Old 04-24-2020, 02:54 PM   #1
noz-e8tr
noz-e8tr's Avatar
Default YoshiFab Turbo drain
Tired of my turbo oil return leaking at the block. I have the YoshiFab -10 fitting and drain hose kit. Has anyone installed one of these while the engine is in? Anything I can learn from your experience? Did you remove the filter relocation for better access? Trying to eliminate surprises once I have it in the air.
Berserker 242 Build Thread
This subculture is not conducive to meeting women let alone inspiring them to drive 30 year old, rectilinear, underpowered shit boxes.
Originally Posted by Walt Disney
"All our dreams can come true, if we have the courage to pursue them."
noz-e8tr is offline   Reply With Quote
Old 04-24-2020, 02:58 PM   #2
Spend another $45 for the "easy button" solution?
https://www.stsmachininginc.com/prod...-drain-adapter
Old 04-24-2020, 03:40 PM   #3
noz-e8tr
noz-e8tr's Avatar
Still an o-ring fitting. It will eventually leak.
Old 04-24-2020, 03:50 PM   #4
I mean ya, in like 20 years it might start weeping. Viton o-rings hold up very well, those ain't your granpappies buna-n o-rings.
I made an o-ring adapter 6+ years ago and it shows no signs of leaking past the o-rings.
Old 04-25-2020, 11:31 PM   #5
89_740Turbo
89_740Turbo's Avatar
You leave my granpappy alone
1989 744Ti
1988 744Ti
1986 744GLE (RIP)
My Feedback Thread - http://forums.turbobricks.com/showthread.php?t=342247
Old 04-25-2020, 11:40 AM   #6
Kestrel
Kestrel's Avatar
How does this stay in? Just a press fit?
Sure it's just a drain, but that has me a little concerned.
Kestrel is offline   Reply With Quote
Old 04-25-2020, 01:05 PM   #7
The o-rings and the force from the drain hose keep it inserted. There's one on my old street car and one on the turbo rally car. If there was ever any concern about it coming out, it would have been addressed. B230FT are cheap, $2k race weekends are not. We don't want failures.
It probably takes 15-20lbs of force to remove the drain hose and adapter fitting as one unit, if using a cheap ebay braided oil drain. It's such a pain that I just remove the hose when I'm pulling the turbo, leaving the fitting in the block. If you have that much force unintentionally pulling on your drain hose, you've got other issues.
Old 04-24-2020, 03:35 PM   #8
AndrewNance
Amateur hour!
AndrewNance's Avatar
I’d guess you can get in there well enough without removing the oil filter arm. Stick the drain fitting in the freezer and it should tap in there pretty easily.
Old 04-24-2020, 03:42 PM   #9
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
wanna say I put one on the blue car, in car, but it didn't have the oil filter extension I don't think. not a big deal if you wheel that guy out of the way.
Megasquirt Tuning!
Old 04-24-2020, 11:30 PM   #10
white855T
Its a tight fit with a rigid stainless hose. I'd go with the high temp silicone hose that atp offers for an easier install. https://www.atpturbo.com/mm5/merchan...egory_Code=OIL
Old 04-25-2020, 12:16 AM   #11
kahluaTDI
kahluaTDI's Avatar
JB Weld it on?
.Signature.
kahluaTDI is offline   Reply With Quote
Old 04-25-2020, 10:37 AM   #12
Dirty Rick
Dirty Rick's Avatar
That's how the Yoshi adapter seals, locktite
Old 04-25-2020, 01:36 PM   #13
Ursan
Bored Member
Ursan's Avatar
I did. Both my 940 and 780. Work a treat.
Originally Posted by 740freak View Post
how psi a stock can support?
Originally Posted by speedn_j View Post
So I’m a racist big deal who cares. Deal with it.
I admit I'm stupid...
1990 780t Kind of Modded 1994 945t Pegz, Tintz, Hidz.
"Rear Wheel Drive, the way God intended. If a car is being pulled from the front, doesn't that mean it's being towed?"
"Lister, you are a polyp on the anus of society." - A.J. Rimmer
Ursan is offline   Reply With Quote
Old 04-25-2020, 03:10 PM   #14
G-Tech 940
G-Tech 940's Avatar
I think you are answering OP's question of "Has anyone installed these while the engine was in".
If so, did you heat up the block?
I watched Josh's video for the install, where he does it on the bench. He said it was better to have the block warm if possible when doing it in the car.
Did you do it with the block warm from running, or did you heat it up another way? I have a bunch of other stuff to do while I have the oil drained so I'm not sure if I will be able to do it with the block still warm.
G-Tech 940 is offline   Reply With Quote
Old 04-27-2020, 01:09 AM   #15
Ursan
Bored Member
Ursan's Avatar
I didn't warm the engine at all, though they were both done in summer. Just cleaned out the bore, applied the thread locker and installed.
IIRC the 940 needed the tiniest bit of persuasion.
Installed with the car on ramps for easier access. Though removing the turbo would have made things easier, but it was impossible.
Neither leak to this day.
Old 04-26-2020, 04:01 AM   #16
MasterCylinder
What a lovely day!
MasterCylinder's Avatar
Location: The Fred Durst Society of the Humanities and Arts
https://www.240turbo.com/oildrain.html
Originally Posted by CAPT_BLOTTO View Post
Wait. T-5 to T5? You can't do that. That's like against the rules.
'90 745ti '02 WRX Wagon '81 Corolla SR5
Master Cylinder Music
MasterCylinder is offline   Reply With Quote
Old 04-26-2020, 05:06 AM   #17
Fa182
Stage 1
Fa182's Avatar
I installed it with everything in the car.
Had no issues and was an easy job. Put it in the freezer over night and it went in with just some very light tapping with a hammer.
I did remove the oil filter and cooler sandwich plate though because I had to change the O-Ring to the arm anyway as it was leaking. I didn't remove the arm itself.
I did all this with the front of the car only on jackstands.
Old 04-27-2020, 03:37 AM   #18
Fa182
Stage 1
Fa182's Avatar
Forgot to note that the engine was still kinda warm when I did it. At least cold enough not to burn my hands when unmounting the oil cooler and coolant lines
Old 04-27-2020, 11:01 AM   #19
rb92673
I did it with the engine in the car, manifold/turbo off, engine cold, adapter frozen. Lots of room then the exhaust is not in the way to hammer that sucker in.
Old 04-27-2020, 01:43 PM   #20
2barxr
i did it the same way i didn't have the cap so it little harder the only thing i did was brake the edge to make it easier to start
2barxr is offline   Reply With Quote
Old 04-27-2020, 02:13 AM   #21
77volvo245
77volvo245's Avatar
Try a measure the hole dia on the block. it should be one inch. I seen another b230 using my fitting I sell was lose in the block. I'm thinking the hole dia may vary.
STSmachining
Old 04-28-2020, 08:39 AM   #22
crogthomas
crogthomas's Avatar
Are you sure?
I measured three B230FT blocks and got closer to 25.1mm (1" is 25.4mm) which is a significant enough difference for a press fit to fail.
Old 04-28-2020, 11:28 PM   #23
77volvo245
77volvo245's Avatar
Originally Posted by crogthomas View Post
Are you sure?
I guess I should of measured before posting. I was going off memory of the size of the hole. The hole is smaller than one inch on the block
Old 04-27-2020, 01:40 PM   #24
2barxr
I heated it up with a heat gun it didn't go in as easy as i hoped but it is now in and no leaks
Old 04-27-2020, 02:40 PM   #25
Fa182
Stage 1
Fa182's Avatar
From what I'm reading some people did it from the top?
I did it from under the car and the only thing I had to remove was the oil filter to have some room to hammer it in.
