Old 09-10-2019, 01:32 PM   #551
cosbySweater
cosbySweater's Avatar
Yea those wheels are great and extremely cheap. Vision 571s on summit
1984 Volvo 245
1995 Porsche 993
2013 VW Passat TDI
Old 09-10-2019, 01:34 PM   #552
cosbySweater
Post a vid when you get there! Would love to see it.
Luckily for me, the guys I bought my aluminum 5.3 from ran it on the dyno and found worn cam bearings before they shipped it to me, common problem I suppose? I don't know... I had them put a cam in and fix the bearings way cheaper than I could have done it. What heads do you have on it? I have a couple sets of heads, currently have the 799 heads on it.
My aluminum motor is a lm4 so the older trailblazer/envoy engine. It has 706 heads on it. Yea cam bearings are a common issue on these things but honestly what I've found is the cam retainer plate and rear cover gaskets are the number one killer of the cam bearings.
Old 11-01-2019, 09:15 PM   #553
cosbySweater
Update! It works!!! Still. Just having fun with this thing. Once I redo the suspension I am calling this thing complete as far as the drivetrain goes. So here's a fun 1/2 throttle burnout I did in the woods last night
https://youtu.be/pqqA80ECxho
Old 11-01-2019, 10:00 PM   #554
122power
dude
122power's Avatar
Smokey smoke
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 11-01-2019, 11:55 PM   #555
2turbotoys
Astro Zombie
2turbotoys's Avatar
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 11-14-2019, 09:34 PM   #556
cosbySweater
Well guys ended up with another car. Massive amounts of progress spread through all the projects here. Let me see if I can get it all. Got the the full service done on my tdi, which is nice, I've put over 10k on it. Moved the gremlin over to a friend's house and we have YUGE plans for that car, as well as most of the engine stuff being done. Ummmmm did some service work on the 993, ironically I haven't driven it since August, but my mom dailys it to keep the miles on it and make sure it's okay. The Volvo is getting a intercooler swap and going straight back to the track. I'm going to see if I can crack tens with the 5.3 at low boost and full intake and exhaust. In full daily mode. Also picked up a 74 Bavaria with a friend that has a m30 swapped in 3x dcoes and a getrag 265. Don't know why we bought it but it's super funny. Pics incoming as well as videos
Old 11-15-2019, 12:00 AM   #557
Vol242vo
Keep it clean...
Vol242vo's Avatar
Ummmm yes please^^^^
Derek
1 Owner - 85k mile 1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 11-15-2019, 12:28 AM   #558
gsellstr
Vintage anti-ricer
gsellstr's Avatar
When are we headed to the track? Sitting on a decent spark tune and around 22-23psi, ready to smoke the slicks again, before the year is out. If we can get you, Ryan and myself out to lock in the win for the best coast that would be awesome!
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 11-15-2019, 03:19 AM   #559
cosbySweater
In that case I'll max out the ebc and leave the crank on the track!
Old 11-15-2019, 11:37 AM   #560
gsellstr
Vintage anti-ricer
gsellstr's Avatar
You said you'd do that last time and you failed, so now you gotta double up and make it happen! lol
You have my number, lets get together and get out there! Mine's pulling clean thru the rev range with the gap dropped down so it should be good for at least a 13.0 finally, if it'll hook.
Old 11-15-2019, 12:04 PM   #561
122power
dude
122power's Avatar
Who's we?
Old 11-15-2019, 01:12 PM   #562
cosbySweater
Yea I had a lean issue and you could feel the power going away. Moved the fuel pumps out of the sump and the issue is resolved. So I can push it a bit harder now
Old 11-15-2019, 02:00 PM   #563
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
I like it
Current setup - Aluminum L33/Summit Turbo Stage 2, Billet 80mm turbo, single Walbro 450 and Dual AEM 400's, Bosch 210's
3060lb no driver
3240lb with driver
Old 11-15-2019, 02:55 PM   #564
gsellstr
Vintage anti-ricer
gsellstr's Avatar
You're welcome to join us Luke. Gotta figure a day out and get something coordinated before Sac closes for the season.
Old 11-16-2019, 08:58 PM   #565
cosbySweater
When does the speedway close???
Old 11-17-2019, 04:36 AM   #566
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Usually weather dependent. Looks like this week is the last wednesday night drag for the year, but they have Saturday TnT's on the calendar thru the end of the year.
Old 11-17-2019, 03:00 PM   #567
cosbySweater
Okay I'm gonna shoot for sometime in December I have to mod the ic a bit to get it in and I'm planning on towing it there so I can be a bit more aggressive with it. Plan is to run mid to high ten in full street mode. Full size front wheels, full weight, full intake and exhaust
Old 11-17-2019, 08:18 PM   #568
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Get a cage in it yet?
Definitely let me know so I can get mine dialed and get Ryan up here as well.
Old 11-18-2019, 01:18 PM   #569
cosbySweater
No cage, dial in half track then full send
Old 11-18-2019, 03:43 PM   #570
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Good luck with that...they likely remember your car by now. lol
Old 11-18-2019, 08:32 PM   #571
cosbySweater
Meh only been there twice should be fine
Old 11-18-2019, 11:59 PM   #572
gsellstr
Vintage anti-ricer
gsellstr's Avatar
And been kicked out both times...
Old 11-19-2019, 12:02 AM   #573
122power
dude
122power's Avatar
No one forgets a fast Volvo lol
Old 11-19-2019, 01:26 AM   #574
cosbySweater
I'm willing to risk it. Lol, see how many times Jeff went out there with no cage?
Old 11-19-2019, 01:47 AM   #575
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Funny, they don't even tech my ****, even if I haven't been out there for a year, depending on who the tech is. Didn't comment on my helmet being out of date, where PIR said I needed to rent one that was in date.
