Old 02-15-2020, 05:46 PM   #951
Canuck
Frozen Garage Hell
Canuck's Avatar
Looks great. It's not that hard to break it apart and weld it up. It'll move a little, weld it to the collector first then the flange and clamp that sucker down.
- Craig
1966 Canadian (B5234T, C4 up front, Supra out back and a nut in the middle) http://forums.turbobricks.com/showthread.php?t=328003
1981 242 (B230FT, LH 2.4...and a few other things)
YouTube channel covering Canadian build https://www.youtube.com/channel/UCsx...n3CiBQFd4rMyXw
Old 02-15-2020, 10:36 PM   #952
Vol242vo
Keep it clean...
Vol242vo's Avatar
Work of art. Looks really nice.
Derek
1 Owner - 85k mile 1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 02-15-2020, 11:38 PM   #953
Tfrasca
Tfrasca's Avatar
Thanks, guys! I'm pretty happy with it so far. I'll need to brace the hell out of it since it puts the turbo way out there.
That was the original thought. But the Joints to the collector will be very difficult, if not impossible to get to with the runners already welded. I think we will weld all the 'els' onto the collector, then weld each runner as a sub assembly, then weld those to the els at the collector, and then to the flange. So annoying...
I wanted to fully weld runner number 2, which would act like a jig, but now I'm thinking we'll have to break that on apart too. So I guess I'll have to make a separate jig to keep the collector and flange in the right spots.
Old 02-16-2020, 12:13 PM   #954
vwbusman66
Stößelstange über alles!
vwbusman66's Avatar
Just dip the whole thing in jb weld?
1971 142 beater/fake racecar
Originally Posted by propav8r
The incest is implied.
Old 02-17-2020, 11:49 AM   #955
Canuck
Frozen Garage Hell
Canuck's Avatar
Jig for sure. I usually just scab together some channel and get it bolted down. Sucks for one's and two's but it's really needed. Tube is worse - but this stuff still moves a lot. I just hate that part. Beautiful fit, weld it up and get the grinder out to get it to fit. For me, it's the reason you can't make money building manifolds. Too much hand work.
Are you two passing the pipe? Big gas lens and a lot of stick out...and a cheater in my lid - and pray I don't shake! If I can get a supply of weld els (looking for 321 90's and Ace Race is out) I'll be welding one up in a few months. I've also changed my manifold flange design so that I'm not doing the fillet to the flange, but doing a butt weld to the runners.
Can't wait to see this one done - looks fantastic.
Old 02-17-2020, 01:29 PM   #956
Tfrasca
Tfrasca's Avatar
Yeah, Noah (the guy with the welding skills) and I have been saying how hard it must be to make money doing this. It's so fiddly, and with the warping, they're all a little different.
I want to do two passes, yeah. Seems like that's the best way to get 100% penetration. But we'll see what happens once we get going. Noah is a little concerned about adding essentially twice the heat into the piece, encouraging more warping.
Old 02-17-2020, 01:39 PM   #957
Duder
Comes with a free Frogurt
Duder's Avatar
Looking great, Tyler. In terms of timing of the exhaust pulses into the turbine, it looks like 4 and 2 might reach the wheel at about the same time:
1...3...4-2......1...3 etc.
If you have control of individual cylinder fuel trim you might want to play with the #4 as it might run a bit richer than the others at high engine rpm. I'd think the much longer runner will effect scavenging on that cylinder also, but that's something you can verify through reading the plugs after some initial testing.
Old 02-17-2020, 01:51 PM   #958
Tfrasca
Tfrasca's Avatar
I was planning on using Microsquirt, which wouldn't give me individual cylinder trim. In which case, I guess I'd just have to live with a less than ideal tune.
I don't see myself buying an ECU any time soon, though, so I still have time to do some research. Would an MS3 or another fully sequential ECU let me trim one cylinder?
Old 02-17-2020, 02:00 PM   #959
Duder
Duder's Avatar
I don't think it's going to be strictly necessary, just thinking of ways you could optimize if you wanted to. I believe MS3 can do it if you're running sequential injection. You would really want to install individual pre-turbine widebands on each runner though, in addition to a post-turbine wideband. Or at least have bungs in each runner and then tune each cylinder individually by moving one additional wideband through each of them, one at a time.
I'm just benchracing really, feel free to ignore.
Old 02-17-2020, 02:24 PM   #960
Tfrasca
Tfrasca's Avatar
Bench racing is highly encouraged here, since this car won't actually run for quite some time. This will be my first time messing with any kind of tunable ECU, so I doubt I'll really consider individual fuel trims, but it's fun to think about.
Old 02-17-2020, 02:25 PM   #961
Canuck
Frozen Garage Hell
Canuck's Avatar
It's less heat if you do two passes. The first is basically just fusion with very little filler and depending on your land thickness would be maybe 50 A. Then the cap is put in with just enough to get it to fuse all the way around. Pulse with like 100 A full pedal.
When I was making headers, It always takes about 50% more time than I think it will take and with purging and all the other messing around, it never got fast. Mild steel would be different, but stainless is time consuming to get it nice.
Old 02-17-2020, 02:41 PM   #962
Tfrasca
Tfrasca's Avatar
That's what I was thinking, re: heat, but I'm not doing the welding so I really don't know, haha. I wish he had a pulse set up, though.
Old 02-25-2020, 09:28 PM   #963
joel142
I'm curious how that will do, cooling-wise. Looks very similar to my fan setup, which didn't move enough air. I think your treatment of the radiator supports and top radiator cover looks great, though.
You mentioned barely clearing the hood. I assume that's just the filler neck? Do you have any pics of the mounting tabs at the bottom of the radiator? I'm thinking about that same radiator, but using a 240 style expansion tank and filling it from there. Not having the filler sticking up would help move it further forward, making room for the fan and shroud.
Yes, the cap has about a finger's thickness to the hood. I didn't want to get into modifying the radiator and/or finding yet another place for a bottle at a set height, but, I like the plan of the expansion tank. It at least give visibility of coolant height.
Here's a picture of the tabs. With the radiator centered up they just sit on the flat area before the fender wall slopes up. I found a radiator grommet on Amazon, step drilled the flange, and made a little bolt in plate with a pin that comes up. From your other thread it looks like you've made yourself some more room vertically. I thought long and hard about making the same cut because that bar sets the placement of my intercooler. I left it in not knowing what problems I'd unleash if I cut it.
The jagged hole on the right was where the intercooler piping ran on v1. The intercooler is now flipped and the pipes run out the top and I'll need to patch that hole. With the radiator there I have about 2.5" of space between the fan and the pulley. Probably room enough for a shroud. Shame to have something be at >1/8" tolerance in that bay...
Everything stacked in there. I need to trim the bottom oil cooler mount because it interferes with the grill trim. It's 1/4" spacing between each cooler.
'71 142E, M41, Corbeau GT seats, iPd bars and springs, Nardi wheel, GT gauges, overmatched KYB Gas-A-Justs, Canisto wheels, 7" and Series 175 Cibies
'95 T5-R, yellow, M56H swap
joel142 is offline   Reply With Quote
Old 02-26-2020, 11:26 AM   #964
Tfrasca
Tfrasca's Avatar
That looks great. I like that your oil cooler is able to fit. That's where mine was on my old 8 valve setup, but the way I ended up doing my radiator this time means I'll have to find a new spot for the oil cooler. I may just commit to the no bumper look and mount it in one of the old bumper holes.
This is how I lowered the radiator support to use the 16x20 radiator I already had.
2" square tubing, set about 1.5" lower than the old support:
M8 riv nuts in the bottom for splash pan/air diverter. I figure a big part of the poor cooling was the high pressure in the engine bay:
Roughly where the radiator will sit. This should give me room for a proper 14" fan and a decent shroud:
Old 03-09-2020, 09:33 PM   #965
Tfrasca
Tfrasca's Avatar
Got the radiator more or less bolted in. It's crazy to have this much room behind the radiator in a 140. Should make packaging everything a lot easier.
I'm pretty happy with the little supports I made to hold the radiator and give the hood slam panel its rigidity back after cutting off the old radiator supports. I made the new supports out of some 1.25" 1/8" square tube I had laying around. Unfortunately, I used the project to practice TIG welding, so they are pretty rough. Powder coat will help.
Old 03-10-2020, 06:13 PM   #966
cwdodson88
I would kill to have that many room for activities behind my radiator in the 122. I'm back to running my radiator tipped forward 15* to clear the new whirly boi goin in.
A flap disc should blend those welds nicely. I need to get in and clean up my ish welds.
Are you using scratch start tig or HF start?
The Build Thread
SVEA - PUSHROD TURBO!
Old 03-10-2020, 06:26 PM   #967
Tfrasca
Tfrasca's Avatar
Scratch/lift start. It's annoying, and I have jammed SO many tungstens into the puddle right as I start. I'm very slowly getting the hang of it though. Definitely enough to stick metal together in a quiet enough way that it won't wake the baby.
Old 03-11-2020, 08:56 AM   #968
cwdodson88
Do you have arc shut off control? The hardest thing for me was termination while keeping gas coverage. I rigged up a foot switch to a 200 amp dc contactor and it was so much easier. It’s definitely worth learning.
Old 03-11-2020, 10:30 AM   #969
Tfrasca
Tfrasca's Avatar
What do you mean by arc shutoff? It has a foot pedal, so I can taper the amperage on shut off. The post flow is not adjustable, but it seems to be tied to the amperage setting, so for hot passes, it'll flow for longer.
One funny thing with gas coverage: Whenever the cooling fan kicked on, the arc would go crazy and then burn through. I figured it was some sort of voltage thing since I was near the upper limits of the machine and using an extension cord. Turns out, I'm a dummy and had the fan inadvertently pointed right at the work piece, so it was just blowing the gas away.
Old 03-11-2020, 11:44 AM   #970
cwdodson88
Ah. Some/most old school scratch start, like mine, have no amp control, torch always live, set amps based on material thickness and go. That is the hardest to learn on, but gives you a lot of understanding of arc length control, and its effect on heat management as well a speed control. As the work piece heats up, get your best Goldblum on and must go faster till you're ready to finish. Basically you scratch the arc, pull to length, run your bead and as you get to your finish, slam some filler in the puddle to cool it then snap the arc away and come back in to maintain gas coverage.
Old 03-11-2020, 11:56 AM   #971
Sounds like the type of thing I do on the regular.
Old 03-11-2020, 05:26 PM   #972
Duder
Duder's Avatar
Me too. My shared workshop has a front door facing west and a roll-up door on the east side. The welding table is in between these. When we open both doors for flow-through ventilation the gas gets blown all over the place on a day with a stiff sea breeze. Took me a while to figure that one out!
Old 03-11-2020, 06:00 PM   #973
Tfrasca
Tfrasca's Avatar
Yeah, it was a weird one. I'm just going along, overheating the **** out of some 1/8" steel, minding my own business. Fan kicks on, then BAM.
The welder was on my bench, about 12" from the piece. Shielding gas never stood a chance.
Old 03-11-2020, 06:41 PM   #974
cwdodson88
whats the cup size and what cfh are you running? I'm liking my #14 mooseknuckle and my FUPA 12 at like 35-37, and I dont seem to have issues much unless its howling with all 3 bay doors open.
Also, you may want to try not outrunning your cup. Shorten you weld travel to the width of you cup. Not sure how your machine reacts to hot restarts, but if I run an inch on sch10 (.10 wall 304ss), and cut the arc, let it cool till the orange flashes silver and smack the pedal itll fire off again without scratch, then I can keep going and the tail is cool by the time it leaves the gas coverage.
Old 03-11-2020, 07:08 PM   #975
Tfrasca
Tfrasca's Avatar
I'm using an 8 with a gas lens, around 20-25 cfh. I know I was way too hot on this pass, too. Doing shorter runs would be way better, but I'm still at the point where I'm trying to coordinate my two hands, so I usually just power through...
