Old 08-30-2020, 01:46 PM   #1
BeaverMeat
Default Suspension for V8 swap
My 264 GL diesel (or, 244 GL D6) with a 1989 Mustang 5.0L is still rocking the stock suspension. The original owner changed out the shocks to KYB units which don't handle the stiffer diesel springs too well. It's actually a bit iffy on the road. The suspension has to be done.
I'm curious what set-up other V8 swap guys are using. Also, how does the Iron Windosr V8 effect weight transfer and balance compared to a regular red bock four banger? I can find optimum spring rate front/rear rate bias for four bangers, but not for a V8.
To be clear, I am aiming for actual performance for street and track use. Not "stance" suspension.
I'm thinking about Kaplhenke front suspension but, I have no clue what spring length and spring rate, or even what f/r bias to go with on this V8 car.
Thanks
BeaverMeat is online now   Reply With Quote
Old 08-30-2020, 02:07 PM   #2
740atl
educator monkey
740atl's Avatar
My buddies 242 is rocking stock suspension with a 5.0 and it handles fine. In fact the shocks and struts were the cheapest we could find... Monroes from rockauto. What’s the condition of the suspension bushings? Especially the rear trailing arm bushings, rear torque rod and front (rear) control arm bushings. If they’re shot the car will handle like a drunk pushing a wheelbarrow.
Old 08-30-2020, 02:19 PM   #3
On my 5.0 244 I use:
Bilstein HD struts in the front with 250 lb/in springs, 12” long. I’m also using BNE Select top mounts and KL Racing extended control arms.
Rear are cut down wagon overload springs (Moog CC217... I think), and Gabriel Ultra rear shocks.
Front bar is ~28mm, no rear bar.
Front toe is set at 0
Camber is -2.5 to -3 most days
Caster is 7deg
Old 08-30-2020, 04:01 PM   #4
BeaverMeat
Originally Posted by 740atl View Post
My buddies 242 is rocking stock suspension with a 5.0 and it handles fine. In fact the shocks and struts were the cheapest we could find... Monroes from rockauto. Whatís the condition of the suspension bushings? Especially the rear trailing arm bushings, rear torque rod and front (rear) control arm bushings. If theyíre shot the car will handle like a drunk pushing a wheelbarrow.
The car only has 80,000 miles on it and, it was an easy 80,000 miles.
Old 08-30-2020, 04:17 PM   #5
740atl
educator monkey
740atl's Avatar
Well if that means that the bushings on a 30 year old car are still good and not your problem then super.
Old 08-30-2020, 05:48 PM   #6
BeaverMeat
It went through an inspection, they are good. The mechanic just noted “It handles like a ‘65 Cadillac Fleetwood”. He knows my idea of “handling” is different then others. lol. To some, that’s ok. I like a car that can go around corners. Both kinds - left and right.
Old 08-30-2020, 06:10 PM   #7
Thanks
Whelp it's going to handle like sheet warmed over with a big lump of 'merican iron in the nose.
Old 08-30-2020, 06:47 PM   #8
I have an aluminum 5.3 and a Nissan 6 spd manual in my 240. I never weighed it with the redblock 16V/T5 trans setup, but just based on ride height and general handling, I really don't think the alu V8 added much weight at all.
IPD lowering spring, Bilstein HD's, 17X7 wheels and 225/40/17 tires.
Old 08-30-2020, 07:10 PM   #9
BeaverMeat
From my calculations with the transmission it’s only ~200lbs heavier up front... it’s probably less than that because I don’t have A/C. That’s not all that hard to compensate for. Essentially it’s the same weight as the D24 that came out of it.
Replacing the battery with a light weight unit and relocating it to the trunk will take ~45lbs from the front and add ~15lbs to the rear.
After that stuff gets expensive.
Old 08-30-2020, 07:33 PM   #10
283SD
I have an old school 350 Chevy in my wagon [installed in 10/88]. I drove for a year with the stock suspension, worked and looked fine. Bought lowering springs from IPD in'90 when I make it the two door, put in KYB shocks at the time they were OK, the 1" rear sway bar was the best ride changer. Changed the shocks to Koni sport adjust. It's a whole new car to drive. P/S the V8 added 70 lbs over the stock weight,alum intake and water pump, tube headers vs CI etc. Got to drive it on the Watkins Glen street course [closed to traffic] behind a GT1 Corvette and an A/C Cobra. That was a blast, a story for another time.
Old 08-30-2020, 07:46 PM   #11
https://www.gomog.com/allmorgan/engineweights2.html
Old 08-30-2020, 07:57 PM   #12
2turbotoys
Astro Zombie
2turbotoys's Avatar
Ask them at Kaplhenke, they make and use the stuff and can pick out what you need.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 08-30-2020, 08:16 PM   #13
BeaverMeat
Still waiting for a reply.
I think I'll need a set of corner scales so I can calculate the right f/r rate bias by cross-referencing with 244 Turbos.
Old 08-30-2020, 08:22 PM   #14
BeaverMeat
Dry, complete, short block, long block?
Old 08-30-2020, 08:56 PM   #15
mikep
The MP
mikep's Avatar
Bilstein HD struts in the front with 250 lb/in springs, 12Ē long. Iím also using BNE Select top mounts and KL Racing extended control arms.
Caster is 7deg
Start there, but if youíre worried about money forget the control arms. If you want to keep the stock front bar, use 300# front springs. And since 28mm is huuuge and heavy, look for a 25mm or a turbo front bar (22-23mm) used.
A stock wagon rear bar can help balance things. I prefer more rear spring Than an overload, but i donít have a v8.
IF you plan on drag racing, a big rear bar will help keep the right rear down. If corners are more Your style, more spring less bar in rear.
Also, a lower chassis brace helps a lot.
Originally Posted by leecatd8209 View Post
Being dead has a funny way of messing up your small business, too.
Old 08-30-2020, 09:14 PM   #16
BeaverMeat
It already has a iPD sway up front. Donít know the size as the car is still on the truck making the 1200 mile journey to my driveway.
Old 08-30-2020, 09:25 PM   #17
Probably long block dry IE: engine weight.
Old 08-31-2020, 03:23 PM   #18
Wrong. It won't make squat difference. The redblock is no lightweight. My old school 327/TH400 swap into my 1975 242 with B20 gained 150 lb. I weighed the car before and after on a local truck scale.
Old 08-31-2020, 07:20 PM   #19
Broke4speed
Broke4speed's Avatar
I find the position over the front wheels is a bigger change in handling. The B6304 I put in my 244 was quite long, and the car definitely felt nosey on a 21mm bar, IPD springs (1 coil removed), and KYB GR2s.
1984 244/ AQ140A / M46
Old 09-01-2020, 01:12 PM   #20
Did you get a reply?
Sometimes messages can fall through the cracks.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 09-01-2020, 02:59 PM   #21
BeaverMeat
Yeah, my calculations were wrong. The 5.0L and T-5 swap from an 1989 Mustang only adds closer to 100lbs, not 200lbs. It's within 11lbs of the D24 it replaced.
No big deal. This must be the reason for the 302 swap popularity in the 80s-90s. Today itís the LS. I have buddy thatís been buying up all the junked 05-07 GM extended cabs he can find for the relatively cheap all aluminum L33s. Probably the best bang-for-buck LS you can find.
I reckon an inline-6 is usually longitudinally larger than any inline-4 or V8. It's to be expected.
I did the "RE:" trick
Old 09-20-2020, 04:24 PM   #22
asilomar244
I have an LT1/T56 using the JTR crossmember. Had to do an aluminum racing radiator to keep it running cool. All of that together probably adds 150-200 lbs to the front axle.
I've done what I think would be considered a medium grade suspension build:
TME lowering springs
iPd sway bars, poly bushings
Bilstein shocks
TrueTrac LSD in 1031 3.73 rear end
Adjustable panhard and torque rods with poly
Cherry Turbos strut mount brace
iPd upper and lower chassis braces
OEM but replaced inner/outer tie rods and lower ball joints
OEM but replaced strut mounts
Currently dealing with failed rubber bushing in rear trailing arms (http://forums.turbobricks.com/showthread.php?t=356743), upgrading the rear trailing arm bushings to poly now.
So this suspension setup is pretty good but the car understeers which is annoying. So I would like to get full adjustable with a Kalpehnke setup eventually but that is $$$.
'82 242, 5.7L LT1, T56 6sp MT, TrueTrac LSD, 1.5" drop/Bilstein/poly/spacers, 16x6.5" Mimas wheels
asilomar244 is offline   Reply With Quote
Old 09-20-2020, 06:15 PM   #23
redblockpowered
redblockpowered's Avatar
Bilstein shocks
Understeers under what circumstances?
I sell chips for LH 2.4!
Old 09-20-2020, 07:16 PM   #24
+1. I would ask you to define under steer with regard to this particular car.
Old 09-20-2020, 09:39 PM   #25
asilomar244
It loses steering and pushes as it reaches the limit. Throttle on with LSD rear end help to compensate but not enough to overcome it.
