up the rear by the differential, and I know there must be somewhere to do it wheel-by-wheel.
I've figured out the front points, but please, tell me exactly where on the rear I can lift the car? (see my sig for exact model)
I plan on using jack stands so I can't be using the jack on the actual jack points because then I can't fit the jack stands...
So, as someone else had put it in their own thread about jacking up their car, talk to me like an idiot
1992 240 GL (4dr, B230F, M47, LH 3.1)
seanile is offline   Reply With Quote
Old 05-27-2019, 07:55 AM   #2
Otto Mattik
Otto Mattik's Avatar
Volvo like many European cars is a Uni-Body design, careful not to ruin the under body like so many stupid grease monkeys do.
Do you have some specific reason not to use the pumpkin(diff) ?
Originally posted by Jack
_________________________
Feedback Link: http://forums.turbobricks.com/showthread.php?t=323689
Old 05-27-2019, 11:14 AM   #3
Pick it up by the rocker and bend the ¢hit out of the pinch weld.
Old 05-27-2019, 11:32 AM   #4
240240
Throw black coffee at me
240240's Avatar
Why do you need to put on jackstands?
Originally Posted by miguels244 View Post
Pooptooth.
Shoot the poop!
I WANT TO BE HIRED BY 240240!!!
Old 05-27-2019, 12:28 PM   #5
seanile
seanile's Avatar
I recently got the car, so largely im just trying to understand all of the options for lifting it before the imminent need arises, since the pumpkin wont always be the best option.
However i would like to get it on jack stands to assess the condition of the exhaust (it barfed out some baffling this week), and also to get at the brakes and the rear sunroof drainage hoses
Old 05-27-2019, 12:39 PM   #6
johfraser
What kind of jack are you using? The factory screw jack will only fit the 4 jack points on the sides. If you have a rolling floor jack or even a bottle or scissor jack, I suppose you could put it under the axle out near the wheel.
Old 05-27-2019, 12:41 PM   #7
You can put jackstands on the rear jackpoints. They won't fit inside but they support the car just fine. There are thinner jackstands that fit into the jackpoint. The other place is behind the jackpoints there are body braces where you can also put a jackstand. Pickup the car by the differential and put it on the jackpoints or body bracing behind the jackpoint.
Old 05-27-2019, 12:46 PM   #8
122power
dude
122power's Avatar
If pinch weld rocker area use a 6" 2x4 to displace the load so it wont bend the pinch weld area. It may push into the wood but thats ok. Otherwise its the diff. Or the hinge pin of the stock jack point. You could probably use the trailing arm also but have to watch the angle if it slips or not.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 05-27-2019, 12:54 PM   #9
seanile
seanile's Avatar
Originally Posted by dl242gt View Post
... The other place is behind the jackpoints there are body braces where you can also put a jackstand. Pickup the car by the differential and put it on the jackpoints or body bracing behind the jackpoint.
i think i found this area, but wasn't confident my jack would be out of the way enough to be able to put a stand in place. i'll look again. have any pictures? how close is it to the jack point?
ive got a 2-ton roller, and two 2-ton jack stands. ive heard that jacking from the axle itself is a no-no, that not so?
greatly appreciate the responses everyone.
to be clear, the jack stands i have do fit into the jackpoints and are able to sit snugly under the pin. the issue is that i can't set the jack stands themselves up when using the jack there since the jack is in the way and there's not enough room in town for the both of them.
given the car is new to me, i'm in an information gathering phase and looking to understand all the viable points for lifting it that aren't the differential, especially any wheel-by-wheel means. those options seem to be,
1) still use the differential
2) rocker panel if the weight is dispersed via wood
3) body braces behind the jack points.
4) rear axle
5) trailing arm, beware angle changes/slipping
Old 05-27-2019, 01:06 PM   #10
cleanflametrap
cleanflametrap's Avatar
Originally Posted by seanile View Post
ive got a 2 ton roller that gets in the way of setting up the jack stands if im trying to place them near where im jacking (i.e. the rear jack points). ive heard that jacking from the axle itself is a no-no, that not so?
I've been working on 240s for 20 years, which in some ways makes me a newcomer, but in that time I've come to understand exactly what you're asking. You want to place the jackstands under the tire-change-jack points (as I would do) but then where do you put your floor jack?
I use the pumpkin, even though I know you don't want to lift the body by its suspension, it is the only way I do this. I can sneak my floor jack in from the side (it goes low enough) to leave space for a jack stand, if I don't want to lift the garage door to get the pumpkin directly from the rear, like there's 6" of snow out there. I haven't heard not to use the axle tube to jack by, but I suppose someone bent one once maybe?
Watch that you don't bend the loops the tire-change-jacks depend on. I found out the hard way on the road, and had to make an unplanned purchase of a cheap hydraulic floor jack.
In the front, I use the same technique always, under the crossmember.
-Art
Old 05-27-2019, 07:30 PM   #11
nel621
You came here for help and you got it. Almost everyone here has had there car on 2 jack stands if not 4. Most will lift from the diff. in the rear and the cross member in the front. Jack stands placed at jacking points. I use a a 3 1/2 ton Craftsman jack to lift my cars.
Old 05-27-2019, 07:32 PM   #12
nel621
Also I don't use the jack points and I also use 1/4 ply to keep the jacks from sinking into the blacktop.
Old 05-27-2019, 08:30 PM   #13
2turbotoys
Salaminizer
2turbotoys's Avatar
These work also, I use them occasionally when I can't get the jack behind the car. It safest to use them when there is something behind it such as the factory rear jack point and not in the middle of the car, which can dent in the rocker.
https://www.ebay.com/itm/USA-2X-Univ...8AAOSwcHRcnINm
1978 242, getting prepped for LS
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 05-27-2019, 08:31 PM   #14
Mr. V
Mr. V's Avatar
You can also jack it up at the pumpkin and put jackstands under the rear axle, toward the wheels.
Old 05-27-2019, 08:50 PM   #15
TestPoint
TestPoint's Avatar
duh . . . I have been jacking cars for 60 years and didn't know any better than pumpkin and axles.
Ford V8 Conversion Manual -
Old 05-27-2019, 11:04 PM   #16
seanile
seanile's Avatar
yep! absolutely right, thank you all for your help. as i said, was just getting my information straight so i could safely and adequately lift my 2 ton car and crawl under it didn't mean to be a hassle
Old 05-27-2019, 11:14 PM   #17
2turbotoys
Salaminizer
2turbotoys's Avatar
It's not a hassle, welcome to TB
Old 05-27-2019, 11:41 PM   #18
seanile
seanile's Avatar
cheers, and thanks for the frame rail recommendation, those look pretty damn handy.
Old 05-27-2019, 11:46 PM   #19
2turbotoys
Salaminizer
2turbotoys's Avatar
Old 05-28-2019, 12:22 AM   #20
philski o'flood
philski o'flood's Avatar
if you don't need to have the suspension hang you can use ramps
Old 05-28-2019, 01:37 PM   #21
Jack
junkman
Jack's Avatar
I just use me but you cant have me unless you pay $14.99
Old 05-28-2019, 02:15 PM   #22
Stiggy Pop
Stiggy Pop's Avatar
I pick my car up with a lift so there's really no choice BUT to lift it at the jack stand points. Done it a few hundred times now and it's not a problem. For me it's preferable to jacking it up by the diff.
'79 242
943 pickup
Old 05-28-2019, 02:29 PM   #23
240240
240240's Avatar
real men use saw horses
floor jacks are for little girls
Untitled by t s, on Flickr
Old 05-28-2019, 03:47 PM   #24
Broke4speed
Broke4speed's Avatar
I use these...but still on the stock jack points.
1984 244/ B6304S+T / AW30-40 w/Poi-Shift.
Old 05-28-2019, 09:40 PM   #25
2turbotoys
Salaminizer
2turbotoys's Avatar
Is that shipped?
