Old 03-20-2019, 02:18 PM   #651
t8fanning
8v are still cool, right?
t8fanning's Avatar
nice...looks a bit more lightweight than what I came up with.
Maybe. Ben's trailing arms do seem pretty light. But I do think my shock is a little more compressed at ride height than is ideal. I think putting the upper mounting point in the frame is definitely the way to go. It's just easier for me to machine a part than to cut and weld back there.
1982 242 Turbo.
Old 03-20-2019, 08:42 PM   #652
t8fanning
t8fanning's Avatar
Just took it out for a quick drive. The rear end feels so much better over bumps.
Old 03-21-2019, 02:09 PM   #653
I have drop brackets for the trailing arm to fix that.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 04-02-2019, 02:26 AM   #654
t8fanning
t8fanning's Avatar
I actually measured my shock at ride height and it's at 14.5", which is what ride tech recommends.
My buddy upgraded to a double pumper Aeromotive setup and gave me his Walbro 525 for a deal. At 27 psi of boost pressure I was seeing a 83% duty cycle on my ID1300s, so I wanted some extra pump headroom for when I turn up the boost this summer. Since the pump requires a bit more current than the 450, it transfers more heat to the fuel. To counteract that, I used an old oil cooler I had lying around as a fuel cooler.
I've never had vapor lock with this car, and I hope this cooler prevents it in the future with this pump. I've got a few more things to do before Davis, but I should be able to do it in time.
Old 04-02-2019, 12:41 PM   #655
84.242
Originally Posted by blkaplan View Post
So these are available again? They show out of stock/new model coming on the site?
84.242 is offline   Reply With Quote
Old 04-03-2019, 12:55 PM   #656
Not yet. hopefully soon. Keep running out of other stuff.
Old 04-03-2019, 01:53 PM   #657
84.242
thanks for responding Ben, i'll wait patiently
Old 04-03-2019, 03:36 PM   #658
cosbySweater
cosbySweater's Avatar
I gotta do the fuel cooler before Davis too
1984 Volvo 245
1995 Porsche 993
2013 VW Passat TDI
Old 04-12-2019, 01:43 AM   #659
t8fanning
t8fanning's Avatar
Ever since the fuel pump upgrade, I've been looking at my injector duty. It's not ideal.
The screenshot isn't great, but the lower plot is injector duty cycle (red) and boost (yellow). Injector duty peaked to 98% at 27 psi. What's weird is that after the gear shift I hit 33 psi, but that only required a duty of 85%. The spike corresponds to a difference in wheel speed between front and rear (upper plot). I'm not sure why the engine requires more injector duty during wheel spin when then engine isn't loaded as much. Can anyone shed some light on this?
I don't really want to, but I might have to upgrade to some 1700cc injectors. The above is all with a base fuel pressure of 60 psi, so I can't really increase it with the boost pressures I'm running. Ideally I'd do staged injection, but I don't have the available outputs on the ECU for that, and it would be way more expensive than a set of injectors.
Does anyone here have experience with idle quality on pump gas with ID1700s? I try to keep a mix above e60, but on road trips and stuff I use normal pump gas, so I'd like to know what I'm in for as far as idle quality.
Old 04-13-2019, 12:37 PM   #660
cosbySweater
What size lines to you have? What is the fitting situation at the sending unit?
Old 04-13-2019, 06:27 PM   #661
t8fanning
t8fanning's Avatar
I have -6 fittings brazed on the sending unit, and use -6 line with the stock hard line.
Old 04-13-2019, 11:32 PM   #662
cosbySweater
The bend in that sending unit is so small. Like the size of a 5/16ths fuel line
Old 04-13-2019, 11:48 PM   #663
t8fanning
t8fanning's Avatar
That's true. I should make my own with a different fuel level sending unit and big hard lines.
Old 04-14-2019, 11:39 AM   #664
RvolvoR
yep, the fuel system is only as good as the smallest part of it.
Old 04-14-2019, 03:43 PM   #665
cosbySweater
Do bulk head fittings and a -8 line for the feed. Make sure you're getting charging voltage at the injectors and pump!
Old 04-16-2019, 12:44 AM   #666
t8fanning
t8fanning's Avatar
I'm not too worried about the wiring. I use 10 awg for most of the run, and then step down to 12 awg.
I have been thinking about making a nice sending unit, but man there really isn't that much room.
Also, if I do a -8 feed line, I guess I need to swage the tube down to the 3/8" outlet of the walbro.
Old 04-22-2019, 12:41 AM   #667
t8fanning
t8fanning's Avatar
I got some ID1700x, and didn't do anything to my feed line. Required duty has dropped a ton; it's now hovering between 50-60% at ~30 psi of boost. They idle great on e65. I'll be curious to see how they do with pump gas on the way to Davis. So if anyone wants some ID1300s talk to me because I'll likely sell mine soon.
After installing the injectors and messing with the tune a bit, I went out with some buddies and did some pulls. My buddy who trapped 131 in the quarter can't pull away from me. My car is finally starting to feel fast.
Old 04-22-2019, 02:01 PM   #668
Duder
Comes with a free Frogurt
Duder's Avatar
Great to see the progress on this, and that's awesome that you're coming to Davis this year. Will be good to finally meet up and check it out!
Old 04-22-2019, 03:03 PM   #669
gsellstr
gsellstr's Avatar
***looks at my wagon...looks at list of cars on the fast drive for Davis....shudders at the thought of being the slow one....
Awesome news indeed man! FYI, bring your tuning stuff, we DO have quite a few E85 stations in town. I'm back to straight E85 now and we seem to be getting a decent blend in the Propel tanks right now.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 04-22-2019, 03:25 PM   #670
t8fanning
t8fanning's Avatar
It'll definitely be a good time.
I drive pretty slowly normally, I mostly like to go fast just doing pulls with people. I'll definitely bring my laptop. I already know I'll have to knock out a ton of wastegate duty. It loves to hit boost cut down there.
Old 04-22-2019, 03:33 PM   #671
RvolvoR
wrong, raise boost cut.
Old 04-22-2019, 04:13 PM   #672
t8fanning
t8fanning's Avatar
Lol. I'll raise boost cut when I don't have to drive the car 700 miles home.
Old 04-22-2019, 05:38 PM   #673
Duder
Duder's Avatar
I think I know what the problem is. Your titanium aluminide turbine wheel is too light.
Old 06-23-2019, 06:31 PM   #674
t8fanning
t8fanning's Avatar
It's been a while, but I've just been driving the car. I finally decided to upgrade the brakes from the RX7 and stock rear calipers I had to match the power I'm making. I don't think I'll ever put big sidewall slicks on the back, so holding out to fit 15" wheels in the back isn't a priority anymore. It's not a drag car. It's a street car and most of my driving is highway pulls anyway, so I put R brakes on front and rear. Maybe not the best option, but I got them for cheap and it's an easy job. I use a mustang master cylinder with a volvo reservoir and I shortened a wilwood push rod spacer to make up the difference.
The only tricky part for me was that my local hose shop couldn't find the same bulkhead fittings as stock for the rear soft lines. So I changed it from a bubble to a double flare and used these fittings:
Simple enough fix and it works just as well. Fronts look like this:
Rears look like this:
I also finally rounded out my Stack gauge collection and got a new boost gauge:
Old 06-23-2019, 07:45 PM   #675
122power
dude
122power's Avatar
Is that the STS set up?
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
